  1. Mar 21, 2020 at 9:52 PM
    Running Board Man
    Running Board Man Well-Known Member
    I will hurt you... i floor it get my 30% manual over-ride and 3 seconds later get full throttle but only shift before redline
    Iirc my tacoma would go into it before shifting
    The trans was rebuilt so the shitty feeling shifting could be that
    even though i have the same symptoms as a bad accumulator piston, ive googled it i still dont know where it is , the procedure, or what parts to use
    And my buddy with his 97 that shifts like a transmission rubs it in my face cause he actually pulls on me
  2. Mar 21, 2020 at 10:04 PM
    dweikum
    dweikum Well-Known Member
    Duane
    Oakland CA
    02 4WD V6 5spd SR5 TURD
    Replaced inner and outer Tie Rods and Sway bar end links and bushings.
    Replaced fuel filter.
    Replaced hood latch cable.
    Been a long day...shower and bed now.
    Bridge4 and Running Board Man like this.
  3. Mar 21, 2020 at 10:10 PM
    00_5VZ
    00_5VZ Dumbest smart guy you’ll ever meet
    Rob
    Thornton, CO
    2004 DC TRD, S/C, Impulse Red Pearl
    TRD S/C, URD 7th injector, Deck plate mod, gray wire mod, 2 low mod, magnaflow cat back exhaust
    ABS was available in 95-97 Tacoma, but it’s a hard to find option. We have a customer at my dealer who has a 96 SR5 Tacoma, and his has ABS
  4. Mar 21, 2020 at 10:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Working on a shock relocate.
  5. Mar 21, 2020 at 10:13 PM
    Running Board Man
    Never heard of it
    Kinda like the pre trd locker?
  6. Mar 22, 2020 at 12:10 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Sweet bypasses!
    Gonna box the frame while you're down there?
  7. Mar 22, 2020 at 7:01 AM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    4C1E002B-F0A4-4508-A15A-2CC98C2CDA71.jpg 4EEB41FE-5A09-4E85-9201-F7DAB9088ACC.jpg Busy day yesterday.
    -Fixed my E Locker (inside was gunked up with crud. Cleaned, relubed, works like a champ).
    -Built a fold out camp table (still needs paint)
    -cut and installed the newer ARB fog light pods with Baja Designs fog lights.
    nagorb, cruiserguy, Phessor and 5 others like this.
  8. Mar 22, 2020 at 7:54 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Awesome truck.
    Looks like you're the kind of guy who could use one of these. I just bought one a few weeks ago and have used it on my tractor push bar and ROPS to mount some LED lights. It worked real well. From what I have read, you just have to be careful to not break the bits while you have it attached and inserted into a hole. Any side to side movement puts a lot of stress on the bits and can snap them off.
    https://tinyurl.com/vyjcucl
    cruiserguy likes this.
  9. Mar 22, 2020 at 8:46 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Just manual swap. Then it does what you tell it to do 100% of the time.
  10. Mar 22, 2020 at 9:14 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    specs on shocks plz
  11. Mar 22, 2020 at 9:17 AM
    iunek808
    iunek808 Well-Known Member
    oahu
    04 tacoma dblcab prerunner 4x4
    Tundra 5100's w/Fj springs Deaver leafs 4x4 conversion w/manual hubs Jshift
    10k seems super shitty lol. Pay for what u get. 158k on all the parts i changed. Why only 10k on oem lbjʻs?
  12. Mar 22, 2020 at 9:19 AM
    Running Board Man
    It will still have the throttle body that only opens the butterfly 30% when the throttle is pushed 100% than the rest is determined by the computer
    Theres a shift kit and manual shifter for the a340
  13. Mar 22, 2020 at 9:31 AM
    Digiratus
    Roaming the PNW
    The RedHead
    The Mercer Fab frame plates we put on there 7 years ago have been plenty of reinforcement. Don't feel the need to box it.
    These are 10" stroke with welded rod ends and CO type top cap to make them as compact as possible. 25" extended, 15' compressed.
    I got these shocks from Matthew at MCM Fab about 2 months ago. Just now getting around to getting them installed.
  14. Mar 22, 2020 at 10:11 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Because race truck!
  15. Mar 22, 2020 at 10:20 AM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Yep!! It’s all about driving style and conditions. I got almost 80k out of a set of Moogs but that was at least 90% highway miles. Although AZ highways are as bad as some of y’all’s dirt roads.
    chrslefty and Running Board Man like this.
  16. Mar 22, 2020 at 1:36 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  17. Mar 22, 2020 at 1:40 PM
    2004TacomaNavy
    2004TacomaNavy Well-Known Member
    Brian
    Oak Harbor, WA.
    04 Extra Cab 4X4 SR5
    All Pro rock sliders, U-Bolt flip kit, Shock mount relocation tabs, All Pro Billy 3" lift front and back, 2014 Tundra Bed Rail tie down system, Fuel 17X8.5 Wheels on 32's, LED front light bar, Raptor style grill W/lights, Tinted Headlights w/LEDs, ARB Dual Air Compressor W/ 2 Gal. Tank, Smoked Tail Lights, Double Din Sat radio w/ back-up camera, Redline Hood Struts, ARB Dual air compressor W/ 20 Gal. air tank, Sig P320C Security System!
    Model complete. Should be good for 10mph gain. Lol
  18. Mar 22, 2020 at 2:08 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Im gonna say nah. Should move some but since you had to use a prybar to get it to move I dont think its bad yet. How bad is it if you move it by hand?
  19. Mar 22, 2020 at 2:11 PM
    JKO1998
    Utah
    It moves a bit. I feel like an out of balance drift shaft or wheel would vibrate all the time.
  20. Mar 22, 2020 at 2:13 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    My brand new one had 1/2" of play in it.
    Running Board Man likes this.
