  1. Aug 12, 2020 at 8:48 PM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Hello....I purchased new, and have always kept it clean. That’s why it takes me forever to do anything mechanical on my truck because I clean everything as I go. Manifold isn’t painted. Just keep it and the throttle body polished.
  2. Aug 12, 2020 at 8:51 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Question about brakes: I put slotted and drilled rotors on my gfs second gen and when braking at low speeds makes a clunkish/popping noise. Is this normal? Brakes fine the rest of the time
  3. Aug 12, 2020 at 9:34 PM
    Dan8906
    Daniel
    Concord, California
    They brake good overall. I mean everything is tight, so I’m not worried about them being installed wrong. Seen this online so maybe it’s normal? Not sure
  4. Aug 12, 2020 at 9:39 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Did you bed the brakes after install?
  5. Aug 12, 2020 at 9:44 PM
    Dan8906
    Daniel
    Concord, California
    I just gave a couple speed ups and slow downs around the block. So I didn’t properly bed the brakes, was too hungry for dinner
  6. Aug 12, 2020 at 9:51 PM
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    Hit this milestone on the way back from a long road trip. And then immediately ran out of gas in the middle of nowhere Utah after leaving Colorado.
    Also managed to crack the front upper cross member / core support at some point when I was wheeling. Guess it's time for a drill and weld.
  7. Aug 12, 2020 at 9:54 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It's just the start of things to come! :devil:
    Give your body mounts a good look on the core support.
    Burro[QUOTED] likes this.
  8. Aug 12, 2020 at 10:01 PM
    Burro
    SoCal
    98 v6 4x4 xtracab
    Are bad body mounts known to cause more flexing in the core support leading to cracking? If mine are bad what's the go to replacement, OEM or poly?
  9. Aug 13, 2020 at 12:05 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I put a piece of 1” x 1/16” or 3/32 angle iron to support my hood pin plate I made, if you cut enough of the angle iron to fit in and around the various nutserts / threaded hole thing-a-mabobers, hood height adjusters, and anything else in the way you can reinforce that core support. I used 5/16 bolts and used factory holes and a couple of my own. You can’t see the angle iron since it’s in the core support - but where I drilled / used holes is visible here under the hood pin holder. That core support is paper thin so welding it is like putting a piece of scotch tape on it imo - not that it would hurt to of course. That area is flimsy af though.
  10. Aug 13, 2020 at 6:35 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The valve covers don't match now.
  11. Aug 13, 2020 at 6:54 AM
    jammer
    Ben
    Bentonville, AR
    I know right!
    cruiserguy likes this.
  12. Aug 13, 2020 at 7:37 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Jeezus. Me next? Lol
  13. Aug 13, 2020 at 8:04 AM
    Dan8906
    Daniel
    Concord, California
    That’s what mine looks like lol
    Fernando[QUOTED] likes this.
  14. Aug 13, 2020 at 8:09 AM
    jammer
    Ben
    Bentonville, AR
    Holy Cow! Fernando, that would be a definite challenge!!! I'd be like a deer in the headlights....."where do I start??"
    I think in all my years of being on this forum, you may have the dirtiest motor!
    Fernando[QUOTED] and Phessor like this.
  15. Aug 13, 2020 at 8:31 AM
    Dan8906
    Daniel
    Concord, California
    Bedded properly this morning, seems to have cleared the issue.
  16. Aug 13, 2020 at 8:59 AM
    razhick4x4
    razhick4x4 Well-Known Member
    Alex
    MT/WY
    2004, Tacoma SR5 Xtracab TRD, 4x4, Red, 5spd. V6
    ARB Bumper, 3" Toytec/OME lift, 33s, Sliders, ARE Topper, Ditch Lights, Hella LEDs, Trigger controller, CB, Pioneer Radio
    not exactly today but yesterday I drove over from Seattle to Bozeman. truck did great, but at the higher altitude and on some of the steeper grades i could definitely feel the high gearing...
    On the way over in Eastern Washington:
    and taking a break in Northern Idaho:
    Also saw this old car off in the bushes didn't get close enough to see what it was since there were about 8 different no trespassing signs at the mouth of the road it was off of but cool nonetheless:
    SwampYota, vonellis, jubei and 4 others like this.
  17. Aug 13, 2020 at 9:12 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You picked the worst rest stop in Eastern WA, that little valley right before the hill always smells like manure and it has zero services nearby haha. Should've stopped at Exit 272 and said hi
    razhick4x4[QUOTED] likes this.
  18. Aug 13, 2020 at 9:14 AM
    razhick4x4
    Alex
    MT/WY
    thanks for the info! i was just trying to get there in one day so stopping wasn't real high on my priority list but i'll be making trips back and fourth to seattle at least once or twice a year. i'll need to check it out one of these trips though! Idaho was one of the most beautiful places that I drove through on the way over. Almost made me rethink my choice of school since i also got into the University of Idaho in Moscow:D;).
    DashMaple likes this.
  19. Aug 13, 2020 at 9:16 AM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    I've been to Idaho once, 6 years ago. Been all up and down the east coast, smokey mountains, moab, colorado. Idaho is still #1 on my list to go back to, really a hidden gem
  20. Aug 13, 2020 at 9:16 AM
    razhick4x4
    Alex
    MT/WY
    yeah, it wasn't ideal lol. main reason that we stopped there was because of my parents. My mom wanted to do the whole thing in as few stops as possible as she's spooked by this whole Covid thing, while my dad wanted to stop here and there to stretch and use the bathroom. so we settled on the rest area in the middle of no-place with almost no one at it:rolleyes:.
    Speedytech7[QUOTED] likes this.
