  1. Apr 5, 2020 at 6:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just buy some 1/4'' or 1/8'' vac line and put one cut in it to open one side of it. It'll grip the metal and look good. Plus super cheap and easy to do.
    austinmtb[QUOTED] likes this.
  2. Apr 5, 2020 at 6:21 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Spent about 2 hours in my left front fender well. Added a fender liner (been missing since I rebuilt this wreck) and added a seal to keep winter slush from splashing into the engine compartment.
    If you know anybody in the roofing business, this stuff really comes in handy. My brother-in-law does warranty inspections for Firestone on the roofing products they sell. Gets me all the free rubber I need.
    Lots of holes already in the frame and inner fender panel, and I had some of those push pin type clips that can easily be removed for oil filter access.
    CS_AR, cruiserguy, dc welding and 2 others like this.
  3. Apr 5, 2020 at 7:15 PM
    Jeeperwilly
    Jeeperwilly Well-Known Member
    NE Minnesota
    03 X-cab 4x4 TRD
    Mostly exterior stuff and engine parts....spare headlights, tail lights, fiberglass ram induction hood, ratty 5 spoke 4Runner wheels, the supercharger and 7th injector setup, spare stock intake, oil pan, complete heads...stuff like that.
    Hooks98tacoma[QUOTED] likes this.
  4. Apr 5, 2020 at 7:41 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Made a couple of harnesses today and got the front lights installed. All most 180 degrees of light up front! Side and rear lights next.
    0F8981CC-F7EE-425A-AF42-E2E4932F76F7.jpg 9160309D-F91F-48D2-9CA6-0C41E69A41E7.jpg 1DB58C14-758B-479D-A209-3EFCAC8CDE9F.jpg
  5. Apr 5, 2020 at 8:11 PM
    InAComa2004
    InAComa2004 Well-Known Member
    2004 Toyota Tacoma(Base)
    Ive been wondering how my truck would perform without the 2nd cat. Would y'all know how it would perform?
    2004 Tacoma 2.4L 4x2.
    Running Board Man likes this.
  6. Apr 5, 2020 at 8:14 PM
    Running Board Man
    Running Board Man Well-Known Member
    Meh, some say less restriction more power, others say the catalyst is larger than the pipe diameter so it doesnt cause restriction
    None have proof
  7. Apr 5, 2020 at 8:15 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Do the cats change size for the v6 engine?
  8. Apr 5, 2020 at 8:15 PM
    Running Board Man
    Its 2.25 inch pipe on v6s idk 4 bangers
  9. Apr 5, 2020 at 8:19 PM
    InAComa2004
    I've been slowly piecing together a "test pipe", so I was just wondering about this, and also how much would it normally cost for a exhaust shop to weld it on?
    I like how tons of people are on.
  10. Apr 5, 2020 at 8:19 PM
    0xDEADBEEF
    Looks like rockauto has separate part numbers for them. So much for that theory.
  11. Apr 5, 2020 at 8:30 PM
    Running Board Man
    Depends where you live where i live they will give you 70 bux to cut the cats off and weld a pipe in their place
  12. Apr 5, 2020 at 8:30 PM
    Running Board Man
  13. Apr 5, 2020 at 8:31 PM
    0xDEADBEEF
    I was thinking if the v6 and the 4 cylinders had the same cats, there wouldn't be much gain in going to bigger cats.
    but then again, from a production perspective, it would be simpler to put the same size cats on all of them - so why do they bother making smaller ones for the 4 cylinders?
  14. Apr 5, 2020 at 8:31 PM
    InAComa2004
    Sounds good, I wonder how Houston's shops price at when I have pipe for it
  15. Apr 5, 2020 at 8:32 PM
    Running Board Man
    Platinum is expensive
    0xDEADBEEF[QUOTED] likes this.
  16. Apr 5, 2020 at 8:33 PM
    Running Board Man
    Go on facebook market place and look for ads like this
  17. Apr 5, 2020 at 9:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The front cat was removed from my truck with an open pipe welded in it's place. It is definitely louder than before. Can't say whether that means it performs better because my butt dyno is out of calibration.
    Phessor likes this.
  18. Apr 5, 2020 at 10:39 PM
    Timmythetacoma
    Timmythetacoma Well-Known Member
    Taylor
    Estacada Oregon
    2019 quicksand Trd off road
    Took my 3rd gen grille and put it in my 1st gen
    erice, jdmstuff, kuntry09 and 15 others like this.
  19. Apr 6, 2020 at 12:50 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I thought I would hate it... But I don't.
  20. Apr 6, 2020 at 1:00 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
