  1. Aug 6, 2020 at 8:19 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Hell yeah! Score!
  2. Aug 6, 2020 at 8:28 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Brown santa brought me a box of bolts today, should be all the ones I need to reassemble the back half of my truck. A lot of progress considering I spent the evening drinking and playing trivia on zoom :laughing:
    EDIT: For future reference, BoltDepot.com is amazing. So much cheaper than a hardware store.
  3. Aug 6, 2020 at 8:28 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Yeah, I don’t think that really bothers me. Plus I’ve never had a 2.5 shock, so out of sight out of mind haha
  4. Aug 6, 2020 at 8:53 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    The whin came on slow last summer I top it off and added stabilizer to it and it went away. Its back now not so bad yet . Leeds me to thinks it’s the filter/screen thing. Full Monty Away
    2002Tacoma4x4 likes this.
  5. Aug 6, 2020 at 9:05 PM
    G59
    G59 Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Replaced my stock windshield sprayers with ones off of a Honda Odyssey today! Best upgrade Ive done in a while. Bye bye laser beams
  6. Aug 7, 2020 at 6:29 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Check the 4wd and make sure the actuator is still working. They tend to fail if not used.
    cruiserguy likes this.
  7. Aug 7, 2020 at 7:10 AM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    Went into 4 low, or atleast it felt like it did when I tried it out.
    It was maintained at a high end Toyota/Lexus specialist shop so I was pretty confident about the purchase, that’s where we met and I checked it out.
    cruiserguy and se7enine[QUOTED] like this.
  8. Aug 7, 2020 at 7:37 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    It's not a "filter" it's a strainer.
    It can be rinsed and re-used. The only reason you wouldn't be able to re-use it is if it has damage, In which case you have bigger problems than what replacing the strainer will fix.
  9. Aug 7, 2020 at 11:21 AM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    CEL free was very short lived. Throwing the dreaded p0420 code.
    Guess redoing the exhaust is next on the list. It really will be a new truck at this rate...
    Bridge4 and Running Board Man like this.
  10. Aug 7, 2020 at 11:23 AM
    eon_blue
    Azusa, CA
    That code is a huge pain in the ass if you live somewhere with emissions testing. If not, you can usually get by with that code for a long time just coming and going. But if you intend on replacing the entire exhaust eventually that should take care of it. Might just need a crack fixed though or more likely a bad cat.
  11. Aug 7, 2020 at 11:25 AM
    JoeyWales
    SC
    Luckily my state doesn’t require emissions. But it’s still a nuisance to see the light. Honestly, I’m not surprised. Between the rust and exhaust leaks, it needed to be done anyway. I’m thinking magnaflow cats. Seems people have had some pretty good luck with them.
  12. Aug 7, 2020 at 11:27 AM
    eon_blue
    Azusa, CA
    Yeah when I got the intermittent P0420 I needed to replace the front cat, ended up just replacing front and rear with Magnaflows. That was almost 4 years ago now and they are still going strong. Way cheaper than OEM and probably won't last as long, but it's hard to bite the bullet on the price of OEM cats. Especially if you don't need them in your state.
  13. Aug 7, 2020 at 11:28 AM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    @Blackdawg
    @Squeaky Penguin maybe?
    @anyone else running Solo Stock Length Lowers
    Any word on replacing bushings from Solo? Was planned on throwing on some Cam Eliminator Plates and figured I'd replace the bushings while down there.
  14. Aug 7, 2020 at 11:35 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I just got new ones. They should be able to send you some if you want, just give them a ring.
    Though if your doing solid lower mounts(which i assume means you have heim adjustable uppers now) then I'd look at getting some Derlin bushings.
  15. Aug 7, 2020 at 11:59 AM
    MattJakobs
    Matthew
    NorCal
    Price? Get them to you pretty quick?
    What Delrin bushings are you speaking of? I've got uniball uppers, bushing sleeves on the ends though.
  16. Aug 7, 2020 at 12:09 PM
    MattJakobs
    Matthew
    NorCal
    And another question. Ever consider adding a zertz insert?
    Running Board Man likes this.
  17. Aug 7, 2020 at 12:15 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I'm going to add zerks next time I pull them out. I messed up by not adding them from the start, but didn't want to drill into my brand new arms. IMO, they really should come with them.
    Haven't messed with replacing the bushings yet.
    MattJakobs[QUOTED] likes this.
  18. Aug 7, 2020 at 12:42 PM
    JoeyWales
    SC
    Are they stainless? If so, do they still decent and not rusted?
  19. Aug 7, 2020 at 12:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Like 80 bucks? or 60?
    Delrin is WAY harder than Poly is all. If you solid mount the lowers then you want to eliminate play in the bushings. This is because the bolts will just be straight, they don't need to twist bushings as the alignment will be done with the Uppers.
    You can NOT solid mount the lower without a heim upper adjustable UCA. As in the mounts are heim joints that screw in and out. This is because if you solid mount the lowers and use a standard UCA you have literally not way to adjust for an alignment.
    So no Heim UCAs, No solid lowers.
    @austinmtb is going through this process now. This is also a very popular mod on 2nd gens more so than 1sts. He is making his own UCAs I think and he got Derlin bushings from somewhere for his Solos.
    Solo is way understaffed right now. but they are busting ass as best they can. It took a while but they go to it. Think Carl told me they were operating at 25% staff...
    YES! it is one of my biggest complaints. my LT kit LCAs have them. Not sure why these don't. I was planning on doing it but I ran out of time and just had to get it back together. The thickness of the wall for the mounts though is HUGE. Like twice as thick as my LT kit ones. So maybe a zert won't clear.
  20. Aug 7, 2020 at 12:43 PM
    eon_blue
    Azusa, CA
    Mine are permanently covered in cooked on dirt lol. Rust isn't really an issue where I'm at
