  1. Sep 2, 2012 at 11:13 AM
    scocar
    scocar hypotenoper
    :notsure: can't see them. Take a better pic so we can behold their glory.
  2. Sep 2, 2012 at 2:44 PM
    anthonywilk
    anthonywilk Active Member
    Anthony
    Canada
    2008 TRD sport
    3'' toytec lift, SCS Stealth 6 rims, 285\70\17 Kelly Safari tsr
    dont really have a great pic but i hope this one is better, just out for some sunday evening flexin
  3. Sep 2, 2012 at 3:30 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Extended my rear diff breather up to the plastic shroud around the gas filler and installed an extended rear brake line I've had sitting around since 2005 :D Also installed an aluminum BPV bracket, made it myself :eek:
  4. Sep 2, 2012 at 4:12 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    Got rid of the brake light ans ABS light today. tweaked around with the e brake line. Then cleaned the ABS module connector and topped off the brake fluid.
  5. Sep 2, 2012 at 4:23 PM
    Iceman2448
    Iceman2448 Well-Known Member
    Ga
    5100 OME 3" front lift 1.5 rear All Injen cold air Intake N-Fab light bar Hella 500FF lights Alpine Heand unit Type R 10 sub r500.1 amp Alpine 6x8 comps up front Alpine 6x9 in rear
    Went to Meatman's house and helped him mount and wire up his new switches. ImageUploadedByTapatalk1346628125.153995.jpgImageUploadedByTapatalk1346628149.805783.jpgImageUploadedByTapatalk1346628175.037851.jpg
  6. Sep 2, 2012 at 6:28 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Cleaned the throttle body and maf sensor. Washed the outside, cleaned the interior with armor all and vacuumed. Its a happy taco now :)
  7. Sep 2, 2012 at 6:32 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    All I could do today was sit and stare at my little Taco. :p
    Can't work on it until me and my best friend are done building his garage, because that's where we'll be doing the tear-down.
    Can't wait to work on this sucker!
  8. Sep 2, 2012 at 6:35 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    does anyone know if there is a seal kit for the rack and pinion? I have found my leak.
  9. Sep 2, 2012 at 6:42 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I finally have more clearance for the curbs at the mall!
    put on these bad boys yesterday:
    [​IMG][​IMG]
  10. Sep 2, 2012 at 6:46 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
  11. Sep 2, 2012 at 6:50 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  12. Sep 2, 2012 at 7:01 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    I had to get new bushings when I got my ailment done back in DEC. Glad I found the leak.
  13. Sep 2, 2012 at 7:11 PM
    Madjik_Man
    Colorado Front Range
    Where'd you (or he) get that switch plate?
  14. Sep 2, 2012 at 7:12 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    That is a pretty sweet switch bank.
  15. Sep 2, 2012 at 7:22 PM
    Quirk
    Quirk Member
    Mark
    Louisville
    98 Tacoma
    On my '98 Tacoma I changed all the lug nuts. Now they match. Yeah I had to have 'em match. I got chrome acorn nuts. And I added some trim rings. It looks really good. At least I love it.
  16. Sep 2, 2012 at 7:41 PM
    Iceman2448
    Ga
    We made it out a black plastic
  17. Sep 2, 2012 at 7:43 PM
    Iceman2448
    Ga
    Thanks man I think it turned out great myself
  18. Sep 2, 2012 at 7:55 PM
    04tacomaSR5
    04tacomaSR5 Proud Canadian
    British Columbia, Canada
    2005 Tacoma TRD Sport 4x4
    Toyota hard tonneau cover, custom seat covers, nerf bars, more to come...
    how did you mount the switch plate in that area under the deck so that it wouldn't push in/ pop out?
  19. Sep 2, 2012 at 8:47 PM
    Hoyle
    Hoyle Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    Check engine light was on, when to Autozone, they hooked up meter and checked my code. Front 02 Sensor, they wanted $189.00 for new one.. Dont' think so, came back to this forum, found http://www.rockauto.com/ for $80 ... duh.. same Denso part!... replaced Sensor, Nuts came right off after 11 years...
    Went back to Autozone, they reset my code... No more Check Engine..
    Sweet!
  20. Sep 2, 2012 at 9:13 PM
    Iceman2448
    Ga
    I took the pocket faceplate off and if you've ever notice that the radio dash trim has a notch around the radio opening. Well I made the panel fit that notch and the pocket holds it in tight. I'll post up more pic tomorrow as I do mine.
