  1. Sep 26, 2020 at 7:50 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    like this member says, I'd still get a quote done on it for repairs
  2. Sep 26, 2020 at 8:48 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    What year Dakota?
  3. Sep 26, 2020 at 9:07 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    1997-2004 Dakota 4x4. The individual leafs below the main leaf are a great fit. They're even off center like ours
    tortoise_taco likes this.
  4. Sep 26, 2020 at 9:22 AM
    Speedytech7
    Aaaaaaand it's old now
    vonellis, Das it mang and SwampYota like this.
  5. Sep 26, 2020 at 11:15 AM
    Speedytech7
    If your main leaf (the one that bolts to your frame) is okay, then absolutely. Just unbolt the pack and exchange a couple yota leafs for a couple Dakota leafs and you're golden. I only put 1 in per side and that alone without my usual weight was about 2" of lift.
  6. Sep 26, 2020 at 11:19 AM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    I had some help and took the shell off my truck for the first time. I have to replace the original seal. I'm getting the urge to install carpet as a headliner while this thing is off...
    SwampYota and megalodon like this.
  7. Sep 26, 2020 at 11:50 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Definitely do the carpet.
    TacoSauce04[QUOTED] likes this.
  8. Sep 26, 2020 at 11:50 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Found this in a free pile down the street.EB7E3065-AB29-4688-8798-C8BFA3699689.jpg
    SwampYota, Sebz13 and BeLance89 like this.
  9. Sep 26, 2020 at 12:00 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’ve got one you can have too
    Dan8906 and Sebz13 like this.
  10. Sep 26, 2020 at 12:51 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    nice!! Thanks the intel, the hunt begins!!
  11. Sep 26, 2020 at 1:50 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Why extended lines in the front? Geometry there is limited by the control arms, so unless you're going long travel, the stock length brake lines are all you'll ever need... regardless of lift, or a little extra droop from bushings, after market UCA, etc.
    ...at least, as far as I know.
    Speedytech7 likes this.
  12. Sep 26, 2020 at 2:00 PM
    TacoSauce04
    David
    ARE Shell
    Congrats on the new baby! I have 3 boys. 3, 5 and 11. They still fit in my DC but I'm guessing another year and the 11yr olds gotta ride in the bed.
    Tour991 and Taco critter like this.
  13. Sep 26, 2020 at 2:12 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Finally got around to buying and installing a 33 tooth Speedo gear to try and correct the speedometer from the regear. With the 30 tooth the speedometer was about 10 mph higher than I was actually going @ 65 mph. Now it’s about 3 mph higher than actual speed. So about 7-8% slower @ 65 mph. That’s with 305/70r16 tires and 4.88 gears.
    turbodb likes this.
  14. Sep 26, 2020 at 3:25 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Does anyone know if you can replace the lights in the ECT, Diff lock, hazard buttons?
    I took the dash apart today to try and find a rattle now the diff lock and hazard lights won’t work.
    I was able to get the Diff lock button light to work by banging on the dash but it went back out.
    this is exactly how the Toyota instrument lights act just before they go out for good.
  15. Sep 26, 2020 at 4:11 PM
    Shortman5
    Supercharged TRD
    Remember how many bulbs there were in the cluster?
  16. Sep 26, 2020 at 5:10 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  17. Sep 26, 2020 at 5:37 PM
    vonellis
    Some and some more
    I got two now thanks boss! what I do need though are nick nacs plastic caps for rear fold down control nob possible center console.49E93521-9431-4144-853E-A5E2A7FBB243.jpg863E4DE3-1545-4A3C-AF3B-FF458371BF45.jpg
  18. Sep 26, 2020 at 5:44 PM
    JKO1998
    Utah
    I probably could steal the knobs, interiors the wrong color though
  19. Sep 26, 2020 at 6:47 PM
    Shortman5
    Supercharged TRD
    Just replaced all 4 in the cluster. Got the bulbs out of the switches as well.
    Tlook[QUOTED] likes this.
  20. Sep 26, 2020 at 7:52 PM
    03_taco_IN
    03_taco_IN Well-Known Member
    Indiana
    2003 xtracab sr5 v6 trd
    Blue wire/ grey wire/rear diff breather mod/881s w/bilistein
    My muffler finally fell apart at the seams, and it sounds like crap. Is the pipe size 2.25 or 2.50? Was just going to order a flowmaster and weld it on unless someone has a better recommendation, thanks.
