  1. Nov 8, 2020 at 1:34 PM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    Reset everything and it works like a charm! Thanks everyone
  2. Nov 8, 2020 at 2:30 PM
    bayareayota
    Bay Area
    Prinsu 32" K02 OME
    What size screw is used to secure the shift console to the body?
    #10?
  3. Nov 8, 2020 at 2:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Did it with the coilovers on the truck, wheel removed, and jacked up?
    I need to take out some pre-load as well.
  4. Nov 8, 2020 at 2:35 PM
    eon_blue
    Azusa, CA
    With Kings yes that's all you have to do, don't even need to remove the tire as long as it's jacked up. There's enough droop to get in there. UCA is the biggest obstacle but at least as far as SPCs go I can work around them
    Spray wd-40 on the threads and they turn easier, just don't loosen the collar too much or turn it too fast where it jumps threads
  5. Nov 8, 2020 at 2:36 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    To those that have gone to a newer console (from 01-04) in an older first gen (95-00), was it completely bolt on? I'm trying to do it today and it looks like new holes have to be drilled to fit the new bracket? Just curious how everyone else did it...
    Where the old bracket bolts...
    Where the new bracket would need to bolt...
    Rivnuts? Drill/tap the sheet metal? Something else? Am I missing something?
  6. Nov 8, 2020 at 2:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I guess I just meant if he did anything more.
    I know, only 1 turn on the bolt holding the collar and no more than that.
    Some people have used a spring compressor to relieve a bit more tension cause the droop alone wasn't enough.
  7. Nov 8, 2020 at 2:40 PM
    eon_blue
    Azusa, CA
    I dunno, I've adjusted mine probably 10 times and thats all I ever needed to do, never had to take them off or anything. Tensions never been an issue, does take a little muscle but have your Wheaties first and you'll be ok :p
  8. Nov 8, 2020 at 2:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Basically everyone else was just a bitch :rofl:
  9. Nov 8, 2020 at 2:46 PM
    eon_blue
    Azusa, CA
    :notsure: I've always been able to do them like that
  10. Nov 8, 2020 at 2:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    said no one ever
  11. Nov 8, 2020 at 3:37 PM
    JKO1998
    Utah
    My AT’s did great in the snow this morning, but I feel like MT’s shine when you really gotta dig in
  12. Nov 8, 2020 at 3:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Do your Kings have a resi hose fitting. The Kings I had before were the ifp type, no resi. So yeah, pretty easy to do on the truck.
    No way to do them on the truck, even if the UCA is disconnected and moved up, out of the way. Fortunately, I have access to a very nice Brannack spring compressor.
  13. Nov 8, 2020 at 3:40 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    mts shine in the snow when you're down at 8psi and trying to paddle through.
    short of that, pretty poor performance. the whole point of a snow tire is to hold snow.
    the whole point of a mud tire is to fling out anything in them
  14. Nov 8, 2020 at 3:41 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I adjust my coilovers with resis on the truck all the time. :notsure:
    You do have to pull the uniball through bolt though.
  15. Nov 8, 2020 at 4:00 PM
    JKO1998
    Utah
    What is air down
  16. Nov 8, 2020 at 4:03 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    never heard of it
  17. Nov 8, 2020 at 4:05 PM
    JKO1998
    Utah
    Same, must be some new magic
    SiskiyouSavage likes this.
  18. Nov 8, 2020 at 4:13 PM
    Coachcleats90
    Coachcleats90 New Member
    Brad
    Weed, CA
    1999 Toyota Tocoma
    It's the Daughters rig, so I'm a dad keeping it running... New head lights New LED reverse lamps
    Gave daughters rig a new perscription. Foggy headlights are gone, in with the clear.fullsizeoutput_134e.jpg
    Winkle99, Dekoy909, SwampYota and 2 others like this.
  19. Nov 8, 2020 at 4:39 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Snow depth also plays a roll. Really deep, loose snow the MT shine. Packed snow the AT definitely do better.
    m3bassman[QUOTED] likes this.
  20. Nov 8, 2020 at 4:52 PM
    JKO1998
    Utah
    Chains and a locker will get you anywhere
    Maximus2x4 likes this.
