  1. Jun 9, 2020 at 6:58 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Spent most of the day getting the rear corner, lower side of my bed straightened out. It wasn't much of a bend, just looked like the PO had gotten against a tree. But that corner is almost completely blocked off with bracing. I was working with hammer and dollies, but no spoons. About half way through, I would have sold my soul for someone to weld some pins on and use a slide hammer. In the end, I got it reasonably close, enough, to give it a skim of bondo and call it good. Funny thing is that for the most part this area is hidden by the wrap around on my NWTI bumper.
    osterhagen likes this.
  2. Jun 9, 2020 at 7:28 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I feel like 70% of the time after I work on my 3rz, I end up with a high idle after.
    So far it's been due to vacuum lines and my throttle body. I went a little too gung-ho when I cleaned the throttle body one time and cleaned away that coating on either side of the butterfly valve which allowed too much air to escape by. Remedied that by buying a used throttle body off ebay.
    0xDEADBEEF[QUOTED] likes this.
  3. Jun 9, 2020 at 7:40 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    Great write, way too much work for my taste. Looks great though
  4. Jun 9, 2020 at 7:40 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Yeah I specifically didn't clean the throttle body, hoping to avoid this. All my vacuum lines are new and in the right place, so I'm thinking I washed some crud into the IAC. Easy enough fix.
    nagorb and HarborSeal like this.
  5. Jun 9, 2020 at 7:55 PM
    Phessor
    Phessor Well-Known Member
    First step in the spindle rebuild project.
  6. Jun 9, 2020 at 7:58 PM
    HarborSeal
    HarborSeal Well-Known Member
    96 taco, 84 4 runner
    lce headers, ome suspension,
    cleaned my maf, new air filter, replaced some cracked vacuum lines, and then tried to solve the weird rattle i have at low RPMS. I thought the heat shield might just be loose or cracked, but then all the bolts sheared off when i went to try and take the heat shield off. Turns out my exhaust manifold has a huge crack in it! I suspect that is what is causing noise when my rpms drop. Oh well, I guess I HAVE to get some LCE headers I had been eyeing.
    GQ7227 and SwampYota like this.
  7. Jun 9, 2020 at 9:03 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    yup... that'll cause a rattle like noise.
    time for some 01-04 mini headers or w/e they call them (better design)
  8. Jun 10, 2020 at 4:15 AM
    Running Board Man
    Running Board Man Well-Known Member
    Good to know
  9. Jun 10, 2020 at 4:49 AM
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    CFE858F6-805C-460C-9C63-2E6630EF453D.jpg AA2CAC79-58D0-4943-B51F-B0CADB6DEAB6.jpg Added some miles to it. Crossed 66000...lol
  10. Jun 10, 2020 at 6:02 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :brianr:
    I just hit 240k:pout:
    But she still gets it! :burnrubber:
    GQ7227 and Silver02Taco like this.
  11. Jun 10, 2020 at 7:18 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Joined the 300K Club on the way to work today.
    GQ7227, 0xDEADBEEF, Fernando and 8 others like this.
  12. Jun 10, 2020 at 7:51 AM
    Grimm30
    Grimm30 Well-Known Member
    Kody
    Ventura, CA
    04 Tacoma 3.4l MT 4x4 Limited
    Wow, that looks so much better. Might have to try that out myself.
  13. Jun 10, 2020 at 9:05 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Man that looks awesome. But too much work for me.
  14. Jun 10, 2020 at 9:43 AM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    I should have pulled the fender when I did mine. I have a bunch of broken clips and stuff that rattle like crazy, would have been a good time to freshen it up. Plus, I peeled mine back too far when installing the ditch brackets and have a beautiful panel gap between the hood and drivers fender. Can almost fit my finger in it lol.
    osterhagen[QUOTED] likes this.
  15. Jun 10, 2020 at 12:29 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    B-R is power from the ignition circuit AM2 fuse
    BR is ground
    It's on the same circuit as the ignition coils
    See attached schematic.
  16. Jun 10, 2020 at 1:25 PM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    Ouch man, that is horrible. Yeah they are kind of a pain to install but I really like where the light ends up.
    Speaking of a while you're in there situation again... replacing my steering rack and I've been wanting to add a power steering cooler. So seems how I have it all disconnected and drained with the steering rack off, why not get one installed. Arrived from the Amazon overlords today. Gonna install it this evening after work hopefully!
    crawling around the AZ desert soon and hope this will help keep my components safe cause the shit that came out smelled like death and could tell it had gotten warm. Smelled burned/hot or whatever.
    nagorb, SwampYota and jubei like this.
  17. Jun 10, 2020 at 1:45 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Told the wife wanted to buy another Tacoma. She wasn’t happy and said I need to pay what I owed for mine . So I payed it off Today! Title is in the mail. I told here I paid it off and she’s still red hot about it. Maybe I have a crunchy taco problem.
  18. Jun 10, 2020 at 1:47 PM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    2025 SR5 4x4
    What have you had to do to keep her running so well for so long? That's quite an achievement.
  19. Jun 10, 2020 at 3:00 PM
    vonellis
    Some and some more
    O Dam! Nail in tire needed new shoes anyways. loosing the street slicks. image.jpg
  20. Jun 10, 2020 at 3:23 PM
    Joey_Bada_Bing
    Joey_Bada_Bing Well-Known Member
    North Carolina
    1st Gen DC 4WD
    A bunch of the same stuff everybody else has already done.
    Got my 3rd Gen 4runner wheels mounted up and installed! Went white letter out This time so they are a bit dirty right now but you get the idea...
