  1. Jul 30, 2020 at 12:36 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    technically the one to the block alternator side (starter ground as you called it) i believe ties into the battery body ground wire. but i may also be wrong.. dont pay too much attention to it
  2. Jul 30, 2020 at 1:54 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    It's by the oil filter. But a little bit forward and down.
  3. Jul 30, 2020 at 5:10 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    That's a good idea. While I don't still have the old ones (let a steel scraper have them), I have two 95s and the other one needs one spring. The left spring broke a while back and I only replaced that one. I could go ahead and buy the RH side and take that old one apart and reuse. I might just try that for a project/learning experience.
    Reh5108[QUOTED] likes this.
  4. Jul 30, 2020 at 5:17 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    They self clearance, ask me how I know :p
  5. Jul 30, 2020 at 6:14 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  6. Jul 30, 2020 at 9:02 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I don't think I was making any excuses, Mr. :p; just sharing my style to compare rear shock travel needs. Plus, I'm still slower than Monte and @Squeaky Penguin for sure.
    Not enough very's in this sentence. Getting out as much as I do, and so putting the miles under my belt helps a lot too I think, becomes a lot easier to pick lines and go fast when you're doing it all the time.
  7. Jul 30, 2020 at 10:08 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Oh yeah. that always helps. The threshold of comfort grows all the time.
  8. Jul 30, 2020 at 10:20 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't think it'll be possible to slow down...until im like 70 haha hard to go back to slow speeds.
  9. Jul 30, 2020 at 10:33 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Depends on terrain I think. I've learned which terrain can accept higher speeds without really messing with the truck. When I hit rocks, I slow way down. Our last couple trips have been on nicely graded roads.
    Who knows, maybe I'm just fooling myself. :notsure:
    m3bassman[QUOTED] likes this.
  10. Jul 30, 2020 at 10:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's a good point. I have a dog now so that could impact my world more than I think. He'll be in the cab still but Devin will not want it to be crazy.
    Could get a dog harness though...
    Don't worry, you are. Just wait for XYZ to implode on itself as it will eventually and then you'll go...damn..I should slow down I guess.
    So you'll fix it and then go back out with the intention of slowing down only to find it impossible to do so haha
  11. Jul 30, 2020 at 10:39 AM
    Madjik_Man
    Colorado Front Range
    If it means anything I do have a picture of you hanging up over my garage workbench :oops:
    Digiratus likes this.
  12. Jul 30, 2020 at 11:10 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Dan is doing this with Echo. Probably a good safety measure regardless.
    jubei likes this.
  13. Jul 30, 2020 at 11:20 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Sure, I let her drive once in a while. But she’s never off her leash for even a second.
  14. Jul 30, 2020 at 11:22 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    LOL I forgot about that. Funny shit.
    This looks appropriate :laugh:
    To bad my dog is bigger than that.
  15. Jul 30, 2020 at 11:24 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah im building a platform and hope to find something that'll work.
  16. Jul 30, 2020 at 11:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No shit! haha be so good. Gotta find it...
  17. Jul 30, 2020 at 11:36 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You carry a pretty good pace.
    Don't speed up anymore or your truck will end up like mine - A constantly broken piece of shit.
    m3bassman and Blackdawg like this.
  18. Jul 30, 2020 at 11:46 AM
    1997tacomav6
    Denver
    Stainless steel fuel lines and heat shield are waiting for the supercharger coming today from its build
  19. Jul 30, 2020 at 11:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Solid advice
  20. Jul 30, 2020 at 11:55 AM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    It's almost funny how universal it is that going fast is expensive. Off-road, on track, in space, on the internet... hell faster charging is even more expensive. And if you get caught, it's expensive going fast on road too ;)
    cruiserguy likes this.
