  1. Aug 7, 2020 at 12:50 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    Lucky you. No salt here, but it’s always humid and a chance of rain.
    eon_blue[QUOTED] likes this.
  2. Aug 7, 2020 at 1:31 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Ah thanks for the education ! Noob forever :) Any specific procedures on rinsing the strainer?
  3. Aug 7, 2020 at 2:05 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The 02 whines in first gear. I’ve noticed a lot of Tacoma’s do it with the a340. My 01 never did though
  4. Aug 7, 2020 at 2:12 PM
    JoeyWales
    SC
    Has anyone seen a side by side or know the answer to whether the new gloss grey wheels (PTR20-35110-G4) are lighter in color than the matte grey version? Or are they simply just a gloss version without the red TRD lettering?
  5. Aug 7, 2020 at 2:13 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Just rinse it reverse of the flow with some transmission fluid. There shouldn't be much of anything on it. You may see a grey haze on it that should pretty much go away once you rinse it.
  6. Aug 7, 2020 at 2:55 PM
    vonellis
    Some and some more
    Sweet thanks!
  7. Aug 7, 2020 at 3:05 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Tried to do some proactive maintenance and made things much worse. I noticed my clutch fluid was very dark a week ago and decided to do a flush. My flush involved putting new fluid in the reservoir and cracking the slave cylinder bleeder to drain into a 20oz bottle, I did this until the fluid ran clear. I believe I introduced air into the system and now I'm having trouble fully actuating the clutch to get out of gear.
    [Edit]. After taking some videos, I've found that the slave cylinder does not consistently hold pressure. I can press the clutch pedal and on some attempts the slave cylinder stays extended, on others it slowly retracts and after a second or two the clutch is no longer disengaged. Does this sound like I still have air in the system, or do I have a failing slave cylinder?
  8. Aug 7, 2020 at 5:33 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Wok= Overlander, right?
    Tour991, vonellis, Phessor and 5 others like this.
  9. Aug 7, 2020 at 5:36 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    I can feel my colon shaking from all that protein. Fuckin jelly man, enjoy it
  10. Aug 7, 2020 at 5:54 PM
    eon_blue
    Azusa, CA
  11. Aug 7, 2020 at 6:16 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    So I noticed one of the studs on the output flange of my transfer case was loose. Splines are rounded on the stud and completely gone in the flange. I noticed my prerunner output flange uses nuts and bolts, can I just use those or should I get a new flange from toyota.
    -fpfCRfP30NwSqRp8mJYlrBj_iOt2-1uaYW5A6dV_0e0b9887876585bce513427b63ce9951d9cd2f08.jpg
  12. Aug 7, 2020 at 7:18 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I would just order a new one from Toyota or aftermarket. Might need to get one with a larger spline as the id might have wallowed out on the output flange. You shouldn't need a new flange.
    DashMaple[QUOTED] likes this.
  13. Aug 7, 2020 at 7:26 PM
    DashMaple
    Louisiana
    I ask about swapping to bolts because toyota does not seem to sell the studs by themselves
    Running Board Man likes this.
  14. Aug 7, 2020 at 7:33 PM
    Running Board Man
    Running Board Man Well-Known Member
    Just put a nut and bolt on it you wont die
  15. Aug 7, 2020 at 7:37 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I'd you have calipers you can take dimensions and purchase online. McMaster Carr is a good place to start.
  16. Aug 7, 2020 at 7:39 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    For once I don't totally disagree with your half assed suggestions. If the hole on the flange isn't too wallowed out it shouldn't be a problem until he gets a new stud. But I wouldn't run it like that long term
    Kevins60, SwampYota, Fernando and 4 others like this.
  17. Aug 7, 2020 at 7:41 PM
    DashMaple
    Louisiana
    What I find interesting is the 2wd driveshaft uses nuts and bolts but the 4wd uses studs.
  18. Aug 7, 2020 at 7:49 PM
    Running Board Man
    He could take the stud 180 degrees away from it out and put the same nut and bolt there so whatever minute harmonic imbalance results is mitigated
    I'm not wrong
  19. Aug 7, 2020 at 7:56 PM
    vonellis
    Some and some more
    Washed the uni , quick photo shoot, Max photo shop.
    Bridge4, BYJOSHCOOK, JKO1998 and 8 others like this.
  20. Aug 7, 2020 at 8:03 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Max ballin:cool:
