  1. Jul 4, 2020 at 6:44 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    No, I was trying to put back in the same bolts that I removed from my original bed, and on the replacement, two of the welded nuts seem to have been wallowed or drilled out. I got a nut one the one closest to the cab, but gave up one the middle one, no way to get a nut in there without drilling out a hole in the floor of the bed and going down from the top.
  2. Jul 4, 2020 at 6:45 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Electric fans will never match the sheer CFM a mechanical clutch fan can push.
  3. Jul 4, 2020 at 6:46 PM
    eon_blue
    Azusa, CA
    Yeah, they might be ok for a street rig but I know @FLBAdrian wheels his truck and I'd hate to see him go through what I did with mine
  4. Jul 4, 2020 at 7:03 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
  5. Jul 4, 2020 at 7:12 PM
    eon_blue
    Azusa, CA
    Only if you name your truck Chaz
  6. Jul 4, 2020 at 7:28 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    This is generally frowned upon because it makes the system less reliable and less cooling ability.
    Chaz Michael Michaels :rofl:
    BYJOSHCOOK and eon_blue[QUOTED] like this.
  7. Jul 4, 2020 at 7:39 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    NM, it's back to black!
    cruiserguy and eon_blue[QUOTED] like this.
  8. Jul 4, 2020 at 9:10 PM
    Jordan.cliner
    Jordan.cliner Well-Known Member
    Jordan
    Carlsbad california
    1996 Tacoma xtra cab, 4x4 3.4
    Fox 2.0 piggyback, K&N cold air, sparco seats, race radio, flomaster 10, total chaos uppers, for 2.5 dsc front
    I’ll come pick them up, I’m in SD and I’d love to check out the truck!
    boshak[QUOTED] likes this.
  9. Jul 4, 2020 at 9:15 PM
    Running Board Man
    Running Board Man Well-Known Member
    You can unbolt the metal pieces under the carpet for more room
  10. Jul 4, 2020 at 9:25 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Drill and tap the next size up.
  11. Jul 4, 2020 at 10:14 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    PM me your availability!
  12. Jul 4, 2020 at 10:15 PM
    boshak
    AG
    CA
    oOoo tell me more!
  13. Jul 4, 2020 at 11:21 PM
    Running Board Man
    Its like 6 10mm bolts and you get rid of the sheet metal that makes up the factory compartments under the seat
  14. Jul 5, 2020 at 5:20 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    This is good to know! I’ve been considering this mod. Does anyone know if there are upgraded fans/fans from a different vehicle that might move more air at a lower RPM that also fit inside the fan shroud?
    Running Board Man likes this.
  15. Jul 5, 2020 at 6:54 AM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    Pictures of the seats please. what year? thanks
  16. Jul 5, 2020 at 7:24 AM
    megalodon
    megalodon Well-Known Member
    FingerLakes Ny
    2003 v6 Ex.Cab
    finally making some progress on my rust repair not a ton of time to work on it between work & grad-school.
    When I pulled the bed I had to torch off the two rear bolts to get it off, and another one of the bolts apparently snapped when they did the frame replacement I haven't had a chance to get that off yet.
    I flipped the bed up to remove the two bolts then proceeded to knock the rust off the bottom so sprayed some rust converter on that & self etching primer on the back side of the patches I welded in while I have things apart.
    I thought I was close to being ready to get painting but as I was messing around with things I found more rust I need to cut out and patch, glad I found it now instead of when I got things back together.
    rust-repair-1.jpg rust-repair-2.jpg rust-repair-3.jpg rust-repair-4.jpg rust-repair-5.jpg rust-repair-6.jpg rust-repair-7.jpg
  17. Jul 5, 2020 at 7:35 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I have tint all the way around. Clutch fan is brand new denso.
    m3bassman[QUOTED] likes this.
  18. Jul 5, 2020 at 9:26 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    It gets pretty hot here where I’m at I was like at 207 temp at a light waiting.
  19. Jul 5, 2020 at 9:27 AM
    Empty_Lord
    Dan
    Make sure your radiator fins aren’t plugged up with gunk and stuff
  20. Jul 5, 2020 at 9:28 AM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
    I do need to clean it out with air
