  1. Jun 25, 2020 at 11:08 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Can confirm.
    osterhagen likes this.
  2. Jun 25, 2020 at 11:13 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    No
  3. Jun 25, 2020 at 11:14 AM
    eon_blue
    Azusa, CA
    sounds like you could use a tune up then and the fuel filter is easy to do on the V6. New spark plugs/wires, fuel filter, air filter, clean the MAF, etc.
    JKO1998[QUOTED] likes this.
  4. Jun 25, 2020 at 11:15 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I always though of it like the farm States where the government pays you to farm. Except with meth.
  5. Jun 25, 2020 at 11:15 AM
    JKO1998
    Utah
    Dumping money into this bitch the last few days
  6. Jun 25, 2020 at 11:16 AM
    eon_blue
    Azusa, CA
    I've felt that way the last few years
  7. Jun 25, 2020 at 11:49 AM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    I installed mine by myself...but I did have a transmission floor jack, which really made it a breeze. Just took it slow and adjusted the angles on the jack plate and she lined up... bit of a jiggle back and forth and she was close enough to start all the bolts and sucked right in after. That being said, I put the transfer case on after which I wager makes a big difference also.
    With the right tools, patience and proper lubrication (for the mechanic), I'd say you should be fine. You should have seen me install the front diff alone, looked quite silly I'd recon but we got it done!
  8. Jun 25, 2020 at 11:51 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
  9. Jun 25, 2020 at 12:02 PM
    GoJo
    GoJo Well-Known Member
    Utah
    is this on your 02? If so, maybe check this out: https://www.tacomaworld.com/threads/bad-throttle-lag.163262/page-2 post #21
    My 03 auto has done similar to what you describe and I have to do this at least once or twice a year to get it to go away. I also had a coil go bad as well at one point, took about a week for that to get bad enough to through a CEL to scan
  10. Jun 25, 2020 at 12:24 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Same here in North Idaho and Eastern WA, not a single redeeming quality. Just methh and broken dreams
  11. Jun 25, 2020 at 12:55 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Chock full
  12. Jun 25, 2020 at 2:01 PM
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Hey maybe a chuck full is equivalent to a butt load :D:rofl:
    High Noon likes this.
  13. Jun 25, 2020 at 2:04 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Man I really like what you have going on here. When my AT goes I’ll be going manual for sure. If you ever need a hand or don’t mind someone being nosey about your build, I’d like to see it 1st hand in progress.
    Speedytech7 likes this.
  14. Jun 25, 2020 at 2:52 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    It's true
    Yes they are, trust me it's true. I was there once, on hippie Hill, before heroine Hill.
    BeLance89 likes this.
  15. Jun 25, 2020 at 2:52 PM
    Madjik_Man
    Colorado Front Range
    I unfortunately have XL size hands. Always wish I had baby hands at the end of Manute Bol arms (when working on the truck or car).
    Captain Magma, High Noon and nagorb like this.
  16. Jun 25, 2020 at 2:53 PM
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    If you have any, some of that electrical connections cleaner works wonders for that stuff. I mean depends on how bad it is to start with. But I've had luck with being liberal with that and a nylon brush / pipe cleaner for about 2 mins and then can get the connection off.
    Also if you have a 90 degree pick tool, using that to put more direct pressure on the tab that releases it often is a game changer.
    m3bassman likes this.
  17. Jun 25, 2020 at 2:55 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I've got short fat arms/hands. Perfect for rough tasks, terrible for tight spaces. When I swapped mine luckily a buddie stopped by with long skinny arms, he made short work of all the connections above the trans. I did the grunt work pulling it.
    High Noon and Madjik_Man[QUOTED] like this.
  18. Jun 25, 2020 at 2:56 PM
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Not at all mate, it just struck me as funny. As long as people can understand what you're getting at, that's all that matters IMO. I have a very corporate job and have to be proper all day at work, not fussed about shit here lol.
    Fingers crossed for ya man, hope you can get those disconnected!
  19. Jun 25, 2020 at 3:01 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    You know everything and Got the world figured out. I can tell. :facepalm:
  20. Jun 25, 2020 at 3:03 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I thought it was clear I was joking.
    Plus he knows I'm from there...
