  1. Aug 2, 2020 at 5:53 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I would think that tire size also has a role on how easily you can fret/strip the T-case input shaft too. 33's/34's would put a lot less of a load on the connections versus say 37's.
  2. Aug 2, 2020 at 5:58 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    It happend on 33s. It has nothing to do with stress, fretting is two surfaces rubbing against each other like splines.
    jubei and malburg114 like this.
  3. Aug 2, 2020 at 6:00 PM
    betterbuckleup
    Ian
    Concord, CA
    Dang. Well I take back what I said in that case
    slander[QUOTED] likes this.
  4. Aug 2, 2020 at 6:01 PM
    slander
    Hickory, NC
    You dont even need a cross member, just run it with the factory trans mount. I did that the entire time I was IFS with my doubler. Worked great!
    jubei and malburg114[QUOTED] like this.
  5. Aug 2, 2020 at 6:04 PM
    slander
    Hickory, NC
    Mine happend almost a year to the day after I installed it, it was most likely installation error on my part. This was 2007/2008 and there was ZERO info on installing these anywhere. Like I said others have had good luck, I lost all confidence after that for mine.
  6. Aug 2, 2020 at 6:06 PM
    betterbuckleup
    Ian
    Concord, CA
    Gotcha. If there's anything I've learned from the crawlbox BS thread, it's to use shit loads of anti-seize on splined connections.
    jubei and slander[QUOTED] like this.
  7. Aug 2, 2020 at 6:09 PM
    slander
    Hickory, NC
    Yea I found that out after mine blew up and I made it my lifes mission to plaster that info all over the internet.
  8. Aug 2, 2020 at 6:19 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    How I’d love to swap a 5 speed into my double cab.
  9. Aug 2, 2020 at 6:26 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Do it! It's really not that hard, mostly just time consuming. @osterhagen has a great swap thread.
  10. Aug 2, 2020 at 6:29 PM
    razhick4x4
    razhick4x4 Well-Known Member
    Alex
    MT/WY
    2004, Tacoma SR5 Xtracab TRD, 4x4, Red, 5spd. V6
    ARB Bumper, 3" Toytec/OME lift, 33s, Sliders, ARE Topper, Ditch Lights, Hella LEDs, Trigger controller, CB, Pioneer Radio
    out of curiosity (forgive me if this has been mentioned somewhere already) what gear ratio are you running?
  11. Aug 2, 2020 at 6:39 PM
    razhick4x4
    Alex
    MT/WY
    ok, how's the power with 35s and stock gears? i'm running 285s and haven't felt a particular need to re-gear, plus at 80 i'm at almost 3100 RPMs. truck's much happier at 75 and 2800. trying to get this figured out as re-gearing has crossed my mind and in 10 days i'm moving to a state where the actual speed limit is 80.
  12. Aug 2, 2020 at 6:39 PM
    JoeyWales
    SC
    If I could find the proper parts, I totally would. I need to write down the proper parts list and really start looking and collecting. Finding the proper ECU is what I’m expecting to be the hardest part.
  13. Aug 2, 2020 at 6:52 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Parts hunting is never easy. I waited 5 or so years for a decent local deal to pop up, but I was really only looking in here. I ended up just buying an ecu off eBay, wasn't cheap, but worked.
  14. Aug 2, 2020 at 7:28 PM
    Madjik_Man
    Colorado Front Range
    Same.
    I’m still trying to bribe @osterhagen to road trip to Colorado...
    osterhagen likes this.
  15. Aug 2, 2020 at 7:42 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
  16. Aug 2, 2020 at 7:42 PM
    Spoonman
    Jamie
    Alberta
    It’s extremely easy. You don’t need an ECU or wiring harness.
  17. Aug 2, 2020 at 7:56 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    So atlas? Thats the tranny right?
    Idk...thats why i was asking. Got some cash burning a hole in my pocket
  18. Aug 2, 2020 at 7:57 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Sound like you got your answers, but:
    1. My truck came with those little boots. Think it was an 01+ thing. Haven't run them in years and it's been fine.
    2. Those old LBJs were shot! It's vertical play you need to be concerned about, and it looks like those had lots.
    3. Alignment will look off when you first drop it back on the ground. You should be fine, but if you don't know the last time it was aligned, it couldn't hurt to get one.
    I messed up by not buying one of those from Low Range last fall when you could double up on coupons and get them for 25% off. :facepalm:
    Going to be watching closely for black friday deals.
  19. Aug 2, 2020 at 8:02 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
  20. Aug 2, 2020 at 8:13 PM
    Madjik_Man
    Thanks man, appreciate it.
    Yes, lots of vertical play in the joint. Both sides.
    I should get an alignment because 1. I don't know when the last one was and 2. I just got new wheels/tires on it.
    However I am also going to hopefully be doing the suspension here in a few weeks, so I'm going to need to get one again after that install. I'll spend the money but doing an alignment so close together and paying twice is a swift kick to the nuts.
