  1. Jun 2, 2020 at 10:10 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Yea I suppose that could work too. Yea it's a 2000. I'll do some poking around.
    Thanks for the input!
    Welcome to TW btw!
  2. Jun 2, 2020 at 10:56 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I started one side then used a pic to pull around it and up over the edge. Piece of cake.
    nagorb and Captain Magma[QUOTED] like this.
  3. Jun 3, 2020 at 4:23 AM
    Cattywampus
    Cattywampus Splitter of CV Boots
    Mark
    Colorado
    '03 Tacoma DC TRD OR
    Started a rust treatment/prevention project over the weekend. Starting with inside of the boxed portions of the frame. I drilled a 1" hole near the rear wheel well on both frame rails to allow for drainage and rust chucks that used to be my frame to fall out. I jacked up the front end to slope the frame back towards the drain hole. I cleaned and removed as much rust as possible from the inside of the frame by using a power washer through all the openings in the frame. In the third photo you can see a sample of what fell out under the drain hole when washing. Next step, Eastwood internal frame coating. To be continued....
  4. Jun 3, 2020 at 6:40 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I always wondered about this argument. I mean the most it could possibly weigh is based on how many cans of the stuff you use right, not a whole lot. Plus I believe it is thinned before spraying, so even less.
    ToyotaDriver and nagorb like this.
  5. Jun 3, 2020 at 6:51 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Pretty much depends on how many coats of the 1000g mix you use.
    ToyotaDriver likes this.
  6. Jun 3, 2020 at 7:54 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Couldn’t you just weigh the cans before and after. Whatever you used should be pretty close to how much stuck to the truck. How much do the cans weigh anyway, 10lbs, 20lbs?
  7. Jun 3, 2020 at 8:17 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Is the dry weight different than the wet weight?
  8. Jun 3, 2020 at 8:18 AM
    Madjik_Man
    Colorado Front Range
    Yeah I don’t think it adds too much weight at all if applied correctly.
    But TW is a wealth of great information and data. Figured this would just add to it.
  9. Jun 3, 2020 at 8:20 AM
    Madjik_Man
    That would probably work. I’m not a physicist but I’d imagine the dry weight would be lighter than the wet weight after it cures.
  10. Jun 3, 2020 at 8:20 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    This thread in particular is detrimental to my wallet. I get so many good-bad ideas from here!
    Ant4x4 likes this.
  11. Jun 3, 2020 at 8:36 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Removed crunchy things. Installed new, non-crunchy ones.
    DLtaco02, BeLance89, kuntry09 and 8 others like this.
  12. Jun 3, 2020 at 8:38 AM
    RattleTractor
    Harry
    VT
    While the truck was parked and waiting for those new coilovers, I also removed the bed and did some rust mitigation procedures. IMG_8720.jpg IMG_8719.jpg
    BeLance89, megalodon, Tour991 and 4 others like this.
  13. Jun 3, 2020 at 8:48 AM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    Wow those old ones were crunchy. Looking good man
    Taco critter likes this.
  14. Jun 3, 2020 at 8:55 AM
    RattleTractor
    Harry
    VT
    ...and this was a Utah truck for most of its' life! The previous owners built it to be used, then promptly did so quite a lot.
  15. Jun 3, 2020 at 8:56 AM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    You aren't lying about the heat. It's awful.
    Hopefully it cools down a bit this weekend:fingerscrossed:
    betterbuckleup likes this.
  16. Jun 3, 2020 at 8:58 AM
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Please... I'd trade you weather in a heart beat :) It's all relative :bananadead:
    DLtaco02 likes this.
  17. Jun 3, 2020 at 10:16 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Suppose to be 102 today :bananadead::bananadead:
  18. Jun 3, 2020 at 10:57 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Gallon cans are 8.8 lbs, although the tintable comes in 28 oz bottles, you add 8.3 oz of hardener, 3 oz. of tint. It can be reduced by as much as 20%. The bottles go right on the gun. I purchased an 8 bottle kit (more or less 2 gallons). I also got two bottles of black for flares and bumpers, and bed (if I have enough) I run a liner, so if I don't have enough, no worries.
    I saw some outrageous number for the weight for a square foot of liner, on one of the manufacturers web sites, something like a pound and a half per sq ft. When I saw it, I thought that they must have been off by a factor of 10 (or more). But I couldn't quickly find the reference when I searched again.
    osterhagen likes this.
  19. Jun 3, 2020 at 11:13 AM
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    3C8D9589-6F3C-4D3B-935A-F867788EEE2B.jpg Done....now just the install
    DLtaco02, Rldanie, BeLance89 and 7 others like this.
  20. Jun 3, 2020 at 12:43 PM
    1997tacomav6
    Denver
    Got the valve covers back from the painter today, :)
    Came out sweet!,,
    100.00 well spent
    Winkle99, DLtaco02, Rldanie and 11 others like this.
