  1. Nov 18, 2020 at 7:49 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I’m down to help too, what’s wrong with it?
  2. Nov 18, 2020 at 7:50 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Progress is slow, but today I got the majority of the trim off, pressure washed the pickup and started roughing up the paint with scotch brite. Hoping I’ll have the thing totally ready for paint including body work by thanksgiving. Tomorrow I’ll pull the interior for the spots we have to get behind the panels to straighten them and hopefully do a little bit of straightening on the frame.
    Tour991 likes this.
  3. Nov 18, 2020 at 7:52 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I took a disc sander to mine when I bedlined it
    might speed it up a bit... don’t know
    ToyotaDriver[QUOTED] likes this.
  4. Nov 18, 2020 at 7:57 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I went and got 6. 3 for the lexus and 3 for the yota.
    chowwwww[QUOTED] likes this.
  5. Nov 18, 2020 at 7:57 PM
    ToyotaDriver
    Idaho
    Someone not that long ago was talking about bed lining their fender flares and they replaced the rubber on the fender flares with new material. Does that ring a bell to anyone? Looking to get the rubber for when I put the fender flares back on
    planning on using a DA sander for a few spots where I’ll need to use bondo, but the 80 grit scotch brite is really working great for the majority of it.
    JKO1998[QUOTED] likes this.
  6. Nov 18, 2020 at 8:12 PM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
  7. Nov 18, 2020 at 8:47 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Sand them,clean them, bed line them, then coat them satin black.
    Easy peasy
  8. Nov 18, 2020 at 8:53 PM
    ToyotaDriver
    Idaho
    Guessing you were replying to my post. Not asking about the process. I’m asking about the rubber edge on the fender flare since I need to replace mine. I was thinking that this was the product that someone else recently used, but wasn’t sure KING FENDER FLARES Edge Trim Rubber Gasket WELTING T-Style 30' FEET - with Alignment Tool for CAR and Truck Wheel Wells - Double Edge - Length 30’ FEET - Automotive Adhesive Tape Bonds to Flare https://www.amazon.com/dp/B07R1K8KL1/ref=cm_sw_r_cp_api_fabc_CNFTFbXZ943V7?_encoding=UTF8&psc=1
  9. Nov 18, 2020 at 8:56 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Oh. My bad. I didnt have to deal with that. Good luck man
  10. Nov 18, 2020 at 9:32 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    Nothing’s wrong with it. Just want to lift the tire higher, put it at a slight angle, and add 10 gallons worth of fuel/water storage
    Dan8906[QUOTED] likes this.
  11. Nov 18, 2020 at 11:11 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Easy peasy. Come thru to the east bay and we can knock it out! :cheers:
  12. Nov 18, 2020 at 11:12 PM
    betterbuckleup
    Ian
    Concord, CA
    I used this and it worked great
    https://www.amazon.com/dp/B01CJRGX3O
  13. Nov 19, 2020 at 5:59 AM
    MattJakobs
    Matthew
    NorCal
    Just when I move away :confused:
    Dan8906 likes this.
  14. Nov 19, 2020 at 6:45 AM
    ToyotaDriver
    Idaho
  15. Nov 19, 2020 at 8:13 AM
    betterbuckleup
    Ian
    Concord, CA
    Thought you already moved, no?
  16. Nov 19, 2020 at 9:14 AM
    MattJakobs
    Matthew
    NorCal
    It’s a slow process. I’m. between both places right now, hopefully I’ll be out of the bay by the end of the month.
    All/most of my shit is still in Walnut Creek. 4Runner and truck stuff is in Sac
  17. Nov 19, 2020 at 9:22 AM
    betterbuckleup
    Ian
    Concord, CA
    Ahh gotcha. I'll shoot you a text.
    MattJakobs[QUOTED] likes this.
  18. Nov 19, 2020 at 9:43 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Mine is in the same spot but SuperWhite is in the house!
    Mischief and SwampYota like this.
  19. Nov 19, 2020 at 6:09 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    Did the gentex 453 mirror swap. Digging the orange compass to match the factory colors. $40 on ebay. IMG_20201119_210830.jpg
  20. Nov 19, 2020 at 8:14 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Curious for those running SPC UCAs. How often do you change the ball joint? I think I have about 70-80k on mine.
    LBJ have been changed and are at roughly 60k.
    mostly high way. Some fire roads and a few trail runs, But not much.
    I just installed Kings and saw that I have a freshly ripped driverside Inner CV rip. So debating if I should just replace it all or just replace the CV. There’s a small clunk coming from the driver side at low speeds going on and off drive ways. Which only happened after installing my kings. Was never there with my old 5100/eibach. Paint pen marks show that bolts have not moved.
