  1. Aug 2, 2020 at 9:59 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    My understanding is no towing for the first 500 miles and light throttle/load for that entire first 500 miles.
    Yetimetchkangmi and cruiserguy like this.
  2. Aug 2, 2020 at 10:01 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    She rolls boys!
    megalodon, ireymon, Bridge4 and 24 others like this.
  3. Aug 2, 2020 at 10:16 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks guys. Maybe i should bite the bullet. Now i need to do more HW on the atlas. Is this tranny good for DD? Eventually, my rig will be on tons.
    I have the cash now. But responsible me says pay off debt. Cool me says sas it already. Lol
    StevenP[QUOTED] likes this.
  4. Aug 2, 2020 at 10:18 AM
    esxcli
    esxcli Keyboard Warrior
    Sean
    Reno NV
    Cool Fernando sounds pretty on point.
    Fernando[QUOTED], StevenP and jubei like this.
  5. Aug 2, 2020 at 10:32 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Do you mean getting a top shift gear driven case? Cause my factory j-shift chain case is top shift
    esxcli likes this.
  6. Aug 2, 2020 at 10:36 AM
    esxcli
    Sean
    Reno NV
    Got the kids out for a quick solo.
  7. Aug 2, 2020 at 11:03 AM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    Put the cash towards a card, and use said card to buy the stuff.. that’s the best of both worlds right??o_O
    Fernando[QUOTED] likes this.
  8. Aug 2, 2020 at 11:05 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    The atlas in fine in a DD, it uses np241 style planetary reduction and a gear drive output setup based on a Dana 300. It’ll be noisier than a single stock chain case but DD-able.
    Top shift gear drive case
  9. Aug 2, 2020 at 11:27 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    The advantage of the atlas is that is THE last tcase you would have to buy. I have around 3k dumped into my lefty/dual setup and if I ever wanted to build a buggy I would have to buy an atlas or something, between the lefty and 30spline chromo everything i have probably the strongest gear drive toyota setup you could build. If I would have spent 1k more I would have a forever tcase. Now an atlas is a lot harder to fit into a Tacoma if you dont want it dangling way below the frame. The toyota duals used to be a good deal, but they switched the materials over to unobtanium or something because it's pretty expensive now. The days of building a dual setup out of junkyard parts for $500 are long gone! My duals are noisy as hell, and get crazy hot on the highway and it does increase your maintenance. I change my fluid every 6months when it was a DD, it seems to always leak etc. I DD my duals for over 12years. I have a friend with a 4spd atlas in his grand cherokee and he installed it once and never touched it again.
    Saying that my duals are the best mod ever, way better than an SAS and worth the $$ and time invested. I should have went atlas but I also built my first set of duals in 2008 and my lefty in 2010 so it was still far cheaper than an atlas, now with today's prices and marlin getting stupid with restricting you from buying the parts to build it yourself, it's not worth the $$ for what you get these days IMO. TG I refuse to use anything that is a precision machined component, that's just me, their parts always looked like cheap HF crap to me, BUT others have had good luck with their stuff. In fairness I also had a marlin coupler strip out on me.
    Another thing to consider is with an atlas you WILL need a welder to install it, you will have to build your own cross member. With the toyota duals you can just use the factory cross member. I did that for the entire time I was IFS with no real issues. So that's a consideration as well not knowing your tool availability and fabrication skill level.
  10. Aug 2, 2020 at 11:33 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    We're headed to Colorado Springs (specifically Ft Carson. my kid is stationed there)
    On the way in, we're going to be coming through Aspen/Independence pass. We may be doing Pikes Peak while we're there depending on time. On the way home we'll be hitting Monarch pass on 50 and then we're going to do Highway 62 from Ridgway to Placerville and head out highway 145/90 to catch 191 in Utah south of Moab.
  11. Aug 2, 2020 at 12:41 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    That is one beautiful frame.
    Empty_Lord[QUOTED] likes this.
  12. Aug 2, 2020 at 1:10 PM
    Empty_Lord
    Dan
    I’d hope so it’s new! Lol
    Speedytech7 likes this.
  13. Aug 2, 2020 at 1:11 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Don't roll it out of the garage though, you're in indiana... It'll look worse than the titanic in a matter of seconds
    slander and Phessor like this.
  14. Aug 2, 2020 at 1:26 PM
    Empty_Lord
    Dan
    Already did and it’s fine! It’s in the third bay right now. Tundras being stored for the moment to make room for a 4runner I have to work on... while I have the runner I’ll hopefully get the front diff and shit onto the frame
    Speedytech7[QUOTED] likes this.
  15. Aug 2, 2020 at 1:28 PM
    slander
    Hickory, NC
    Lol!!
    I had a jeep yj that I put in storage and the frame rotted out in 2yrs sitting in a garage here in the midwest F humidity!!
  16. Aug 2, 2020 at 1:39 PM
    Speedytech7
    Out here we roll out shit that's been sitting for decades and other than some mildew or lichen it looks new.
  17. Aug 2, 2020 at 2:13 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Correct! I’m past the initial 500 miles and the oil change. After that, it instructs that only ‘light towing’ for 40 miles. I plan on calling tomorrow, just curious as to what other guys have done.
  18. Aug 2, 2020 at 2:21 PM
    ToyotaDriver
    Idaho
    When I did my rear end last year, I just did the 500 mile break in and went about abusing it as I always have after that. Pulled the ring and pinion this year and 10,000 miles later to regear, and it doesn’t show any signs of abnormal wear or abuse.
    kuntry09[QUOTED] likes this.
  19. Aug 2, 2020 at 3:22 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Dont worry.. I was not gentle ;)
    BYJOSHCOOK, m3bassman and cruiserguy like this.
  20. Aug 2, 2020 at 3:51 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Well fuck it. I need to sas
    Lol
    You sound like a responsible man
    So bite the bullet and go Atlas is what your saying? Does the atlas come with hella sticks? I dont care for them.....
    You nasty MF!!!
