  1. Aug 18, 2020 at 4:45 PM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    Yeah I hear you on the getting older thing and the RTT. Plus for us, it actually stopped us several times from camping in spots because of shit on the ground and so forth. RTT is really gonna be a great option but I am gonna get a flat one as I don't care for the brick looking ones. Likely will mount my solar panels to the top of it but we shall see. We also want to do a fair bit of winter camping and being up off the ground and having the heated blanket should really help with that!
    nagorb[QUOTED] likes this.
  2. Aug 18, 2020 at 4:49 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Well that was cool to come back to - just got back from the Olympic Peninsula, for a pretty awesome hike up amongst the peaks.
    Nice. What are you getting? Xtracab so you can move the GFC over? I'll be there someday, I'm sure.
    osterhagen likes this.
  3. Aug 18, 2020 at 4:52 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    No, and now I feel real stupid. Didn’t realize there was more to it, other than install and adjust idle speed. :(
  4. Aug 18, 2020 at 4:58 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    For anyone running a Satochi grill, here is a little trick to make it easier to get the hood open.
    SwampYota, nagorb and NV.ENGINERD like this.
  5. Aug 18, 2020 at 4:59 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's not tough but it's pretty much required. The FSM is pretty clear on the procedure. As a rule you should never have to adjust the idle screw on a Toyota EFI vehicle from where it came from the factory.
  6. Aug 18, 2020 at 4:59 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I don’t think it exists for an 04 since Toyota thought it was a good idea to make some kind of shitty half assed electronic throttle.
  7. Aug 18, 2020 at 5:02 PM
    Speedytech7
    It may not since Toyota considers the ECTS-i to be non end user serviceable. Toyota says you must replace the entire throttle body on those :/
  8. Aug 18, 2020 at 5:17 PM
    JoeyWales
    SC
    Of course they do....$$$
    Speedytech7[QUOTED] likes this.
  9. Aug 18, 2020 at 5:18 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I drilled out the spot welds on the stock tabs and welded my own sheet metal back onto the bracket for my 24F AGM. It's been working fine for years.
    :brianr:
    It's not that bad...
    ...at the moment.
    Exactly. GFC will get swapped immediately, but I'm not building this one out that much. It will stay as the dedicated camping/adventure/fishing setup, not technical wheeling.
  10. Aug 18, 2020 at 6:42 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Its a gear reduction box, like a transfer case but without the driveshaft connection point, that mounts between your transmission body and the transfer case. if you've ever seen videos of people "ghost riding" their trucks, that's thanks to a crawl box.
    bblindt79[QUOTED] and Fernando like this.
  11. Aug 18, 2020 at 6:56 PM
    paetersen
    paetersen Well-Known Member
    Got tired of the slightly sagged rear end with camper shell, bed platform, bikes, camping gear in the back, and I won't even get into the on-the-bumpstops ride when I haul firewood. Wheelers 2" AAl and 5100's. because of sagged springs I actually went up 2.25, the 'settle' will be good. BTW, their included 'center pin' is the cheapest shit garbage chinese dogshit, do not use it. Their pin stripped at 28ft/lbs. How do I know? Because my $600 Snap-on torque wrench tells you real time data on how much torque is applied...
    Jiveydude, SwampYota and Seagull233 like this.
  12. Aug 18, 2020 at 7:54 PM
    Madjik_Man
    Colorado Front Range
    That's what they all say...
    ToyotaDriver, turbodb and nagorb like this.
  13. Aug 18, 2020 at 8:28 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Dual cases. Crawl box. Turtle speed. All the same
    Makes you ghost ride the whip over the boulders :p
    bblindt79[QUOTED] likes this.
  14. Aug 18, 2020 at 8:51 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Ahh, I see. Igor Jr., except bigger ;). We all know how that goes... Well, @Blackdawg does anyway. :rofl: :luvya:
    In all seriousness though, that sounds like a great idea to me and I think you'll be super happy as long as you can keep the speed down a bit. Or air down a little more than you did when we were around last year. Will we see it this year?
    ^^^ this guy gets it.
  15. Aug 18, 2020 at 8:55 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    he won't be able to resist all the different suspension options. It'll get baby long travel for sure.
    and i changed the oil in my SX DD. Used the Fumoto valve thing for the first time. Was nice. Drains slower but still really conveiant. Just need to relocate the oil filter and then my life will be easy for that. Now that im driving to work again.
  16. Aug 18, 2020 at 8:55 PM
    Squeaky Penguin
    Brett
    In a couple weeks if all goes to plan.
    And I've learned my lessons. I'm setting out with clear goals and expectations for this rig this time that I didn't have previously. Plus, the 1st gen will be around when I really want to wheel.
    turbodb[QUOTED] likes this.
  17. Aug 18, 2020 at 9:18 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Nice. Have been considering one of those for draining (I don't care if it takes a few minutes), and the 90 degree that Zane got for the oil filter.
    Want to try it first? I haven't ordered yet. Want someone else to be the guinea pig. As he said to me: "If it doesn't work, returns are free through Summit" :)
    https://www.summitracing.com/parts/fms-m-6880-a50?seid=srese1
    Or, free returns and shipping (sort of, given that it's $10 more and out of stock) at the 'zon: https://amzn.to/34eHHA2
  18. Aug 18, 2020 at 9:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I just don't see the point of that. Im going to relocate mine to the wheel well. Its a DD and the filter can mount to the back side of the front body mount frame horn. Plenty of room and won't hang below the bumper if done right. That way its just right there.
    The 90 degree one will still make a freaking mess over everything so whats the point.
  19. Aug 18, 2020 at 9:35 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I figured that the 90 degree one would make it so the filter holds all the oil when you unscrew it. Pictures > words. :notsure:
  20. Aug 18, 2020 at 9:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oil is still going to come out of the mount though. Won't be tons sure but enough that over time be oil everywhere anyways. Id rather just be able to reach under the bumper and swap it out.
    Running Board Man likes this.
