  1. Jun 9, 2020 at 9:58 AM
    Cattywampus
    Cattywampus Splitter of CV Boots
    Mark
    Colorado
    '03 Tacoma DC TRD OR
    First coat of Chassis Saver on. Clearly I'm not sure what to do with the leafs, debating whether to paint them or not. I'm probably not the only person on this forum that gets a bit carried away with the "while I'm in here I should... ". Second coat later and then top coating the areas that will get the most UV exposure and see the most debris (wheel wheel area, leaf mounts, etc).
  2. Jun 9, 2020 at 10:44 AM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    Nope not the only one. I'll have half my damn truck rebuilt before this manual swap and 4x4 conversion are done. But come on, when will you ever have an easier time to change the steering rack with no trans or front 4x4 stuff in the way? Re-sealed the oil pan for the same reason!
    nagorb likes this.
  3. Jun 9, 2020 at 10:53 AM
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Speaking of a while you're in there situation... this happened...
    Installing a CBI ditch bracket. Took out all the front end bits between swap over to wire wheel and paint. Got new skirts, rubber coating for the under fender and what not. Should come out looking nice and fresh... once all the parts arrive.
  4. Jun 9, 2020 at 11:19 AM
    Cattywampus
    Mark
    Colorado
    Haha definitely been there. Projects that should have taken a couple of days turns into weeks of waiting for parts that I didn't need, refinishing the whole area, cleaning, etc. Oh well. That's why you have a backup car so you can keep working on the truck.
  5. Jun 9, 2020 at 11:52 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    I have a set of those for sale now... someone says they will pick up on weekend $220 with lug nuts, caps and OEM skid plates
  6. Jun 9, 2020 at 12:02 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Fly me out
  7. Jun 9, 2020 at 12:24 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    na. I can fix it,
    If I can find r22
  8. Jun 9, 2020 at 12:35 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I can just buy it lol
  9. Jun 9, 2020 at 2:15 PM
    Empty_Lord
    Dan
    Wait what? I was told no more r22 residential since January 1st... commercial different?
  10. Jun 9, 2020 at 2:26 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    Well no pics or videos but I did the “proper head light upgrade” today. I believe that’s crashnburns thread?
    Also did a baseline dyno run. After three runs, averaged around 180hp and 200 torque at the wheels. Since I finally rebuilt the front end and replaced the rear leafs, I’m finally starting on the drivetrain.
  11. Jun 9, 2020 at 2:41 PM
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    A76AF0FE-138A-4CBD-AA27-7AE8D8FCFF40.jpg HID retrofit with Blacked our housing + Smoked corner light (but left amber marker) + smoked turn signal....added LED flasher relay and added some super bright turn signal and corner light bulbs
    SwampYota likes this.
  12. Jun 9, 2020 at 2:45 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Me as well. Day long jobs take anywhere from a day to a week, and it goes up from there on longer jobs. Plus I clean the crap out of everything when I pull it apart, and remove rust and paint and do whatever else since I'm in there. Last time my truck was down for a week, it took two months. Though part of that was because I found issues that had to be addressed, water found its way in and ants took up residence...
    osterhagen[QUOTED] likes this.
  13. Jun 9, 2020 at 3:35 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    They don’t make new units with 22. But you can still buy it. But they don’t make new22. Its all old stock or recycled 22. Like 500$ a bottle though.
    we still have stores that are all 22. Some of them have like 400lb+
  14. Jun 9, 2020 at 4:46 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    What's this empty plug attached to the MAF harness? About to give it a nip.
  15. Jun 9, 2020 at 6:01 PM
    MuddyBeaver
    MuddyBeaver Active Member
    2002 Red Tacoma Ext Cab TRD
    Bought Bone Stock 05/02/2017
    Just made a post on how I did the radio-climate control swap. Go check it out let me know what you think.
    Grimm30, Ace115, Rldanie and 9 others like this.
  16. Jun 9, 2020 at 6:06 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    - Burnt valve replaced
    - Head serviced and surfaced
    - New valve seals
    - New injectors
    - New cooling hoses
    - New water pump
    - Other misc things.
    It idles high, and you can hear it try to idle down at a stoplight, but it nearly dies each time. I suspect there's crud in the IAC valve.
    First start (on the first try):
    https://youtu.be/3ozAtC_J6nk?t=29
    ireymon, osterhagen, aroma and 5 others like this.
  17. Jun 9, 2020 at 6:17 PM
    1997tacomav6
    Denver
    I got mine off https://www.car-part.com/mobile/index.htm,
    They cut the main section out of the hood and was around 150.00 shipped
  18. Jun 9, 2020 at 6:17 PM
    Empty_Lord
    Dan
    Empty plug? I think it’s something for electrical noise to the sensors
  19. Jun 9, 2020 at 6:20 PM
    Reh5108
    Idaho
    I pulled the cap off and there's no continuity to it. I roasted one of the wires feeding it. I'm not seeing a blk/red wire and brn combo on the schematic I have.
  20. Jun 9, 2020 at 6:41 PM
    Empty_Lord
    Dan
    I wouldn’t worry about it then
