  1. May 10, 2020 at 9:41 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    you forgot about the pointless bickering about stage 2.
    aka stage 3
    turbodb, Bridge4, nagorb and 2 others like this.
  2. May 10, 2020 at 9:53 PM
    eon_blue
    Azusa, CA
    They're good for keeping your intake temps lower too. Out here where it gets really hot a good part of the year, every little bit counts (especially when you're boosted).
  3. May 10, 2020 at 10:09 PM
    Arman Bagdasarov
    Arman Bagdasarov armbag
    2001 4x4 Tacoma
    Camburg UCA, King coil overs, Fox Shox, Deaver springs, BAMF sliders & LCA Skids, Relentless Skids. Lights on lights on lights
    what kind of clips did you use?
  4. May 10, 2020 at 10:28 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Well shit, I'll try to take the next step.
    Don't plug the drain holes in your air box. Why cause they're fucking drain holes.
    m3bassman[QUOTED] likes this.
  5. May 10, 2020 at 10:30 PM
    Empty_Lord
    Dan
    They become fill holes if you ever flip the truck over!
  6. May 10, 2020 at 11:01 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Does that mean breather tubes become suction tubes?
  7. May 10, 2020 at 11:01 PM
    Empty_Lord
    Dan
    You know it!
    nagorb[QUOTED] likes this.
  8. May 11, 2020 at 4:43 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    A little bit of water in your intake isn't the end of the world. I've yet to notice any pooling of water in my custom airbox. You sit there stuck in a water hole. While you're gathering recovery gear and such those little holes are filling up. After a certain amount of time your engine will begin drinking water. Just my two cents.
    I don't recommend going through water that deep to begin with but shit happens...
    nagorb and El Taco Diablo like this.
  9. May 11, 2020 at 6:37 AM
    1997tacomav6
    Denver
  10. May 11, 2020 at 7:07 AM
    Arman Bagdasarov
    2001 4x4 Tacoma
  11. May 11, 2020 at 7:19 AM
    1997tacomav6
    Denver
    U bet, it took 5 weeks for mine to be delivered, so as long as your good with that they are worth the wait
  12. May 11, 2020 at 7:35 AM
    Arman Bagdasarov
    2001 4x4 Tacoma
    actually just ordered the clips lol, gonna make my own skirt
    1997tacomav6[QUOTED] likes this.
  13. May 11, 2020 at 7:48 AM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Ordered some 285/70r17 6-ply Toyo AT3 today. Going to pick up some 17" wheels today and I should be able to get them put on tomorrow.
    Bridge4 and 2002Tacoma4x4 like this.
  14. May 11, 2020 at 8:47 AM
    RDT415
    RDT415 DUCTACO
    Sonoma County
    23 TRD Pro 6MT / past 04 DCSB 4WD
  15. May 11, 2020 at 9:23 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Considering you have negative pressure in the air box. And the drain holes are at the bottom of the air box. Making the drain holes (now the lowest point in the intake system) the first place water would enter your air box, with negative pressure sucking air (and water) through the drain holes.
    If you have done an adequate job of sealing the rest of your intake system, where you have taken steps to keep water from entering your intake... I'm not really sure why you would keep the drain holes. For the water that shouldn't be in the system to begin with... to get back out.
    Fernando likes this.
  16. May 11, 2020 at 10:36 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    And sometimes bad shit happens next! Water will not compress!
  17. May 11, 2020 at 2:02 PM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Today decision of changing rims has been done.
    I have these 4 Runner Rims in good condition about to place them for sale soon.
    Do you think $350 for 4 of these with 7 central caps and the 24 lug nuts is a good price ?
    Area51Runner likes this.
  18. May 11, 2020 at 2:09 PM
    eon_blue
    Azusa, CA
    @Area51Runner collects these rims, he might know
  19. May 11, 2020 at 2:42 PM
    Balockay
    Blake
    Cleburne, TX
    Also ordered some Method MR305. They'll be here later in the week but hopefully I can get it all put on Friday. Thne I'll crank the new coilovers up and get an alignment to determine if I'll need to run Spidertrax.
    2002Tacoma4x4 likes this.
  20. May 11, 2020 at 2:43 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    lol Ryan. I have a set on the truck now and picked up another to refinish in white. Not a collector by any means... A collector would be someone who has a lamp from a silo on the wall of their garage :boink:
    cruiserguy and eon_blue[QUOTED] like this.
