  1. Aug 1, 2020 at 11:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not yet.
  2. Aug 1, 2020 at 11:07 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    I'm down for helping on the other side of the welder.
    My truck is at Auburn OffRoad getting new spindle bearings, at least that is what I think is toasted.
    They already said that the Camburg uni-balls are trashed.
    Digiratus[QUOTED] likes this.
  3. Aug 2, 2020 at 4:03 AM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    I used half a gallon. That’s two coats sprayed in the bed, fender flares, rear bumper plastic and front bumper valance and trim.
  4. Aug 2, 2020 at 6:11 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I was concerned since the backing plates gets pressed in between but I guess not for the disc setup?
  5. Aug 2, 2020 at 6:58 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Careful with them tranny's bro......
  6. Aug 2, 2020 at 6:59 AM
    1997tacomav6
    Denver
    Were in Colorado are you headed to?
    You coming over the pass from I-70? Some spectacular views up there, Vail, Aspen, Keystone, Divide, Pikes Peak=14,000 feet.
  7. Aug 2, 2020 at 6:59 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  8. Aug 2, 2020 at 7:34 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
  9. Aug 2, 2020 at 7:46 AM
    esxcli
    esxcli Keyboard Warrior
    Sean
    Reno NV
    All the guys in the SAS thread have me talked into the Atlas.
    Fernando[QUOTED] likes this.
  10. Aug 2, 2020 at 7:54 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Anyone ever heard of a flipping the receiver? Does it work with any hitch or nah? I’ll crawl under my truck when I get back to pavement, just curious right now
    Running Board Man likes this.
  11. Aug 2, 2020 at 7:57 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks brotha. I knew i forgot a few guys
    Damn :spending:
  12. Aug 2, 2020 at 7:59 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    When you mentioned it the other day I went and looked at mine. I think its specific to the factory ones on first gens maybe. The bolt pattern on either end of the receiver is a nice symmetric triangle so its flip able. Most receivers that I've seen are welded there instead.
    JKO1998[QUOTED] likes this.
  13. Aug 2, 2020 at 7:59 AM
    jubei
    NoCo
    Stuff. Also things.
    @Fernando , I think this is what you’ll hear from a lot of the dudes I tagged. The Atlas is super spendy and isn’t exactly bolt-on, but it does everything that duals will do and then some without a lot of the hassle.
    I can’t speak from experience, but that’s what I’ve picked up on in the SAS BS and Crawl Box BS threads.
    esxcli[QUOTED] and Fernando like this.
  14. Aug 2, 2020 at 8:02 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Ooh. Thats right. There is a thread on that. I'll go poke around. I wanted to keep it under 3k. Dont really wanna spend more then that.
    Thank you brotha
    jubei likes this.
  15. Aug 2, 2020 at 8:09 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Atlas because Toyota crawl box costs have gotten so expensive an atlas isnt that much more. Or try to find a used one.
    Kwikvette, Fernando[QUOTED] and jubei like this.
  16. Aug 2, 2020 at 8:11 AM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    What's considered 'light towing' when breaking in new gears? I have a 6x10 wood bottom utility trailer and a 7x16 tandem axle trailer I could use to break in the gears for towing... Don't know which to use, I just don't want to over load the gears.
  17. Aug 2, 2020 at 9:06 AM
    esxcli
    Sean
    Reno NV
    Black Friday 3500ish
  18. Aug 2, 2020 at 9:13 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    It’s got a seperate plate so you can slide it over. It’s designed so you can cut the old backing plates and install these without pressing.
    cynicalrider[QUOTED] likes this.
  19. Aug 2, 2020 at 9:23 AM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    I’m picking up my crawl box from Trail Gear this week. So far I’m only about 2k into it, that’s the crawl box, crossmember, and triple sticks from RAD Design. I capitalized on their 4th of July sale, subscriber discount, and transfer case $400 core trade in deal. I will still have to figure out what I want to do with driveshafts, but regardless I should be able to get out well below 3k.
    The 4th of July sale is obviously long gone, but you can still get the 10% subscriber discount and the $400 dollar core credit if you provide your own core (I bought one off eBay for 180, so more like a 220 credit for me).
    I know TG isn’t as highly regarded as the Atlas, or the Taco Box, but it’s a lot more affordable than the Atlas, and can be had much faster than the Taco Box. Mine was ready in about 2 weeks (again, I did provide the core - wait times depend on cores). I’ll be sure to post up a lot more about it when I pick it up and install it.
    ToyRyd04, esxcli, Kwikvette and 2 others like this.
  20. Aug 2, 2020 at 9:52 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I don’t have any regrets on my TG Toyota duals with a 3RZ/5 speed on 37’s. Zero leaks and can be done for around $2k if you snag a top shift box from a junkyard. 6 years on mine with zero problems. If you’re going to run 40”+ tires and have a heavy foot, I’d probably just bite the bullet on an Atlas. It hurts at $4k but the Toyota stuff doesn’t hold up to HP and 42’s.
    StevenP, Fernando and jubei like this.
