  1. Apr 21, 2020 at 5:09 PM
    Jebediah
    Jebediah Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    Gave the topper a fresh coat of flat green paint.
    Attempting to diagnose a bad e-brake. I can engage the brake but then it sticks on. The cable appears to be frozen in place somewhere in front of the rear diff (inside of the sealed tubing). Anyone have any ideas as to how I can fix this? I can pretty easily get down behind the diff and pull the cable in order to release tension on the brakes so it can't be stuck too bad, but it won't release with the handle.
  2. Apr 21, 2020 at 5:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Only for trail gear. An inchworm doesn't really make them for them they were bought out. Marlins product is entirely their own
  3. Apr 21, 2020 at 5:10 PM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    COVID projects continue. my brother gave me an extra cargo net off his subaru. I rigged it up for the kiddos to put their stuff up while on long trips.
  4. Apr 21, 2020 at 5:13 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Check the bell cranks at each wheel. Common for them to get sticky.
    Jebediah[QUOTED] likes this.
  5. Apr 21, 2020 at 5:26 PM
    Speedytech7
    You can swap the gear ratios in the land cruiser gear driven cases, I thought about getting the 4.8:1 set for mine. But yeah, most of these reduction sets are planetary, not just helical cut cogs, so they're not Uber strong and they generate heat and noise. Be hard to make a case that wasn't the size of a manual trans that avoided those issues
  6. Apr 21, 2020 at 5:31 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    @Blackdawg a while back you mentioned you’d like a spring under kit for your single cab so you can sit about stock height but get the benefits of SUA. Maybe this is a way to make this happen. Just need to see if Deaver will design a lead pack. Last time I spoke to them they said they wouldn’t do it.
    https://www.ruffstuffspecialties.com/catalog/DEAV-WIYP.html
  7. Apr 21, 2020 at 5:49 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    Fabricated a bracket for the transmission oil cooler, take everything off, paint and connect the hose tomorrow
    Kevins60, SwampYota and Hooks98tacoma like this.
  8. Apr 21, 2020 at 6:28 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Any additional details on this? Is the bole pictured (on each side) the only modification necessary to do the swap?
  9. Apr 21, 2020 at 6:47 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    :burp:
    Hope I took enough pictures.:laughing:
    cruiserguy and Speedytech7 like this.
  10. Apr 21, 2020 at 6:59 PM
    Speedytech7
    Is easy, you'll be fine. Hardest part is cleaning everything to put it back together
    cruiserguy and Running Board Man like this.
  11. Apr 21, 2020 at 7:01 PM
    0xDEADBEEF
    Yeah, I think I've done a decent job of putting bolts back in their holes, and the wiring usually just falls back into place.
    Now if I could find my 12mm socket that I dropped, I'll be set.
  12. Apr 21, 2020 at 7:03 PM
    Speedytech7
    I actually did stuff to my Taco today, greased the driveshaft for the first time since who knows when... Maybe never, who can say. I've only had it for 6 months. Charged the AC too, it had a bit but only enough to kick the compressor on, not enough to actually get cold air. Works good now, we will see if it lasts.
  13. Apr 21, 2020 at 7:04 PM
    0xDEADBEEF
    Mmmm intake valves
    cruiserguy likes this.
  14. Apr 21, 2020 at 7:05 PM
    0xDEADBEEF
    I charged mine about a year ago, and it seems to be ok, but I know the valve in the dash leaks. :(
    Running Board Man likes this.
  15. Apr 21, 2020 at 7:06 PM
    mataco4wd
    mataco4wd Well-Known Member
    994wd
    Not much work honestly, I used a level and a buddy's eye to visually mark the holes for the headlight adjusters. Then I drilled and filed square. Used a ball peen hammer to angle the headlight adjusters straight and level. Went to ace and matched up springs with some 1987 pickup springs to secure the headlight assembly to any close by lip corner of rad support. Snapped the grill on and my headlight plugs went right in. Also ordered the inserts for the corner lights which the 99 fenders had already drilled square and popped right in. Installed corner lights and aimed headlights straight. Here are some more pics.
  16. Apr 21, 2020 at 7:08 PM
    Speedytech7
    Yeah unfortunately the expansion valves are a known weak point, my last two tacos had bad ones. If this one is too then I will replace it, it's not that bad of a job actually. But I'm hopeful, I used the stuff with tons of stop leak because in the AC system it doesn't matter, can only help and replacing parts to solve a leak that takes a couple years to affect it isn't worth it in my mind.
  17. Apr 21, 2020 at 7:09 PM
    0xDEADBEEF
    Yeah, that's fair. I feel like if I'm going through the trouble of evacuating it, I may as well take it apart and replace some orings while I'm at it, but that's a much bigger job.
  18. Apr 21, 2020 at 7:13 PM
    Gen1FTMFW
    Nice work. Got any pics of how the headlights line up with the grill? @Madjik_Man did a similar swap a few years ago and noticed a slight gap between the two, was just curious if you saw the same thing.
  19. Apr 21, 2020 at 7:15 PM
    Gen1FTMFW
    For reference...
  20. Apr 21, 2020 at 7:21 PM
    mataco4wd
    994wd
    I used to own a 95.5 so I do remember them fitting pretty damn flush, I am very picky about symmetry and lines and honestly the gapping is not bad at all. Its pretty even all around so it doesn't look odd, Maybe 1/4 inch in the top outside corners but it has to do mostly with the after market grill trimming than the headlight mounting. This front has a special place in my heart cause of the 95.5 that I wanted to commemorate lol. More pics
