  1. Jul 18, 2020 at 9:27 AM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    Finally get the truck finished up with frame and bed rust squared away. Bed back on everything hooked up.
    Now I’ve got an intermittent shake in the steering wheel 55-70mph. Ive recently (a month ago) rebuilt the front end. From bushings, ball joints, steering rack and both hubs. New tires and wheels less than 3 weeks ago.
    If it’s not one thing, it’s another.
    Taco critter and Bridge4 like this.
  2. Jul 18, 2020 at 9:29 AM
    Madjik_Man
    Colorado Front Range
    Were the tires balanced with bed off the truck?
    Maybe going back and have them balance the tires again?
  3. Jul 18, 2020 at 9:32 AM
    JoeyWales
    SC
    Yeah, I’m thinking I’ll probably have them rebalance. Perhaps a weight came off. But I’m having a sneaking suspicion it may be a warped rotor. Awhile back, I had a sticking caliper front passenger side. I replaced the rotors and pads then. Though I’m wondering if it’s sticking again.
  4. Jul 18, 2020 at 10:16 AM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    Yeah I think you'll end up liking it when camping. Just have to get it setup and configured the way you like it and get rid of that auto ;)
    The shorter bed does suck a fair bit. You will for sure notice the difference when you start loading your stuff in. But with the shell on the back, you can really stuff a lot of shit in there! Add that to the ability for all of your passengers to have their own doors and a proper seat... window for the dog to not get sick and it's all worth it. Roll down the windows, put on some good tunes and get in low range... you'll forget about the rest of it soon enough.
    Also, just gotta start making memories with that new truck. I had a hard time letting go of an old hippy van of mine. Loved camping and road tripping in that brick and made a ton of great memories.
    jubei likes this.
  5. Jul 18, 2020 at 10:23 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    @osterhagen has probably the most comprehensive build I've seen.
    cruiserguy likes this.
  6. Jul 18, 2020 at 10:37 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Code finally popped and its its cylinder 3 missfire again. Guess the ign coil and the plug was bad
  7. Jul 18, 2020 at 11:34 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    To match for your CB antenna... link
    siznarf, kuntry09 and ToyotaDriver like this.
  8. Jul 18, 2020 at 11:35 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    pretty much as long as the door opens freely you should be good. Mine has a gap of approx 1/4”
    Reh5108 and High Noon like this.
  9. Jul 18, 2020 at 11:40 AM
    Bluecord
    Bluecord Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
    In the process of doing a coolant flush. Changing the upper and lower radiator hoses while I'm at it. On the upper hose I can still see the yellow and white lines on the hose to see which end attaches to the radiator and which goes to the engine. On the lower hose the markings are gone. New hose has a white line with a blue dot on one end and just a blue line on the other end. Anyone know which end goes where? Does it really matter? Both ends appear to be the same diameter and the shape is the same regardless of which direction I flip it.
    Bridge4 likes this.
  10. Jul 18, 2020 at 12:07 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    same here a while back
    Burro[QUOTED] likes this.
  11. Jul 18, 2020 at 12:57 PM
    Bluecord
    Jeff
    Louisiana
    When I removed the clamp I was able to see the old markings. White line with blue dot goes to radiator. Blue line goes to engine.
  12. Jul 18, 2020 at 1:35 PM
    TacoLife04
    TacoLife04 Member
    Aaron
    2004 White Tacoma SR5
    Aftermarket head/tail light, LED conversion bulbs all around, 55” LED bar on bumper, 42” LED bar above windshield, straight 1 3/4 pipe with single glass pack 2” exhaust tip
    Lmao!!! Honestly I just might get one
  13. Jul 18, 2020 at 3:26 PM
    TexasED04
    TexasED04 Well-Known Member
    Brandon
    Houston, Tx
    04 Texas Edition PreRunner
    looking good!
  14. Jul 18, 2020 at 3:27 PM
    TexasED04
    Brandon
    Houston, Tx
    Looks awesome! plans for any lighting?
  15. Jul 18, 2020 at 3:29 PM
    TexasED04
    Brandon
    Houston, Tx
    what brand joint did you go with?
  16. Jul 18, 2020 at 3:53 PM
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    Yep, planning on getting some pods to fit in those square cut outs. Either ball out with some baja designs or just go with brightleds or something more budget friendly
    Hooks98tacoma likes this.
  17. Jul 18, 2020 at 4:37 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
  18. Jul 18, 2020 at 4:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Rear shock relocation :drool:
  19. Jul 18, 2020 at 4:50 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    And Ubolt flip, and frame boxing, and frame reinforcement plates, and super bumps.
    And I have another idea... while the bed is off... if I have time.
  20. Jul 18, 2020 at 4:57 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Replaced my busted headlamp and repainted my grille center, nice and deep black with bedliner.
    Oh and I did my front brakes too, but that's boring
