  1. Jul 27, 2020 at 11:18 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Ahh, I see. You reuse the sleeves on the ES ones. Boy, that sounds terrible.
  2. Jul 27, 2020 at 11:24 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah no doubt haha but some do it. Most have been doing the whitelines though. I think these will work better. hoping to put them in the little truck this fall.
  3. Jul 27, 2020 at 11:45 AM
    POSTacoMike
    POSTacoMike On the rocks, please
    Red Deer AB
    2001 Tacoma DC XPreRunner
    OME Suspension, ARB Bumper, frame swap, Rebco logger box.
    I gotta get at this. Planning to run 36x15.5 MTZ's for snow season. Body mount chop is done on mine already, did it when I swapped the double cab on. I'll get at it this fall. Yours looks good.
    alexvallorosi[QUOTED] likes this.
  4. Jul 27, 2020 at 12:02 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Got a coat of primer on my front and rear plate bumpers. Tomorrow will be a good coat of Raptor Liner. This rehab is just about to wind down.
    megalodon, osterhagen and cruiserguy like this.
  5. Jul 27, 2020 at 1:01 PM
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    Rldanie and drr[QUOTED] like this.
  6. Jul 27, 2020 at 1:06 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
  7. Jul 27, 2020 at 1:14 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Is that due to GFC? I, too, am blocked with Tepui...
  8. Jul 27, 2020 at 1:22 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    That's why I put a reverse cam in mine recently. The canvas on my rack blocks all view. But at least with my cam it came down to how you wired it up if it was on full time. I tapped into an accessory power that was on when the truck is on so the camera is powered all the time, and the head unit trigger is tapped into the reverse switch. So on my head unit I can switch to look at the reverse cam if I need to even if I am not in reverse. I would assume these cams would be operational based on how you wire it as well.
  9. Jul 27, 2020 at 1:41 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah, although I've gotten used to it. This would just be nice to have, plus you never know when you'll want a video of stuff that's happening in front or behind you.
  10. Jul 27, 2020 at 1:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    FYI that camera setup only lets you do 2.5K on the front and 1080 on the rear or vise versa. No 2.5k on both. You need the next model up to run both at 2.5k.
  11. Jul 27, 2020 at 1:49 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Post a link? That vendor only offers an $80.00 1080p and that one that was posted.
  12. Jul 27, 2020 at 1:58 PM
    MoneyB86
    Reagan Country, CA
    Yes, that’s what I am doing. Works perfectly for it.
    drr[QUOTED] likes this.
  13. Jul 27, 2020 at 2:12 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Good call, I really only need/want it for the rear but might as well have the capability to do both at high res.
    If you scroll down to the side by side comparison between models, there is a $69, $99, and $149 version. The $149 one does 2.5K front and rear.
  14. Jul 27, 2020 at 2:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    https://www.amazon.com/dp/B089SVCW1X/ref=emc_b_5_i
    Yeah I mean I know you're getting it for the utility of it. But might as well have it for the worst case scenario too to be able to ID anyone.
  15. Jul 27, 2020 at 2:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Of what??
  16. Jul 27, 2020 at 3:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    man. Your killing lately haha
    I'll pass, no need for those.
  17. Jul 27, 2020 at 4:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not saying they aren't still haha I just want to use the other option I've found and the other truck don't use stock arms so..yeah.
  18. Jul 27, 2020 at 4:22 PM
    loudboy
    loudboy Well-Known Member
    Portland, OR
    '04 4x4 TRD Off-Road Limited
    All-Pro lift, Addicted tube bumper, Revenge sliders, stuff and crap
    My original lift springs werent strong enough to hold the front of the roof up at their deplyed angle, so I installed new stronger ones (I had been using prop-sticks before). They were much too strong to be used regularly, but I wasnt in a position to mess with them at the time so I clamped the lid closed and drove home. I took a weird gust of wind while passing a semi-truck at 75mph on the freeway which helped the gas springs start the lift. Once they started, the springs just buckled the aluminum frame and snapped it.
    I'm bummed, but this is an oportunity to build the roof better, stronger, lighter. I'm going to try using aluminum 8020 T-track, aluminum composite material roof, and a better waterprooof fabric ( see @Ripcord 's excelent write-up here https://www.expeditionportal.com/forum/threads/diy-wedge-camper-gfc-replica.213267/)
    I'm just glad I didnt hurt anybody. Stay positive, you know? We need it these days.
    StevenP[QUOTED] and cruiserguy like this.
  19. Jul 27, 2020 at 4:26 PM
    loudboy
    Portland, OR
    Have you seen a double-din head unit that does dash-cam DVR duty? I've got the only one I could find installed, but its a Pyle and it truly is a pile. It's a bummer that the big-boys like Kenwood or Pioneer dont have a headunit that will do front and rear dash-cam.
  20. Jul 27, 2020 at 4:32 PM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    Love your attitude. Stoked to see what you cook up for this :cheers:
    loudboy[QUOTED] likes this.
