  1. Sep 16, 2020 at 5:39 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Ya its some bs hopefully I can get the cluster out with my cab cage I just bougnt the truck back had it for almost 10 years then sold it a year ago and just bought it back Sunday. Can't wait to get out of Cali with there stupid ass laws and regulations. I do have a choice illegal smog but rather do it the right way. Thankfully the smog guy was chill and didn't charge me for the test because his machine was also having problems
    Yota X[QUOTED] likes this.
  2. Sep 16, 2020 at 5:40 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    WTF!!! you have to pay each time!!! Are you serious???? Its free here at least! I would be buckin that $hit..
  3. Sep 16, 2020 at 5:46 PM
    1st4x4
    sam
    Torrance
    There are some pass or don't pay places but not many any more. Now most do a free retest within 10 days
  4. Sep 16, 2020 at 5:51 PM
    Yota X
    NW New Jersey
    1st gen
    Good luck man... I feel for ya!
    1st4x4[QUOTED] likes this.
  5. Sep 16, 2020 at 6:02 PM
    1st4x4
    sam
    Torrance
    Thanks. Hopefully the bulb is the same as either abs or airbags as those are coming out anyways if I pull the cluster as both have been removed from the truck
  6. Sep 16, 2020 at 6:03 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    They’re the same bulb
  7. Sep 16, 2020 at 6:04 PM
    1st4x4
    sam
    Torrance
    Awesome now I know ill have a extra bulb lol
    Empty_Lord[QUOTED] likes this.
  8. Sep 16, 2020 at 6:08 PM
    Empty_Lord
    Dan
    If you don’t have certain options 90% chance you have completely unused bulbs in the cluster.
    I know my non abs cluster did indeed have a abs bulb... it was brand new never used. Lol
  9. Sep 16, 2020 at 6:56 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The 5-Lug had the connector under the driver's seat for the rear locking diff. Only one of the pins were populated for an extraneous ground.
  10. Sep 16, 2020 at 7:57 PM
    1997tacomav6
    Denver
    This is on my list of things to do
    Should the metal be painted on the inside on the supports before welding or will that not make a difference, ordered a pair of these
  11. Sep 16, 2020 at 8:02 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The theory is that if you weld all the edges and holes completely, you seal out everything, so no rusting on the inside.
    nagorb and 1997tacomav6[QUOTED] like this.
  12. Sep 16, 2020 at 8:34 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    What brand of paint did you use, and does it color match ie (Lunar Mist) paint code. that's a great idea, since my center console is a little beat up, scratched and faded. Maybe a facelift will make it look better.
  13. Sep 16, 2020 at 8:39 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    that's a good question, I would think that spraying some EASTWOOD INTERNAL FRAME COATING 14 OZ AEROSOL after the welding is done. I would think the heat from welding would screw up the paint adhesion if done before welding. Maybe someone will chime in with more experience, just my 2 cents worth.
    1997tacomav6[QUOTED] likes this.
  14. Sep 16, 2020 at 8:52 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Like @0xDEADBEEF said, fully welded should not allow oxidation. Some use weldable primers, I have no experience with them and have never had a problem with proper prepped and welded plates
    0xDEADBEEF[QUOTED] likes this.
  15. Sep 16, 2020 at 9:05 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I love SoAz. This rusting discussion is not even a thought down here!
  16. Sep 16, 2020 at 9:08 PM
    1997tacomav6
    Denver
    Haha it’s a nice 61 degrees here, supercharger loves the cooler temperatures,
  17. Sep 16, 2020 at 9:09 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    How was that snow last week?
    Hard Pass
  18. Sep 16, 2020 at 9:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Loved it
    riskadverb likes this.
  19. Sep 16, 2020 at 9:12 PM
    1997tacomav6
    Denver
    The snow was fantastic, temperature was 100 degrees one day and dropped to 31 degrees.
    Getting tired of the heat, so the cooler temperatures Im looking forward too.
    Supercharger hates the hot temperatures too
  20. Sep 16, 2020 at 9:21 PM
    Empty_Lord
    Dan
    The welding will burn paint off. If it’s welded up right rust should be a non Issue
    1997tacomav6 likes this.
