  1. Sep 14, 2020 at 2:57 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    my thoughts exactly. It’s much easier to leave the LCA in and use a bottle jack on the UCA to press the LCA down.
  2. Sep 14, 2020 at 2:58 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    BeLance89 likes this.
  3. Sep 14, 2020 at 2:59 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    by disconnecting the ball joint and loosening the camber bolts, the lower control arm will swing down on it's own.
  4. Sep 14, 2020 at 3:02 PM
    BeLance89
    Brandon
    Huntsville, AL
    I see now, you were trying to use the weight of the vehicle and leverage of the LCA to avoid having to use a spring compressor.
  5. Sep 14, 2020 at 3:09 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Ah, so they used the X-axis. That's great news, they're sealed spherical bushings with permanent spacers machined in. Great design
  6. Sep 14, 2020 at 4:38 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    All cleaned up and ready for the 2k mile trip to Montana!
    Changed the oil, checked all fluids, rotated and balanced the tires, replaced top hats and coil isolators. Also took the 4Runner seats out and put my originals back in. Wasn’t super stoked about them.
    Also, found that my new whitelines are causing some irritating squeaking. Have to do something about that when I get back. Noticed that on both sides the rear bushings seemed to have wiggled out (?) a bit. Idk maybe I’ll just find replacements for them.
  7. Sep 14, 2020 at 8:16 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    My whitelines started developing that squeak after a bit too. Ended up pulling the arms back out and lubing the ever living shit out of them. Been quiet ever since.
    I would recommend that before changing them.
    My cams are also maxed out on both f&r for max castor so that doesn't exactly do them any good for lifetime with them being in there all cockeyed & whatnot. If yours is the same, i'd say that's normal for them to kinda squish out from the sides like that (if that's what you're referring to with the "wiggled out" description)
  8. Sep 14, 2020 at 9:36 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Finally got my order for ADS coilovers going and paid for. Hopefully it won’t take too long to get them. Excited to get rid of my Icons.
  9. Sep 14, 2020 at 9:37 PM
    betterbuckleup
    Ian
    Concord, CA
    You getting that rear relocation kit?
  10. Sep 14, 2020 at 9:39 PM
    Dan8906
    Daniel
    Concord, California
    Well, I do plan on it. Matt at MCM is still working on that. So I pulled the trigger on the fronts for now. Hopefully he gets it done by spring.
  11. Sep 14, 2020 at 9:41 PM
    betterbuckleup
    Ian
    Concord, CA
    Ah gotcha. Yea that'll be badass when he comes out with it. Great option for those who don't wanna pull the bed to weld in crossbars & box the frame
    Dan8906[QUOTED] likes this.
  12. Sep 14, 2020 at 9:43 PM
    Dan8906
    Daniel
    Concord, California
    Yeah. Might very well do that as well. Not sure. I was really set on the total chaos rear shock relocation kit and that’s not out of the picture either lol
  13. Sep 14, 2020 at 9:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You didn't happen to take any pics of this did you? Would love to see what you are describing.
  14. Sep 14, 2020 at 9:49 PM
    betterbuckleup
    Ian
    Concord, CA
    yea the TC kit would be sweet and the added stability would be nice, but I wanna run 2.5's in the rear and I would rub big time on those mounted outboard.
    My shits wide enough already, don't wanna run spacers on top
  15. Sep 14, 2020 at 10:13 PM
    Dan8906
    Daniel
    Concord, California
    It’s the only down side. But man I think the stability would be awesome.
  16. Sep 15, 2020 at 5:17 AM
    JoeyWales
    SC
    Kind of hard to see, but you can see the sleeve hanging out a bit. I pressed it in completely when I installed them. Passenger side is the same as well. The front bushings on both LCAs are still pressed in fully.
  17. Sep 15, 2020 at 5:20 AM
    betterbuckleup
    Ian
    Concord, CA
    That's pretty weird. If its pressed in, it shouldn't ever slide out like that. I'd maybe contact whiteline and see what they have to say about it.
  18. Sep 15, 2020 at 6:18 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    New hood support latch
  19. Sep 15, 2020 at 6:36 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    New clip should be under $5 from dealer
    CS_AR likes this.
  20. Sep 15, 2020 at 6:41 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Zip tie was 5 cents. the added physics is priceless
    Silver02Taco and 0xDEADBEEF like this.
