  1. Apr 21, 2020 at 7:31 PM
    mataco4wd
    mataco4wd Well-Known Member
    994wd
    @Gen1FTMFW I've seen some local 96 fronts on the road all stock and even they sometimes have small gaps. I worried about this same thing, I did read that thread that @Madjik_Man made but I did not have to cut the holes for the headlights as they did,so maybe that put me a little further out than they did, and also did not use the piece from the 99 headlight.
    Gen1FTMFW likes this.
  2. Apr 21, 2020 at 7:31 PM
    Running Board Man
    Running Board Man Well-Known Member
    Now i feel even worse for wrecking my taco that had cold as fuck ac, that hadnt been touched since 1997
  3. Apr 21, 2020 at 7:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I just installed my 3rd set of Alcans (yeah, I'm a fanboi) and have never had this issue. My wheels have always been centered in the wheel opening.
    I am sure you are correct in this. But to be fair, the last set (set #2) had over 80K on them and were just beginning to lose their ability to hold all that weight. I am heavy at 3000 lbs on the rear axle.
    The 2nd set were spec'd for +500 lbs. with 3" of lift. I do feel it is properly bumped allowing the slightest negative (optically barely) at max flex.
    But the springs did have to work more than they should have because of the damping issue Brett mentioned. And of course, all the weight too.
    :rolleyes:
  4. Apr 21, 2020 at 7:50 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have a stock 96 front end, anything you'd like me to measure?
    mataco4wd[QUOTED] likes this.
  5. Apr 21, 2020 at 7:52 PM
    mataco4wd
    994wd
    @Gen1FTMFW ?
    Running Board Man likes this.
  6. Apr 21, 2020 at 7:59 PM
    Speedytech7
    One of yous
  7. Apr 21, 2020 at 7:59 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Don't need measurements really. Wouldn't mind a couple of pictures of the OEM 95-97 headlights/grill to compare to the conversions from @Madjik_Man and @mataco4wd.
  8. Apr 21, 2020 at 8:09 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That's the easy part. Lots of options for that part, common to do that for LT setups with 62-64'' long springs.
    Not common to do SUA for the stock geometrey. Which I don't think is possible anyways, you'd have to do a long shackle over the frame like any other LT kit so wouldn't really save you much.
    What, you're just gonna roll your eyes at me and not tell us how dem triples felt?????
  9. Apr 21, 2020 at 8:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    haha, there's a time and place for everything.
    I am looking forward to spending time around the campfire with you. :cheers:
  10. Apr 21, 2020 at 8:19 PM
    Speedytech7
    I can't wait a year or more, I must know now!
  11. Apr 21, 2020 at 8:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh fuck that noise. Spill the beans!!!!
    betterbuckleup likes this.
  12. Apr 22, 2020 at 6:57 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    It's in the cylinder next to that rag that @BartMaster1234 left in there. :deadhorse:
  13. Apr 22, 2020 at 7:48 AM
    lightnfast
    lightnfast Well-Known Member
    PDX
    2001 TRD SR5 XCLB
    Stuff and things
    Nice wall!
    Jebediah and riskadverb[QUOTED] like this.
  14. Apr 22, 2020 at 8:28 AM
    riskadverb
    riskadverb Active Member
    Josh
    Denver
    2004 Silver Tacoma TRD
    Dog stickers
    Thank you! very psyched to have it right now
    Jebediah likes this.
  15. Apr 22, 2020 at 9:00 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Excellent choice. Toyota missed the mark with the 98-00 front ends IMO.
  16. Apr 22, 2020 at 12:18 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have no idea what you’re talking about.
  17. Apr 22, 2020 at 12:40 PM
    Gen1FTMFW
    Probably just me, but I think it's:
    95.5-97 > 98-00 > 01-04
    For some reason, the 01-04 looks curvy and feminine to me.
    0xDEADBEEF likes this.
  18. Apr 22, 2020 at 12:41 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Maybe that’s why they’re so hawt
    chrslefty, BYJOSHCOOK, Blue92 and 9 others like this.
  19. Apr 22, 2020 at 12:41 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    To me the 98-00 front end looks bad only because of the stock bumper. I think it looks a hell of a lot better with something aftermarket.
    BYJOSHCOOK and 0xDEADBEEF like this.
  20. Apr 22, 2020 at 12:59 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    3rd gen bumper is FAR worse.
