  1. Aug 11, 2020 at 11:54 AM
    eon_blue
    Azusa, CA
    Aren't CVJ axles just rebuilt OEM ones? With the option of getting silicone boots
    Up until recently you could order rebuilt OEM CVs from Toyota but they are apparently discontinued, though I was able to get one locally as recently as about 6 months ago. Was probably just old stock at the local dealership. I think the price is/was the same as the basic option from CVJs website from what I recall seeing.
    Anyway I don't know if calling them stronger is better, assuming they are just rebuilt OEM. But definitely better than any parts store axle
    As for the silicone boots, I've never run them but I know I've seen some good/bad reviews on here from people who have.
    Wulf likes this.
  2. Aug 11, 2020 at 11:56 AM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    This is the assumption I always had.
    OEM axles, but can opt for better boots, boot slide mod, etc.
    eon_blue[QUOTED] likes this.
  3. Aug 11, 2020 at 12:01 PM
    eon_blue
    Azusa, CA
    Yeah from what I'm reading online it seems that is what they are.
    RCV makes stronger CV axles for Tacomas...but then comes the argument that you're more likely to break something more expensive if the CV axles are no longer the weakest link. Not saying I would know one way or the other as I've never run them, and probably never will at $2,000 per set
    https://www.rcvperformance.com/axlesets/toyota/toyota-ifs-rcv-axle-set.html
    Wulf and riskadverb like this.
  4. Aug 11, 2020 at 12:08 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    :rofl::rofl::rofl:
    Yeah... nope. I’m not paying that kinda money to possibly grenade my diff instead of a CV.
    Wulf, eon_blue[QUOTED] and riskadverb like this.
  5. Aug 11, 2020 at 12:10 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I kind of look at the CV as the fuse.
    Putting a 30 amp fuse on a 15 amp circuit doesn't normally turn out well.
    RCV is a 30 amp fuse.
  6. Aug 11, 2020 at 12:10 PM
    MattJakobs
    Matthew
    NorCal
    There's also Lotus Development. They build their axles with a beefier outer cage and race. Still looking at roughly $1200 for the pair. If I'm spending that kind of money, I'm going RCV.
    http://lotusdevelopmentllc.mybigcom...er-1st-gen-tacoma-single-chromoly-caged-axle/
    @theesotericone is running RCVs with no problems that I know of. And he wheels.
  7. Aug 11, 2020 at 12:11 PM
    eon_blue
    Azusa, CA
    Yeah I was just about to tag him as well, I remember him saying recently he hasn't broken one yet and he's definitely hard on his rig
    theesotericone likes this.
  8. Aug 11, 2020 at 12:13 PM
    Wulf
    rock raisin
    Removed the e locker motor and slid the fork over to unlock the diff
  9. Aug 11, 2020 at 12:13 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Oh I didn't know that. Should have researched them a bit more. I'd just always head about people running them and was curious.
    There's also these I found. https://lotusdevelopmentllc.mybigco...er-1st-gen-tacoma-single-chromoly-caged-axle/
    EDIT: @MattJakobs beat me to it with those axles
    MattJakobs and eon_blue[QUOTED] like this.
  10. Aug 11, 2020 at 12:20 PM
    eon_blue
    Azusa, CA
    assuming you can't get a rebuilt OEM one from a local Toyota dealer then I would personally go the CVJ route since the price is the same. Just have to ship them your old core if you want the core charge back
  11. Aug 11, 2020 at 12:26 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    If you going to go with stronger CV's RCV is the only way to go. Lotus left the inner joint stock. I've personally broken 4 at the inner joint. RCV lifetime warranty. Lotus 1 year warranty. I wonder why?
    I'm not getting into the "fuse" debate. If you change to a stronger CV the diff is not the weak point. The ADD tube and stub shaft are. Again, I've seen the damage from real world use when a buddy grenaded his ADD tube. There's not enough data because no gear company has ever tested their gears until failure. Once you go ARB the spider gears and carrier are strong enough to break chromoly shafts. ARB has tested that.
    In 3 years of being dual cased I've had the following happen.
    On stock and auto parts CV's I had 11 failures in 1 1/2 years. 5 of those where OEM axles. 4 broke at the inner. 7 broke at the outer. All of those where on 295/70/17(33.5")
    In 1 1/2 years of running RCV's I've had no breaks. I have no issues with the front diff or ADD tube. 1 year of that was on Pitbull Rocker radial 35's. They are a true 35 at 35.25" at 32 PSI with the weight of the rig on them.
    I am very glad I got rid of that stupid fucking fuse. lol
  12. Aug 11, 2020 at 12:27 PM
    betterbuckleup
    Ian
    Concord, CA
    I actually was able to find some. Was hoping to find one new, but seems like you cant with the manual hub CVs.
    Not too bad of a price. CJV wants way more.
    https://parts.conicellitoyotaofconshohocken.com/oem-parts/toyota-axle-assembly-434300401084
  13. Aug 11, 2020 at 12:29 PM
    eon_blue
    Azusa, CA
    I think that price is after you return the core though, you have to cough up the $75 core charge up front so it's actually closer to $200 until you bring the core in or ship it.
    But still way cheaper than a brand new OEM axle.
    First time I ordered a reman OEM from the dealer they sent me a manual hub reman by mistake, I didn't check it closely enough and didn't realize it until I got it installed and tried putting the axle nut on. That sucked, lol.
  14. Aug 11, 2020 at 12:35 PM
    betterbuckleup
    Ian
    Concord, CA
    yea I know, still best price i've been able to find on an OEM.
    If I start breaking a bunch of manual CVs i'm just gonna swap to ADD spindles & OEM ADD axles and leave my manual hub diff tube in so I don't have to worry about the ADD stub shaft. Would hate to blow that up on a trail lol. My front DS will be spinning all the time, but it's not my daily anymore so I figure that's an OK trade off to make.
    I know of one other guy that runs his front like that and he's on 37's with a SC and dual cases and he smashes a lot of rev limiter lol
    jubei and eon_blue[QUOTED] like this.
  15. Aug 11, 2020 at 12:35 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    We’re those breaks when you were when you had your locker engaged?
  16. Aug 11, 2020 at 12:38 PM
    theesotericone
    Bishop CA
    Only 4 of those happened with the locker on. Maybe 5. It's hard to remember when you break that many. lol
  17. Aug 11, 2020 at 1:36 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    I was going to say that’s a lot of breaks. Figuring most people will go wheeling once a month for say 10 months out of the year, your almost at a broken cv a trip. Almost doesn’t sound fun. Now you probably wheeled way more than that but just throwing out a general number.
  18. Aug 11, 2020 at 1:36 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Go to a junkyard and get an oem cv for $50. No sense in buying brand new if there's a good chance of breaking one again.
    razhick4x4 likes this.
  19. Aug 11, 2020 at 2:01 PM
    johnnywideopen
    johnnywideopen Well-Known Member
    Johnny
    San Diego
    2002 2.7L SR5 4x4 manual extra cab
    Swap done! New bearings, new inner and outer hubs, spruced up and gusseted spindles, oem cv’s, Camburg uca’s. It’s at the alignment joint.0DD07E02-EE92-42D4-9EDA-8E39FC8EE5D3.jpg
    (The hub caps fit over the wheel spacers for stealth mode)
    BYJOSHCOOK, nagorb, megalodon and 8 others like this.
  20. Aug 11, 2020 at 2:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :drool:
