  1. Aug 25, 2020 at 4:16 PM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    Yeah see, but that requires some gumption lol. I just decided to leave mine off during the rebuild of the front end. I have the OME 883's and I don't do fast corners anyway... it doesn't seem to have much roll for what I do anyway
  2. Aug 25, 2020 at 4:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I run stock suspension with a spacer on the 99 am without a sway bar, doesn’t bother me.
    But this is my commuter for school so I better not.
    Phessor likes this.
  3. Aug 25, 2020 at 4:19 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    How often do you guys change your diff gear oil? Preferably for those who wheel their trucks.
    Cause I know you can get away with a lot longer intervals if you're just driving it to and from work & all that.
  4. Aug 25, 2020 at 4:20 PM
    eon_blue
    Azusa, CA
    I do it once a year, so every ~15k miles give or take
  5. Aug 25, 2020 at 4:21 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    30k miles. That's with ADD too so my front diff is always moving when I'm moving
  6. Aug 25, 2020 at 4:24 PM
    JKO1998
    Utah
    I just found it was easier to replace the diff.
    riskadverb, Phessor and eon_blue like this.
  7. Aug 25, 2020 at 4:25 PM
    betterbuckleup
    Ian
    Concord, CA
    Ooof
  8. Aug 25, 2020 at 4:26 PM
    JKO1998
    Utah
    It modded a drain hole into Itself
  9. Aug 25, 2020 at 4:41 PM
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Do you run diff breathers? Synth or Dino oil? Wheeling isn't all equal IMO. I assume you are meaning a more hardcore style of wheeling, in which I could see that having a much greater impact. Otherwise I "wheel" my rig but I doubt I abuse my diff oil much more than street driving.
    The way I see it is, folks usually approach it one of two ways. They either run Synthetic and try to go longer intervals between changes and hope for improved protection during that time. Or they run Dino, tried and tested and change fluid more frequently.
    The way I handled this during my trucking days was to test the oil to figure out interval. So I might likely do something the same with my Tacoma. Pick a reasonable and conservative change interval to start and save a sample of the fluid for examination by a qualified lab. If you get the results back and no issues and oil stability is still high, add more time before the next change. This will give you other insights into the condition of your diff also.
    But I bet someone will be along soon to explain a much better and simpler means of doing it :)
  10. Aug 25, 2020 at 4:46 PM
    betterbuckleup
    Ian
    Concord, CA
    True. Lots of variables. I run Lucas 85w-140. ARB air lockers f&r. Definitely hard on them.
    I currently get my engine oil analyzed, but should really do that for all the fluids ideally.
  11. Aug 25, 2020 at 4:50 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Just take it off long enough to figure out if it’s causing the noise. Don’t corner hard while it’s off and you should be fine.
    JKO1998[QUOTED] likes this.
  12. Aug 25, 2020 at 4:55 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    How much does it cost to get your oil done? Do you use blackstone? I think that’s the name
  13. Aug 25, 2020 at 4:57 PM
    Dan8906
    Daniel
    Concord, California
    I think you nail the explanation!
  14. Aug 25, 2020 at 6:25 PM
    Aagill225
    Aagill225 Well-Known Member
    Arthur
    2004 Tacoma PreRunner
    None
    I’ve changed mine once in the last 40k who knows how many times it was done before. Wasn’t my truck then.
  15. Aug 25, 2020 at 7:46 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Sway bar??? Whats that? Should i add that too my list?
    I was doing every 25k.....i may be way over now. My back issues had made me a lazy fucker. Those skids are heavy..lol
  16. Aug 25, 2020 at 8:17 PM
    JKO1998
    Utah
    I’ve got a spare if you need it
    osterhagen likes this.
  17. Aug 26, 2020 at 6:06 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :rofl:
    :burnrubber:
    :crazy:
    JKO1998[QUOTED] and osterhagen like this.
  18. Aug 26, 2020 at 8:20 AM
    neucase_fredo
    neucase_fredo Active Member
    Alfredo
    Did my Downstream sensor today on my 02’ manual V6.
    Thanks to a swivel ratchet with a long socket I did the job in less than 30 mins. Ofcourse I didn’t have to deal with any rust.
  19. Aug 26, 2020 at 8:23 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Once a year... actually, this year I've done it twice on the rear axle. lol
    I change the oil in the diff, and tcase in the winter. Also drain and fill my trans at the same time. (this year the rear has been done twice because I had to replace the axle bearings) (I'm not to worried about replacing front diff oil, cause I'm manual hub)
  20. Aug 26, 2020 at 8:49 AM
    betterbuckleup
    Ian
    Concord, CA
    I think it's $30 now. You can have them send you a free kit.
    I'm manual hub as well. So the front diff will be a way longer interval than other fluids in the truck.
    Seems like 25-30k is a good round number to shoot for based on the range that everyone does theirs at. Thanks for the input guys.
