  1. Aug 11, 2020 at 2:17 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    thats a really hot combo
  2. Aug 11, 2020 at 2:18 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    Went to the junkyard and found 4 3rd gen 4runners. Grabbed some bump stops.
    One has 4wd ADD. Is it worth it to grab the spindles and cv axles?
    Disappointed that there isnt more parts that can be used between them and our 1st gen. I thought for sure I could use the wiper motor.
  3. Aug 11, 2020 at 2:23 PM
    eon_blue
    Azusa, CA
    Definitely. You could sell those spindles and especially the CVs on here easily I bet if they're in good shape.
  4. Aug 11, 2020 at 2:58 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    3rd gen 4runner CVs swap over to our trucks, but have a thinner shaft diameter.
    JoeyWales[QUOTED] likes this.
  5. Aug 11, 2020 at 3:05 PM
    JoeyWales
    SC
    It was actually pretty clean. I’ll go back tomorrow. What would be a normal asking price?
  6. Aug 11, 2020 at 3:06 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    What'd you say about my shaft?
    osterhagen and betterbuckleup like this.
  7. Aug 11, 2020 at 3:07 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    He's saying that trucks do it better ;)
  8. Aug 11, 2020 at 3:17 PM
    eon_blue
    Azusa, CA
    for used ones I see prices kind of all over the place, there should be a bunch of old listings for them in the buy/sell/trade section though that you can reference
  9. Aug 11, 2020 at 4:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You know it's really funny that you used the rebuilt hubs vs the brand new in box set :rofl:
  10. Aug 11, 2020 at 4:21 PM
    jrenzii93
    jrenzii93 Member
    Josh
    2002 Toyota Tacoma
    First post here. Been a Toyota fan for years though. Finally finished up a back seat extension for the doggo to make trips more comfortable for her. I think she approves!
  11. Aug 11, 2020 at 5:05 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    It was a lot of CV's. It was also a lot of miles. Where I live I can go wheel after work and be back in time for dinner. I do that a lot. Last year I put about 5000 miles on my rig. Well over half of that was dirt and about 500 of it was hard crawling.
    I got to the point that I could have a CV swapped and be rolling in 15 minutes or less. I'm glad I learned how to be efficient at it but I'm also glad I haven't had to do it again. lol
    malburg114[QUOTED] likes this.
  12. Aug 11, 2020 at 5:20 PM
    MattJakobs
    Matthew
    NorCal
    It takes me that long to jack my car up and get a wheel off.
  13. Aug 11, 2020 at 5:25 PM
    Madjik_Man
    Colorado Front Range
    Hey man... they’ve always told me “size doesn’t matter...”
    :mad:
  14. Aug 11, 2020 at 5:29 PM
    theesotericone
    Bishop CA
    You learn a lot the first 3 times. The next 3 you perfect the sequence. The final 5 I was just racing to beat my own record. lol
    Have you seen my factory bottle jack with a 21mm nut welded on the crank handle? You place that under the LCA. Drop your 21mm, the same size as the lug nuts, impact in your 1/2 drive cordless. Raise the wheel via the LCA. Remove the lug nuts. Remove the wheel. Grab the 1/4" drive impact with a 14mm and remove the 4 LBJ bolts. Pop the axle dust shield off. Pull the axle retainer nut cotter pin. Put the 35mm on your 1/2 drive and back off the axle nut. Swing the spindle clear. Grab the 18" prybar and free the inner cv from the diff. Throw the new CV in. Reverse the process. Yeah, it's that quick. lol
  15. Aug 11, 2020 at 5:49 PM
    johnnywideopen
    johnnywideopen Well-Known Member
    Johnny
    San Diego
    2002 2.7L SR5 4x4 manual extra cab
    You know it’s because the red centers just hit different fam. (trying to use young people lingo)
  16. Aug 11, 2020 at 5:59 PM
    JoeyWales
    SC
    Down to a science. Like when I order food from Cook Out...
    Blue92 likes this.
  17. Aug 11, 2020 at 6:26 PM
    MattJakobs
    Matthew
    NorCal
    You only bring your factory bottle jack? No hi lift?
    and no, I haven’t seen it
    Hot damn, I miss cook out.
    Chicken strips tray
    Hush puppies
    Cheese quesadilla
    Cheerwine float
  18. Aug 11, 2020 at 9:17 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Did the same thing. Welded a 1/2 in nut to my factory bottle jack so a 3/4 in deep socket will raise the truck and take the wheel off. Way safer than a hi lift and cordless tools make everything faster. Having everything easily accessible helps a lot too.
  19. Aug 11, 2020 at 9:19 PM
    malburg114
    Las Vegas, NV
    Hi lifts are over rated. Stock bottle jack works fine and if your inexperienced with a hi lift, the bottle jack is way safer. Plus you don’t have to droop out the suspension and have the truck lifted sky high.
    my next thing is to get a hf aluminum jack and put a skid on it and mount that to make it even easier.
    MattJakobs[QUOTED] likes this.
  20. Aug 11, 2020 at 11:42 PM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
