  1. Jun 16, 2020 at 8:54 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lol well okay but techically I was right :p even in the title haha
    nagorb[QUOTED] and Empty_Lord like this.
  2. Jun 16, 2020 at 8:56 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    No. We're talking machining, so I was right. But yeah it gets confusing, after you posted I had to think for a second, even though I use those terms everyday.....
    cruiserguy likes this.
  3. Jun 16, 2020 at 9:04 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    That’s bad ass
    Digiratus[QUOTED] likes this.
  4. Jun 16, 2020 at 9:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Naw, this is just fun stuff. Now regearing Toyota diffs, that is badass. :cool:
    Yetimetchkangmi likes this.
  5. Jun 16, 2020 at 9:08 PM
    ToyotaDriver
    Idaho
    Well, I’m going to try it with my front end to get it close and see if it saves me some headache. Will let you know how it goes.
    nagorb[QUOTED] likes this.
  6. Jun 16, 2020 at 9:09 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Where are all the cracks on your core support? :confused:
  7. Jun 16, 2020 at 9:10 PM
    ToyotaDriver
    Idaho
    Ha! :hattip:I’ll be stealing this idea for my cracked out washer reservoir.
  8. Jun 16, 2020 at 9:13 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Well, after grabbing a second gauge set since the first HF set wouldn't hold pressure... Then grabbing a second evap core since the first OEM one I got from Toyota (for $270) wouldn't hold pressure, it looks like the second gauge set and second core are going to work just fine.
    Holding good vac for >30 minutes.
    jubei, SwampYota, mechanicjon and 3 others like this.
  9. Jun 16, 2020 at 9:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :notsure: I guess I'm not wheeling hard enough. :rolleyes:
    Madjik_Man likes this.
  10. Jun 16, 2020 at 9:14 PM
    Squeaky Penguin
    Brett
    Not even around the body mounts? I'm impressed.
    Stock rubber body mounts? Guessing the poly mounts are a contributing factor.
  11. Jun 16, 2020 at 9:16 PM
    Madjik_Man
    Colorado Front Range
    dafuq is this bassackwards bowshite?
  12. Jun 16, 2020 at 9:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    They are still originals but they are certainly allowing a lot of movement these days. Sounds like you don't recommend poly replacements.
  13. Jun 16, 2020 at 9:19 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    With age comes restraint and better decisions.
    At least, that's what I've been told.
    Squeaky Penguin likes this.
  14. Jun 16, 2020 at 9:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ha. Whens that supposed to kick in? :p
  15. Jun 16, 2020 at 9:22 PM
    Squeaky Penguin
    Brett
    I don't know what to recommend any more. My truck is not a good judge.
    jubei and Dan8906 like this.
  16. Jun 16, 2020 at 9:23 PM
    ToyotaDriver
    Idaho
    :burnrubber: Apparently I’m not there yet.
    nagorb likes this.
  17. Jun 16, 2020 at 9:24 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Not sure what you mean? That's how you PROPERLY read decimals. Did your math teacher teach you different? Well they're wrong.
    If you base the readings off of .001 that is. Which is why that is done in machining.
    jubei and Speedytech7 like this.
  18. Jun 16, 2020 at 9:25 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Machinists refer to ten thousandths as tenths. This is common to refer to the .0001, but as you've demonstrated here, normal folk don't get it haha
  19. Jun 16, 2020 at 9:28 PM
    Speedytech7
    Being a machinist is hard on my brain, I constantly have to translate logical things to completely illogical nonsense for the sake of a customer's understanding.
    six5crèéd, Wulf and nagorb[QUOTED] like this.
  20. Jun 16, 2020 at 9:31 PM
    Speedytech7
    It's a bellcurve, so watch your actions and never count on experience entirely or you risk becoming blind to new things ;)
    mechanicjon, Wulf and ToyotaDriver like this.
