  1. May 12, 2020 at 4:11 PM
    eon_blue
    Azusa, CA
    OEM. I haven't had luck with aftermarket brands when I had to replace one. Finally just picked up a used OEM one from someone on here that was parting out their truck. The aftermarket ones shake/rattle way too much
    2002Tacoma4x4 likes this.
  2. May 12, 2020 at 4:22 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Love the 'action' shots of the press:D we don't get to see many pics of presses in here. Not too common of a garage tool for most. I dig your setup.
    And that tool you fabbed looks like the bees knees:cool: or maybe the cat's meow, if you prefer :D:rofl:
  3. May 12, 2020 at 4:28 PM
    cmj
    cmj Well-Known Member
    Tucson
    98 Tacoma 4x4
    They're pretty old
    Gotta have a press! Harbor freight is the defacto standard.. they're cheap as hell and incredibly useful. I think I bought mine for $150
  4. May 12, 2020 at 4:29 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    That's what I figured
  5. May 12, 2020 at 5:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That is an older design Sway-A-Way Racerunner 2.0 coilover by the look of it. With the pre-load adjuster on the bottom. They originally came with red powder coated coils IIRC.
  6. May 12, 2020 at 5:25 PM
    eon_blue
    Azusa, CA
    Even the used OEM one I got shakes a bit. I'm sure there's a way to open the case up and tighten it down I just haven't looked into it yet.
  7. May 12, 2020 at 5:29 PM
    cmj
    Tucson
    98 Tacoma 4x4
    That all checks. Original coils were red and 675lb. I didn’t know that and bought 650 lb springs because the red ones deformed a little and 650 was the stiffest I could find at the time. They were way too soft so I just bought some 700’s
  8. May 12, 2020 at 7:07 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Finally getting around to painting the cap I found at the pick-n-pull
  9. May 12, 2020 at 7:12 PM
    1997tacomav6
    Denver
    Probably the fan bracket bearing unless it’s been changed out before,
    But the AC idler pulley goes out a lot
  10. May 12, 2020 at 7:15 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Had two different painters quote painting mine last week, one was $400, one was $200.
    CrustyTaco likes this.
  11. May 12, 2020 at 7:28 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Welcome back.
  12. May 12, 2020 at 7:34 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Hard to believe either one of them. It was $200+ in paint supplies alone.
  13. May 12, 2020 at 7:48 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Good to see you on here again Jon!
    Empty_Lord and 45acp[QUOTED] like this.
  14. May 12, 2020 at 8:42 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I paid 250 to have my 8ft cap painted. Cake out great. Body shops love caps (at least mine did) because preps easy
  15. May 12, 2020 at 8:55 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Made some progress on my aux fuse block tonight. 96256BC1-296D-43FE-B284-C44EA92B8DB6.jpg5A2B0D62-3033-47E1-8ED6-5EC22489F01B.jpg
  16. May 12, 2020 at 9:29 PM
    esxcli
    esxcli Keyboard Warrior
    Sean
    Reno NV
    Great for u joints, ball joints, bearings, gear swaps, and taco gussets!
    GQ7227 likes this.
  17. May 12, 2020 at 9:46 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Whaaat. Prep was horrible in this case Multiple layers of old paint to sand off. I suppose it's easy when you have a sand blasting area. I sometimes wonder where they cut corners. As was the case with my Honda Fit's rear bumper when the clear coat began peeling after a year or so because of improper prep.
    Bridge4 and Empty_Lord[QUOTED] like this.
  18. May 12, 2020 at 9:51 PM
    Empty_Lord
    Dan
    is your cap fiberglass or no?
    45acp[QUOTED] and 2002Tacoma4x4 like this.
  19. May 13, 2020 at 3:11 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The guy who quoted me $200, I told him I’d take all the windows out. I need to reseal them anyway.
  20. May 13, 2020 at 9:28 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I like this setup a lot. Might copy it. Could you retain the tailgate now that it's moved back?
    Loving your progress dude. Waiting for work to get slow so I can read back on your thread.
    Kinda my same mentality.
    Did some wheeling/camping last weekend.
    Destroyed my valve stem and tested my Colby valve for the for the first time, was a fan of how well it worked and how easy it was to install.
