  1. Sep 21, 2020 at 11:29 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Finished up our trip. Was a long slog home today. Made it home safe. Truck did outstanding all the way across and back. Wife and I are already discussing plans for our next adventure(s).
  2. Sep 22, 2020 at 10:49 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    This is happening right now! I don’t think it’s ever been changed :anonymous:
    SwampYota likes this.
  3. Sep 22, 2020 at 10:55 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    what the screen for the transmission
  4. Sep 22, 2020 at 11:04 AM
    vonellis
    Some and some more
    Anyone use this rubber gasket the transmission? Or should I stick with gasket maker? Or both?
    Yes and the fluid.
  5. Sep 22, 2020 at 11:25 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Rubber will eventually dry out and crack.
    Id just use toyota FIPG. Shits amazing.
    jammer, nagorb and vonellis like this.
  6. Sep 22, 2020 at 11:34 AM
    vonellis
    Some and some more
    Sweet thanks. I got some basic shit it has a 90 minute dry time before I can torque the pan down. Any difference in dry time ? can i torque the fipg down right away ? Newb questions
  7. Sep 22, 2020 at 11:34 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I use cork. If it’s good enough for IPT transmission it’s good enough for me. I also don’t have time to wait for something to set.
    vonellis likes this.
  8. Sep 22, 2020 at 12:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I've always just torqued shit down. Probably not the "right" way to do it haha but never been an issue for me.
    vonellis[QUOTED] likes this.
  9. Sep 22, 2020 at 12:23 PM
    vonellis
    Some and some more
    Haha right on !
  10. Sep 22, 2020 at 12:26 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    you can bring it to the dump scale on a trailer and take it off and run through again. Thats how I weigh cars and stuff like that.
    0xDEADBEEF[QUOTED] likes this.
  11. Sep 22, 2020 at 4:00 PM
    vonellis
    Some and some more
    Finished the transmission filter and oil change.The first gear whine is gone. A while back in the posts someone ask me if I would update them if doing all this got rid of it . It did the whine is gone.
    Yota X likes this.
  12. Sep 22, 2020 at 6:48 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    This.
    I've had cork leak on mine.
  13. Sep 22, 2020 at 7:03 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Added a table to the swing out, also there are two broken taps that will forever be apart of my swing out haha
    63AEF552-2A14-4A61-83EB-738CD0073015.jpg 5EC7F246-2AB8-46B1-AF37-9E028275B17E.jpg
  14. Sep 22, 2020 at 9:52 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Yes. Thats the one. Make sure to get OEM. I went with an Amazon special first and it hardly lasted a year. Also, I've never seen another dealer beat McGeorge Toyota prices...
    $228
    https://toyotaparts.mcgeorgetoyota....tKlsbBJ8GQ39HWMpoNkPlOqrTWrSSvBBoC9YEQAvD_BwE
    $226
    https://toyotaparts.bochtoyotasouth...DYf78o-PQhfMZ8j_vTBvxaLLPobIq-sRoC8LgQAvD_BwE
    nagorb and Silver02Taco like this.
  15. Sep 23, 2020 at 5:55 AM
    megalodon
    megalodon Well-Known Member
    FingerLakes Ny
    2003 v6 Ex.Cab
    started to put things back together.
  16. Sep 23, 2020 at 8:15 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    :thumbsup: Looks good.
    I think I've abandoned the table for my swing-out, since the propane bottle for my stove sits - inconveniently - diagonally behind the stove, and so makes a table hard. I've been looking for a different neck/line so I can move the bottle to the side. Until then, no pressure for a table.
    m3bassman and Das it mang like this.
  17. Sep 23, 2020 at 8:32 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Just run a hose with the right fittings
  18. Sep 23, 2020 at 9:13 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    I've looked (lazily) for one, but haven't found any. I'm all ears if you know of one that goes from a Coleman stove to a 1lb propane cylinder.
  19. Sep 23, 2020 at 9:57 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Here's what I did.
    20200923_093104.jpg 20200923_093406.jpg 20200923_094019.jpg 20200923_094027.jpg 20200923_094226.jpg 20200923_094449.jpg
    Propane distribution post
    https://www.amazon.com/dp/B002R5YRBO/ref=cm_sw_r_cp_apa_fab_aZ3AFbNW9MTFX
    Hose that runs from distribution post to stove... this will also run from stove directly to a 1lb bottle (threads are the same)
    https://www.amazon.com/dp/B001ABPB2U/ref=cm_sw_r_cp_apa_fab_x03AFbJE0TERE
    Hose I use if I am using the 5lb bottle but not using the distrubution tree.
    https://www.amazon.com/dp/B06Y5XFF6F/ref=cm_sw_r_cp_apa_fab_X23AFb529PC7C
  20. Sep 23, 2020 at 10:19 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Mr. Heater should have all those hoses/ post thing at a sportsmen’s warehouse, cabelas, tractor supply, places like that.
