  1. Nov 8, 2020 at 3:49 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    These led headlights are bLiNdInG in falling snow
    Not really
  2. Nov 8, 2020 at 6:52 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Better hope the "halogen or retrofit only group" doesn't catch wind of this.
    Fernando likes this.
  3. Nov 8, 2020 at 6:52 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I have found that a graphite spray is preferable to WD40 or other "wet" lubricants. It will not collect dirt. Clean everything with brake clean before applying.
    eon_blue and m3bassman[QUOTED] like this.
  4. Nov 8, 2020 at 7:05 AM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    Got it. Yeah it just seems weird that it’s not engaging and opening until the last few degrees, it’s like the handle when it was cracked.
    Anyone tried these?
    T1A Metal Upgrade Exterior Door Handle Replacement for 1995-2004 Tacoma, Fits Outside Front Left Driver’s Side, Black Color, T1A-69220-35020-METAL
  5. Nov 8, 2020 at 7:07 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I bought the cheapest handle i could find on Amazon. Its held up great
  6. Nov 8, 2020 at 7:16 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Mine is doing the same thing. I’ve had no handle now for probably a year and won’t replace it until I figure out why it’s so difficult to open. I’ve always figured the door was slightly crooked. If I get my fingers under the door and pull up it seems to open easier. I just haven’t tried to do anything about it yet.
  7. Nov 8, 2020 at 8:30 AM
    eon_blue
    Azusa, CA
    That's the brand I used last time but not the metal upgrade version
  8. Nov 8, 2020 at 9:24 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Give the latch mechanism (the part that actually holds the door closed) a good cleaning. It's best if you remove it and clean it real good. It's not really that hard to get out. You just have to disconnect the bottom of the window track on that side to give you room, and it will come out. Get the years of gunk off it and you will be able to open the door with your little finger.
  9. Nov 8, 2020 at 9:27 AM
    JKO1998
    Utah
    These don’t blind other people though, totally fine to run in normal Housings
    Das it mang[QUOTED] likes this.
  10. Nov 8, 2020 at 9:43 AM
    JKO1998
    Utah
    Silver Sluts first real attempt at finding a lion
  11. Nov 8, 2020 at 9:51 AM
    bayareayota
    Bay Area
    Prinsu 32" K02 OME
    Now another fun topic, batteries
    I know all companies have bad batteries. Optima etc.
    I was looking at the Duracell AGM SLI24FAGM. Nice 4 year warranty and a lot of locations
    Not running a winch or fridge but have some accessories.
  12. Nov 8, 2020 at 11:29 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Question... Can't remember the answer and can't find it.
    General rule of thumb, how many threads equal 1 inch lift on most coilovers. I need to raise the front AROUND 1 inch and would rather not be taking these damn things on and off all day.
  13. Nov 8, 2020 at 11:36 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Moved the reservoirs
    Before - Bearly hit at full lock.
    After
    SwampYota, 04taccoo, vonellis and 2 others like this.
  14. Nov 8, 2020 at 11:36 AM
    eon_blue
    Azusa, CA
    I want to say with my Kings it was roughly a half inch for every two threads. I just lowered the driver's side a few weeks ago because I will still rubbing my cv boot.
    I don't know about the procedure with Fox, but with Kings you can do it with them on truck. Just loosen the collar and turn it with a big punch. The UCA gets in the way a bit but it's not too bad, but again this is with Kings. I'm not familiar with how it works on Fox
  15. Nov 8, 2020 at 11:40 AM
    eon_blue
    Azusa, CA
    Actually yeah with the resis I could see it being harder to adjust ride height with the hose and fitting getting in the way
  16. Nov 8, 2020 at 11:46 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I keep thinking 4 threads equal an inch. But I'm not positive. Should be reasonably close to the same. Fox, King, Icon, Sway Away all have pretty close to the same size threads.
    eon_blue[QUOTED] likes this.
  17. Nov 8, 2020 at 12:16 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Too many variables.
    Coil strength
    Weight of your truck
    Could be 2-4 depending on that. Sadly it's a bit of trial and error
  18. Nov 8, 2020 at 12:25 PM
    eon_blue
    Azusa, CA
    Got some snow action in as well, first snow of the season in our mountains yesterday.
    Also saw a rolled 2nd gen T4R on the trail, someone had a real bad day
  19. Nov 8, 2020 at 12:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I recently adjusted my right front CO. Wanted to take out a little pre-load. I moved the adjustment collar up a 1/4" and ended up changing the ride height by 1/2".
    Kwikvette and m3bassman like this.
  20. Nov 8, 2020 at 12:56 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I pulled the 4 mud flaps and fender flares off today. Gonna Raptor Line the flares black
    Dekoy909 and hogeyphenogey like this.
