  1. Jul 20, 2020 at 9:33 AM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Truck rarely gets driven and is trailered everywhere. If it goes bad I’ll replace it under warranty. I thought 200 was a lot for an optima. Can’t believe people are paying what they pay for some things.
    That’s the case with 99% of products now a days. All same product made by the same factory with a different sticker and some have better quality control on what’s actually sent out.
  2. Jul 20, 2020 at 9:39 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I got in a flame fest last time I posted about batteries in here but fuck it I dont care. I would just get a parts store AGM and save the money. Optimas are over priced for what they are and if your truck is sitting most of the time, just a cheap AGM with a battery tender so it's not dead when you load it up on the trailer. I have a car quest AGM stock sized battery and it has been drained twice, nursed back to health with a jump start from my avalon and a cheap battery tender and works great and holds a full charge still. No issues winching with it either.
  3. Jul 20, 2020 at 9:49 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    I've still been running yellow top Optimas. Not lasting as long as they use to but still get 4-5years out of them. Advance Auto always has 20-25% off coupons where I pickup one for around $180-190.
    Noticing better resting voltage with using the voltage booster. Running a higher charging voltage is keep both my yellow tops closer to their designed voltage. Especially with AGM, voltage input needs to be at it's designed voltage which is slightly higher than a standard battery.
    https://www.hkbelect.com/product/24...nic-fuse-version-micro-blade-compatible-2004/
    malburg114[QUOTED] likes this.
  4. Jul 20, 2020 at 10:12 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Not a tacoma, but on the topic of all the raptor liner jobs being done: check this guy out.
    Only things that weren't coated were the lights and door key locks.
    Y'all are doin it wrong
    :stirthepot:
  5. Jul 20, 2020 at 11:23 AM
    Running Board Man
    Running Board Man Well-Known Member
    Is it bad to drain a battery flat?
    I left the key in my tacomas ignition when I worked on it
    Several times at least I'd get in to go to school and it wouldnt even click I had to jump it with my jumper and off I went, never had a problem with that battery
    Than after I changed injectors I cranked it till it didnt
  6. Jul 20, 2020 at 11:31 AM
    slander
    Hickory, NC
    People freak out if you drain an AGM flat. They can be hard to be brought back to life in some cases.
  7. Jul 20, 2020 at 11:33 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    The little odds and ends you don't think about when you have the bright idea to box your frame.
    Brake proportion valve brackets need to mount somehow lol.
  8. Jul 20, 2020 at 11:39 AM
    Madjik_Man
    Colorado Front Range
    If my battery lasts 6 years am I really going to remember the extra $60 I spent on it? No.
  9. Jul 20, 2020 at 11:43 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Good time to shit can it and put a manual valve in.
    ToyRyd04, ToyotaDriver, jubei and 4 others like this.
  10. Jul 20, 2020 at 11:47 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Thought about it. But this project is going on long enough. I've had enough set backs. Just want to finish it lol.
  11. Jul 20, 2020 at 11:47 AM
    Wulf
    rock raisin
  12. Jul 20, 2020 at 12:06 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Do you have a suggestion on any? I've been thinking about swapping mine out since I don't load it for work anymore, but I haven't looked at them in years.
  13. Jul 20, 2020 at 12:17 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Lemme see what I have in my stash. I think I have a few of those circlips I can send you in an envelope
    JKO1998[QUOTED] likes this.
  14. Jul 20, 2020 at 12:20 PM
    Squeaky Penguin
    Brett
    That's why I do projects like that in the middle of winter when I can take my time. They always take longer than you plan.
    It's been four years since I did mine, so haven't really paid attention to the current options. I used the Front Range kit and it's been working well.
    nagorb[QUOTED], jubei and POSTacoMike like this.
  15. Jul 20, 2020 at 12:20 PM
    Madjik_Man
    Thats awesome
  16. Jul 20, 2020 at 12:24 PM
    Running Board Man
    I wonder how nasty it feels to put the mirrors up or down
    Or no tow mirrors?
  17. Jul 20, 2020 at 12:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Willwood makes one. But the Front Range offroad kit is nice. Also what Im running.
    Not sure I love it or not though. Doesn't seem to change much when I change the valve.
  18. Jul 20, 2020 at 12:30 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Please and thank you
  19. Jul 20, 2020 at 12:31 PM
    Wulf
    rock raisin
    The sharptones are awesome at getting people's attention
    Running Board Man likes this.
  20. Jul 20, 2020 at 12:34 PM
    Running Board Man
    I was elated when I found out 4 runners (mine at least) didn't have them
