  1. Oct 9, 2020 at 4:05 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I have the same ones. Comes with turns but not reverse bulbs. FYI the instructions it came with were wrong on the reverse bulb size.
  2. Oct 9, 2020 at 5:41 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    was the reverse bulb a different size than stock??
  3. Oct 9, 2020 at 5:42 PM
    ROlla-Xrs
    ROlla-Xrs Well-Known Member
    Roman
    Elk,WA
    1st gen Trd Tacoma
    Thats kinda cool how it matches the paint
  4. Oct 9, 2020 at 5:43 PM
    Shortman5
    Supercharged TRD
    No. I don’t think so. I believe it’s the same size as the blinker though.
    Directions said to use whatever goes in the side markers/tag lights. Spent the cash on LEDs and they were wrong. eBay seller offered to give me their cheap no name LEDs. I declined and just bought the correct size in LEDs.
    BeLance89[QUOTED] likes this.
  5. Oct 9, 2020 at 5:44 PM
    ROlla-Xrs
    Roman
    Elk,WA
    1st gen Trd Tacoma
    more important to see ahead of you rather then behind :D
    Sicyota04[QUOTED] likes this.
  6. Oct 9, 2020 at 5:49 PM
    Cali. Camper
    Cali. Camper Deserted Desert Guy
    Eric
    Arizona
    ‘00 Tacoma TRD Extra Cab
    Super charger, i8000e Warn wench, BFG km3 33”x10.50, leer shell with defender rack. 5100 Bilsteins.
    Hey folks I have oil blow to super charger, checked pcv valve good, no vacuum leaks any ideas
  7. Oct 9, 2020 at 5:50 PM
    Cali. Camper
    Eric
    Arizona
    Sorry oil blow by.
  8. Oct 9, 2020 at 8:32 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Are you sure? No possibility of bad valve stem seals?
    Running Board Man likes this.
  9. Oct 10, 2020 at 8:36 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Question.
    Are 99 3rz spindles compatible with 01 Tacomas? It's a 6lug according to the description. From looking at Toyota parts they are interchangable. Thanks
  10. Oct 10, 2020 at 8:37 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    The 22RE was never used in a truck past 1995
    nagorb[QUOTED] likes this.
  11. Oct 10, 2020 at 8:42 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
  12. Oct 10, 2020 at 8:44 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
  13. Oct 10, 2020 at 8:46 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Are the spindles the same?
  14. Oct 10, 2020 at 8:51 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Id think so provided one isnt manual hubs. But dont take my word for it.
    JKO1998 and nagorb[QUOTED] like this.
  15. Oct 10, 2020 at 11:32 AM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    New snorkel. eBay special. Pretty nice though. 858741C3-3071-4130-A269-496BED2FAF57.jpg
  16. Oct 10, 2020 at 11:37 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Got the spark plug issue fixed yesterday and changed the oil today
  17. Oct 10, 2020 at 12:20 PM
    eon_blue
    Azusa, CA
    It holds up well, mines about 2 years old now. No issues with it at all
    Yota X[QUOTED] likes this.
  18. Oct 10, 2020 at 12:31 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Yes they should be. Spindles are the same 98-04 afaik. Other than manual vs ADD. I have a set of 01 ADD spindles to go on my truck when I swap from manual hub ones.
  19. Oct 10, 2020 at 12:36 PM
    eon_blue
    Azusa, CA
    I think the ABS ones have the little bracket for the ABS line too but not a big deal either way
  20. Oct 10, 2020 at 12:56 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Did several minor jobs today. Changed the tap that I was using to trigger several of my relays for various lights and such. I found that the top left fuse inside the cab (which isn't used, at least in my version) was a switched power source, so I moved that tap in from under the hood. I had tapped into the A/C circuit out there, and if the A/C was off (almost never in my vehicle), it shut down those various devices.
    Also dabbed a bit of clear silicone on a couple of small gouges that I did to my bedliner paint job, when putting everything back together.
    Also began investigating whether seat belts can be swapped from side to side. It certainly appears that it is possible. I didn't proceed, as you must unhook the battery before messing with the wiring for the SRS tensioner. Since I am heading over for a state inspection in the next few days, I didn't want to fail because I had unhooked the battery. More to come on this!
    ROlla-Xrs likes this.
