  1. Jul 27, 2020 at 9:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :notsure:
    I was divinely inspired... :rolleyes:
  2. Jul 27, 2020 at 10:27 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    the shields definitely help. Send those back and get the Hikari ones. But you’ll still miss the Retro’s
    Yetimetchkangmi likes this.
  3. Jul 27, 2020 at 11:49 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    i can imagine going from retro’s to anything else would be a huge step down.
    Yetimetchkangmi and Fernando like this.
  4. Jul 28, 2020 at 12:37 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    What are you using to press them on?
    Thanks.
  5. Jul 28, 2020 at 12:54 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I actually added a bung in the air intake pipe for a sensor. Just haven't picked up another sensor. Since GM IAT sensors require a 5v reference to the sensor. I had to make my own small power supply with a inline resistor to hook it up to the fic6 analog input.
    You could use a gm IAT sensor and tie into the factory wires and it would work with the ecu.
    Reh5108[QUOTED] likes this.
  6. Jul 28, 2020 at 4:13 AM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    This is what I should’ve done. Then just weld in my own supports.
    0xDEADBEEF[QUOTED] likes this.
  7. Jul 28, 2020 at 5:43 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    We have the special tool and a 20 ton press. Easy for rear axles
  8. Jul 28, 2020 at 6:23 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If @crashnburn80 doesn't recommend them them (drop in LED's), I stay away. His tests speak for themselves.
  9. Jul 28, 2020 at 6:38 AM
    JoeyWales
    SC
    Okay, so maybe one of you can be helpful.
    Story time:
    When I was rebuilding my front end, front passenger side wheel speed sensor was rusted into the hub. Ended up cutting the wire and removing the sensor with a punch and hammer. Ordered new sensor, installed new one etc. ABS light came on as expected, figured give it awhile it should go off.
    Month goes by, still on. Pulled it numerous times cleaned reinstalled. You know standard procedures. Recently, did the wire jump to make sure it was front passenger side.
    31. Yes, front passenger.
    Did the brake pedal pump reset. No good. Light still on. Check connections again. Light still on.
    Then maybe 15mins after the first wire jump check, I do it again. This time I get; 31, 32, 33, 34 and now 41.
    So my question is, how can it flash code 31, then 15 mins later after not touching anything else on the truck, it flash the other codes as well? I didn’t move the truck, I didn’t mess with any other sensors. I understand code 41 has to do with voltage, but it seems out of the ordinary for it to just suddenly appear for no reason.
    Thoughts?
  10. Jul 28, 2020 at 6:42 AM
    JoeyWales
    SC
    I bought that harness from his post. It’s amazing to drive at night again. What a difference. And only maybe 30mins of install and $100.
    cruiserguy and se7enine[QUOTED] like this.
  11. Jul 28, 2020 at 7:14 AM
    POSTacoMike
    POSTacoMike On the rocks, please
    Red Deer AB
    2001 Tacoma DC XPreRunner
    OME Suspension, ARB Bumper, frame swap, Rebco logger box.
    I will if I have too, but I really don't want to. she has a 1" body lift now, I'd like to not add anything more.
  12. Jul 28, 2020 at 8:12 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Why would you need a body lift for 35s?
  13. Jul 28, 2020 at 9:23 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Did you cut up the litttle rubber dust cover things in the back of the headlight? Mine keep falling off and I’m too lazy to find a fix.
  14. Jul 28, 2020 at 9:24 AM
    JKO1998
    Utah
    Tires chains o_O:rolleyes:
  15. Jul 28, 2020 at 9:29 AM
    JKO1998
    Utah
    Cool
  16. Jul 28, 2020 at 10:54 AM
    Blues0010
    Blues0010 Well-Known Member
    Ben
    Boise, ID
    2001 Tacoma SR5
    Replaced my headlights and side markers. Long overdue.
    step 1: sand off the chrome trim (that stuff is for the pretty boys in their duallys) and paint it matte black
    vonellis, SwampYota, Burro and 2 others like this.
  17. Jul 28, 2020 at 11:47 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Raptor Liner applied to the bumpers. The end is in sight.
    CBI DIY for front
    NWTI DIY rear
  18. Jul 28, 2020 at 11:54 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I was able to get the rubber boot in by the heat sink. I just installed the bulbs you recommended but my fenders are off so I can't install the headlights yet.
    [​IMG]Untitled by Michael Halat, on Flickr
    They sell them in black already though... o_O at least I got myself some clears in black.
    I was just redoing the relocation on them yesterday morning.
  19. Jul 28, 2020 at 12:07 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Are those the ones that are blacked out on the inside plastic?
  20. Jul 28, 2020 at 12:11 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    no these are the depo’s without the orange reflector:
    nagorb[QUOTED] likes this.
