  1. Sep 4, 2020 at 10:55 AM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Heard y’all like toe...
  2. Sep 4, 2020 at 10:57 AM
    eon_blue
    Azusa, CA
    I can't bring myself to click like on this statement
  3. Sep 4, 2020 at 12:07 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    This was after doing ote's, I counted the threads and marked everything off the old ones position. Apparently I just suck at counting and coloring haha.
  4. Sep 4, 2020 at 12:09 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    The BPV isn't really that big of a deal. You just use the base as a template for the holes, drill, and tap the inside of the frame plate... I used the original mounting bolts.
    That is a good point about the spare... if you don't want to relocate it, boxing the frame isn't a good option.
    1997tacomav6 likes this.
  5. Sep 4, 2020 at 12:10 PM
    eon_blue
    Azusa, CA
    I had the same thing happen. Actually it turned out the new OTRE's I got (OEM from dealer) had slightly less threads on them than the ones I took off, so my counting didn't help much. Just had to drive it a couple miles to the nearest Firestone for a toe 'n go and it was good.
    Captain Magma[QUOTED] likes this.
  6. Sep 4, 2020 at 12:54 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Did you use the lowers I sent you?
  7. Sep 4, 2020 at 12:59 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    That’s next summers project... Ran out of time
    Tour991[QUOTED] likes this.
  8. Sep 4, 2020 at 2:48 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Much more helpful, thank you.
    Silver02Taco and BeLance89 like this.
  9. Sep 4, 2020 at 5:14 PM
    Madjik_Man
    Colorado Front Range
    is that a Rhino Rack on top?
  10. Sep 4, 2020 at 5:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wow finally selling those. Interesting
    Silver02Taco likes this.
  11. Sep 4, 2020 at 7:29 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Yes, I’ve had it for a little over two years now. No complaints. Put it through a lot of abuse, still looks great.
    Madjik_Man[QUOTED] likes this.
  12. Sep 4, 2020 at 8:03 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Pretty happy with my titanium 125 from harbor freight. If you don't mind the spatter from flux core it'll do most things we need on a truck for under $200. Great starter setup in my opinion.
    Also, my frame is boxed and it's bent in front of the spring perch. That's the factory boxed section and the fulcrum when trying to climb ledges... Might be worth reinforcing for those who aren't afraid of pushing there rigs.
    jubei likes this.
  13. Sep 4, 2020 at 8:36 PM
    1997tacomav6
    Denver
    I don't know if its s regular cab thing but the top shock mount has no drain and is welded to the frame, my truck has zero rust but now
    Is showing some rust on this mount area.
    So it needs to be cut out, All the Tacomas with this mount will rust sooner or later.
    Thats why boxing it would be better with drain holes under.
  14. Sep 4, 2020 at 8:49 PM
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
  15. Sep 4, 2020 at 8:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Definitely a single cab feature.
    I'd just drill a drain hole and be done with it.
    I'll have to check mine out.
  16. Sep 4, 2020 at 9:24 PM
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
  17. Sep 4, 2020 at 9:51 PM
    Bolt Head
    Colorado
    Sweet! You build that?
  18. Sep 5, 2020 at 5:31 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
  19. Sep 5, 2020 at 6:42 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Broke down and bought a CB install for a trip coming up when I get home in another week. Also vowed to not start another project or buy anything else for another project until my current projects are finalized and parts that have been sitting on the shelf are installed.
    Winkle99 and Dan8906 like this.
  20. Sep 5, 2020 at 6:52 AM
    Dan8906
    Daniel
    Concord, California
    My buddy wants me to convert from CB to GMRS. I’m thinking I’d like to get HAM instead.
    BrownMike and Yetimetchkangmi like this.
