  1. Apr 15, 2020 at 6:15 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    That’s the spirit.
  2. Apr 15, 2020 at 6:17 PM
    ericp95
    ericp95 Mean Jeanine
    Eric
    04 Tacoma V6 4x4 Manual
    I'll have to call and get more details..
  3. Apr 15, 2020 at 6:19 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    In actual regards to a first gen. the 02 definetly needs cats.. oh well.. 01 cats will be going on it shortly.[​IMG]
    2002Tacoma4x4 likes this.
  4. Apr 15, 2020 at 6:20 PM
    ericp95
    Eric
    Is it just non-oem vs oem in general or specifically in reference to ball joints?
  5. Apr 15, 2020 at 6:21 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Replaced the evap vacuum valve, the old one was making a loud tick at idle. Also hoping this will fix warm stalling.
  6. Apr 15, 2020 at 6:21 PM
    BeLance89
    Brandon
    Huntsville, AL
    Are you familiar with... Pandora’s box?
  7. Apr 15, 2020 at 6:21 PM
    Empty_Lord
    Dan
    non oem anything else is fine. the LBJ aftermarkets are known to fail early. My moogs cam dangerously close in 10k miles.
    luckily they fully refunded me and i got some OEMs before they went.
    2002Tacoma4x4 and m3bassman like this.
  8. Apr 15, 2020 at 6:22 PM
    Empty_Lord
    Dan
    the tick is normal. may be a hint quieter because the rubber isolater is there. but it'll still tick
  9. Apr 15, 2020 at 6:23 PM
    ericp95
    Eric
    Gotcha..... ok.
  10. Apr 15, 2020 at 6:24 PM
    CrustyTaco
    Todd
    Louisville, KY
    Would you expect to it be one of the loudest components in the engine bay? I just started noticing the tick a couple months ago. I've owned the truck for 6 years.
    Running Board Man likes this.
  11. Apr 15, 2020 at 6:26 PM
    Empty_Lord
    Dan
    they're all pretty loud. even in the new cars. its a valve that opens and closes very fast when its commanded on.
    even the brand new one in the 02 still ticks (the original actually quit ticking... because it died and threw a code). the 01 my father bought new. its ticked as long as he can remember. its not all the time. only when its asked to vent.
    CrustyTaco[QUOTED] likes this.
  12. Apr 15, 2020 at 6:31 PM
    CrustyTaco
    Todd
    Louisville, KY
    Good to know if/when I hear the new one ticking. I imagine the old one got noticeably louder when it broke free from its mounting plate. Was probably resting on some metal that resonated louder than the rubber pad.
  13. Apr 15, 2020 at 6:33 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    What about the O2 sensor and MAF sensors?
  14. Apr 15, 2020 at 6:36 PM
    Empty_Lord
    Dan
    i graphed all the sensors. the A/F responds correctly to fuel being added or removed (-12% to +25%). and the rear o2 seems to operate just fine. its the lack of a delay between the two when switching from rich to lean that tells me the cat has failed (the techstream can really show you alot of info.
    plus the o2 and A/F sensor were replaced 2 years ago.
    ideally with a healthy cat when you add or remove fuel the rear o2 sensor should lag behing a second or so. indicating the catalyst is working properly
  15. Apr 15, 2020 at 6:36 PM
    Empty_Lord
    Dan
    that is what typically happens
  16. Apr 15, 2020 at 7:01 PM
    eon_blue
    Azusa, CA
    Slap some Magnaflow cats on there, been happy with mine so far
  17. Apr 15, 2020 at 7:25 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Same. Except only one since 4cyl.
    Bolted right up which was nice. Didn't have to deal with welding on flanges & stuff.
    eon_blue[QUOTED] likes this.
  18. Apr 15, 2020 at 7:28 PM
    eon_blue
    Azusa, CA
    I assume you had to get the CARB certified ones too since you're also in CA? I was told that for CA certified cats, if you don't want to spend the $$$$ on OEM ones then Magnaflow is the only way to go. I got both replaced for $600 a few years ago and have passed smog twice with them with flying colors, so I'm a fan. For the price (compared to OEM) they can't be beat.
    2002Tacoma4x4 and Silver02Taco like this.
  19. Apr 15, 2020 at 8:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    nice to see a big photo of this ha
    I bet if you made the side plates thicker like you said you'll be good. Also can you run a tube on the bottom tying the two plates together? is there room? I'd do that as well for when it is open.
  20. Apr 15, 2020 at 8:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah I think i see it now. Cool.
    Im sure that will help some with the deflection.
