  1. Apr 2, 2020 at 7:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Mood: Old leaf springs.
  2. Apr 2, 2020 at 7:34 PM
    0xDEADBEEF
    I was looking at the general spring oe replacement. Most lift I would want is about an inch, so maybe an aal. I need to research it.
  3. Apr 2, 2020 at 7:35 PM
    Phessor
    Phessor Well-Known Member
    I tossed mine over a year ago.
    Camtron[QUOTED] and chrslefty like this.
  4. Apr 2, 2020 at 7:39 PM
    0xDEADBEEF
    The other reason i was under here... trying to get an idea of frame integrity. Found a cheap ultrasonic thickness gauge on the Amazon. Not incredible, but good enough to give me an idea of what the typical bad spots are like. Seems like I'm in decent shape so far, need to do some more.
    Edit:. So far, 3mm thickest in the pic below, 2.7mm on the bottom of the frame where it curves up in front of the leaf springs. So not perfect, but also not about to collapse at the mall.
    Reh5108, cruiserguy and SwampYota like this.
  5. Apr 2, 2020 at 10:49 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Okay folks, I need to defeat the upstream oxygen sensor heater circuit, OX1 in the wiring manual. The resistance range are as follows:
    Am I correct in assuming a 20 Ohm, 1 Watt resistor is capable of simulating the heater circuit, as 20 Ohms is in the middle of the minimum and maximum ranges? Or maybe a 20 Ohm, 5 Watt resistor is more appropriate.
  6. Apr 3, 2020 at 5:29 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Fixed.
  7. Apr 3, 2020 at 5:47 AM
    0xDEADBEEF
    I would think something in the 23-32 range if 800c is the temperature it's targeting.
    Any idea how much current that heater circuit pulls?
  8. Apr 3, 2020 at 5:51 AM
    Wsidr1
    Indiana
    Just trying to help, not give GOOD advice. I am weak only electrical knowledge.
    I looked here:
    https://www.electricaltechnology.org/2014/02/ohms-law-P-I-V-R-calculator.html
    Even doing the math manually, I still see: Watts=(V*V)/Ohms Watts=(12*12)/20=144/20=7.2watts. I'd get a 10 watt. Probably only $5-8.00 anyway, if you go too big, you can downsize. Bad to go the other way. Might work at first, then overheat.
    Let me know if you figure out otherwise. I rarely mess with electronics. I might learn something new!
    0xDEADBEEF likes this.
  9. Apr 3, 2020 at 7:24 AM
    Narty
    Narty Well-Known Member
    Orange County
    1998 Black Tacoma ext cab 4x4 A/T
    OME nitrochargers, Dakars+AAL, JBA UCA 285/75/16 Nitto Ridge Grapplers on TRD baja "beadlocks" Flippac
    not sure where you are located but im about to get the heavy duty dakars and will be selling my stock leaf springs + headstrong AAL if you're interested. Stock leaf springs still have plenty of life in them and the AAL has about 5k miles on it. The overload spring was removed too so you woudn't get too much lift.
    GQ7227 likes this.
  10. Apr 3, 2020 at 7:32 AM
    0xDEADBEEF
    Hmm. I think shipping is going to make that pretty tough. General Spring is actually local to me, which makes them super attractive.
  11. Apr 3, 2020 at 9:46 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    What's this for? Mine never had one when I got it from the PO, so maybe they already removed it.
    Running Board Man likes this.
  12. Apr 3, 2020 at 9:50 AM
    Camtron
    Camtron Active Member
    Cameron
    98 Shitbox
    OME suspension. 33s. Sliders. Bumpers. Skids.
    I think they put them elsewhere after 99? Not positive on that, but it’s just an accumulation tank for the vacuum actuated 4 wheel drive.
  13. Apr 3, 2020 at 9:54 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Maybe after that was the electronic actuator?
    Reh5108 and Camtron[QUOTED] like this.
  14. Apr 3, 2020 at 10:44 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    I have a 2000 and it has it. I have thought about relocating it. Gets covered with mud and ice all the time. Not a great spot for it. Thinking somewhere in the engine bay would be better.
    Camtron[QUOTED] likes this.
  15. Apr 3, 2020 at 11:02 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Put my Gear Tech Customs PROTEC splash guards on. The stock ones were a little jacked up from when I put the lift on these are much better quality:
  16. Apr 3, 2020 at 11:16 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    I have these as well and really like them. Only complaint is the piece that attaches to the shock tower ended up tearing on both sides. Still much better than stock.
  17. Apr 3, 2020 at 11:18 AM
    Phessor
    They look better than the cheap Yota Liner brand I purchased.
    2002Tacoma4x4 and 1997tacomav6 like this.
  18. Apr 3, 2020 at 11:31 AM
    SwampYota
    Jon
    Floor mats
    These are pretty thick, I would’ve expected them to yank the plastic clips out before tearing, I’ll keep an eye on that.
    They’re definitely thicker than stock.
    Phessor[QUOTED] likes this.
  19. Apr 3, 2020 at 11:36 AM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    overloaded the taco with my front and back yard's crab grass. riding looowww but took it like a CHAMP. I have no idea how much weight it was but def more than 700lbs which until today was the most I have ever put in the back.
  20. Apr 3, 2020 at 11:39 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Thank you, that’s very helpful. I didn’t know I could use Ohm’s Law without the missing variable I, or current. I’ve got a 1 watt and 5 watt 20 ohm resistor on order, I’ll see if I can get a 10 watt.
    Wsidr1[QUOTED] likes this.
