  1. Apr 28, 2020 at 9:22 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    If you had my truck the spot welds just break themselves.
  2. Apr 28, 2020 at 9:26 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not a new idea.
    Heres how to get a proper ebrake: https://frontrangeoffroadfab.com/drotor-backing-plate-kit/
    Im still not super convinced disks are a big improvement on the rear of our trucks over the drums.
    Blue92, POSTacoMike and ToyotaDriver like this.
  3. Apr 28, 2020 at 9:33 AM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I'm not quite sure what I'm looking at. Does that drum brake go behind the rotor?
    While more braking performance would be great, the main reason I want to go with rotors in the back is so I can run a hydro hand brake.
  4. Apr 28, 2020 at 9:35 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    I’d definitely be interested to see how the two compare side by side in a stop test, but there are so many factors. My guess is that most people don’t have their drums properly adjusted which is why they think they’re not adequate. I’m betting once I finally get my tundra brake upgrade done, I’ll be more than happy with the stopping performance, especially on my 33’s
  5. Apr 28, 2020 at 9:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha that would be fun.
    Its a mini drum that runs on the inside of the rotor basically. I'm not 100% sure on compatibility.
    austinmtb[QUOTED] likes this.
  6. Apr 28, 2020 at 9:37 AM
    The gold standard
    The gold standard Well-Known Member
    Western mass
    Green 03 v6
    First off, I'm not much of a wheeler, don't go hard on anything besides long dirt roads. What's the advantage to this conversion?
    I've heard that rear drums are good for trucks in general bc the friction works well when stopping a loaded vehicle.
  7. Apr 28, 2020 at 9:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean if you think about it, technically, a drum brake has WAY more surface area for stopping. Why they have survived so long in trucks honestly.
    That said, disks dissipate heat way better. But most are racing around anyways..
    So not sure. TG sells a rear disk kit as well. https://trail-gear.com/brakes/144039-1-kittacoma-rear-disc-brake-kit.html
    Not sure its worth it though.
  8. Apr 28, 2020 at 9:39 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't really think there is much of an advantage personally. Why I don't think I'd do it. Although Austins idea of a hydraulic hand brake sound like a good time. But thats the only real reason I can see to do it.
    austinmtb likes this.
  9. Apr 28, 2020 at 9:39 AM
    austinmtb
    Austin
    Southern Oregon
    Huh, what an interesting idea.
    I'd probably just go with the e brake solution the guy making the kit I linked is making because those calipers have a built in e-brake.
  10. Apr 28, 2020 at 9:40 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It looked like a line lock to me though yes?
  11. Apr 28, 2020 at 9:45 AM
    austinmtb
    Austin
    Southern Oregon
    It looks to me like a cable system that ties into the factory e-brake handle.
    Those calipers have a cable attachment for an e-brake built into them.
    Blackdawg[QUOTED] likes this.
  12. Apr 28, 2020 at 9:47 AM
    ToyotaDriver
    Idaho
    True. I’m not convince that the expanding force of shoes on a drum is more effective than the clamping force of pads on a disk. Especially when they get hot. My uncle had an OOOOLLLLDDD Dodge of some sort when I was a little kid, and I remember him talking about how scary having drum brakes all around was in the Sierras. It was lifted with monster tires on it. I was like 4, so I have no idea what the thing actually was.
    EDIT: That said, semis still use drum brakes..... Soooo...??
    I’m not convinced the trail gear kit is worth it. I definitely want a functioning ebrake. Most weekends that I get out on forrest service roads, I cruise in first gear and pick up trash along the way. Some times I only make it 20-30 feet before I spot another beer can in the ditch and have to get out. I feel like a line lock would be really annoying doing that all the time.
  13. Apr 28, 2020 at 9:58 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah so it's a mechanical connection and actuation. That's cool. Maybe I'll get a set too to try. Could be fun on the future turbo SX. But the hydro slide lever sounds fun haha
    Well sure but old as drums are scary haha new ones are quite the improvement.
    And yes semis use huge drums. Like I said, way way more surface area of clamping force.
    The heat dissipation is the big gain from discs. Unless you get huuuuge disks of course. So idk. Some one smarter than me probably know's the real answer.
  14. Apr 28, 2020 at 10:01 AM
    ToyotaDriver
    Idaho
    True. I suppose I was comparing apples to oranges there.
  15. Apr 28, 2020 at 10:03 AM
    austinmtb
    Austin
    Southern Oregon
    Hell yeah it does :burnrubber:
  16. Apr 28, 2020 at 10:03 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha yeah. Im sure there are ways to calculate it all but will depend on the caliper size and piston count. Plus gobs of other variables.
  17. Apr 28, 2020 at 10:06 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  18. Apr 28, 2020 at 10:19 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Is that a spacer/bracket for the 6.5? Where'd ya get that?
  19. Apr 28, 2020 at 10:26 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    So not really what I've done "today"... more like over the past 30 days during a 30 day hiatus from TW.
    But let's get ya'll catched up :wink:
    Got the garage cleared out again
    Did some regear 3rd swappin on @MattJakobs runner
  20. Apr 28, 2020 at 10:26 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Did some maintenance on my truck
    cruiserguy, SwampYota and POSTacoMike like this.
