  1. Aug 21, 2020 at 4:34 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Good for u
  2. Aug 21, 2020 at 4:35 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Woah woah woah... I didn’t say you’d use it... I said you’d show it to your friends.
    JoeyWales and cruiserguy like this.
  3. Aug 21, 2020 at 4:40 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    My visions blurry :(
    BeLance89[QUOTED] likes this.
  4. Aug 21, 2020 at 4:43 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Just stick a glob of clay on the highest point of your motor, and close the hood. Open it back up and the height the clay got squished down to is how much room you have.
  5. Aug 21, 2020 at 4:44 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I believe the flanges are the same. The lengths shouldn't matter much if your going to shorten it. I have one from a 4r, can't remember the year.
    jubei[QUOTED] likes this.
  6. Aug 21, 2020 at 4:48 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Mind you this was my second full swap from removal to placement. Once before with a 22R. I've pulled engines before or added engines.
  7. Aug 21, 2020 at 4:58 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Thanks, Ryan!
  8. Aug 21, 2020 at 6:55 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Should be the same assuming it's the same transmission
  9. Aug 21, 2020 at 8:30 PM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    After what seemed like 30 hrs, 600 dollars, few broken bolts, 20 trips to Toyota, I’m finally done with the project.
    Replaced upper/lower ball joints, rotors, pads, spark plugs, air filter, oil change, and rotated tires.
  10. Aug 21, 2020 at 8:54 PM
    BeLance89
    Brandon
    Huntsville, AL
    I changed my oil with the Purp and some Lucas because my block is thoroughly worn in at 325k. ended up using 3 1/2 quarts of oils and 1 1/2 quarts of the Lucas.
  11. Aug 21, 2020 at 9:29 PM
    Panchovilla6192002
    Arizona
    Yes. Definitely good feeling.
    Cleaned up what I could get to, and repacked inner/outer ball bearings too. I’ll redo the back brakes when winter comes.
  12. Aug 22, 2020 at 3:56 AM
    Noob95.5
    Noob95.5 Well-Known Member
    96 xtra cab 3.4l 4x4 manual
    Wire brush, Sandpaper, sanding block, aluminum polish. Compound
  13. Aug 22, 2020 at 6:23 AM
    Natenite
    Natenite Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    This is what I’m looking into. Any issues so far with the bigger battery? Was the tray easy to install? Where did you find the tray? Thank you!
  14. Aug 22, 2020 at 7:03 AM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    Just sanded primed and used some quality rattle can paint. Light coats until it was solid.
  15. Aug 22, 2020 at 8:13 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Just starting the replacement of a CV with a bad boot, and swapping in OME 883's for the 881's which were not up to a plate bumper and winch. Watched @Timmah! video. But he leaves out one of the most important first steps (at least for us East coast guys). Pull the wheels, and break out the pressure washer for about a half hour, to get rid of the accumulation of red clay mud. I wish I had videoed that process, as you desert guys would not believe what gets stuck all over everything.
  16. Aug 22, 2020 at 9:51 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Is the “vibration” coinciding with a change in engine speed? Usually people say they’re feeling a pulse or a shudder when anything is misfiring.
    Dan8906[QUOTED] likes this.
  17. Aug 22, 2020 at 10:40 AM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    After a few outings I realized the truck needed a slight bump in spring rate, so a quick trip to the shop and they got them swapped in quick along with my AGM sliders.
    This is not something I can do at home anymore with my bottle jack!! :rofl:
    Truck now sits level, even with a good amount of gear, so far so good!
    Uppers:
    16" 350lb
    was
    14" 300lb
    Lower:
    18" 400lb
  18. Aug 22, 2020 at 10:49 AM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Can anyone help me confirm that 3rd gen 4runner e-locker axles shafts are interchangeable with my '99 elocker axle shafts? I swapped some 3rd gen 4runner axles shafts in my truck a while back, but it's been brought to my attention that the axles shafts between the 4runner and tacoma are different part numbers. I hoping that I haven't screwed up. Everything looked the same at the time, but I did not compare shaft lengths.
  19. Aug 22, 2020 at 11:31 AM
    BeLance89
    Brandon
    Huntsville, AL
    Your rear suspension is what my dreams are made of. Lol. Very nice set up man.
    Dalandser likes this.
  20. Aug 22, 2020 at 11:36 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Even if the length is the same the bearings may be different
    Running Board Man likes this.
