  1. Dec 7, 2020 at 10:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It looks like it is kind of a bitch to get it out of the door too.
    WTF :rofl: First it was the 3.4L sounds like dog farts and now this.
  2. Dec 7, 2020 at 10:11 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    What’s wrong with your latches? My rear driver door latch seems to keep dropping down after I open the door. So every time some opens and closes the door it’s slams against the latch. Doesn’t close. Unless I use my finger to pry open the latch then close the door.
  3. Dec 7, 2020 at 10:11 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Have you ever smelled brake clean and PTFE spray. That's not a smell I want lingering inside my cab. WD-40 is like the most mild thing ever, you could spray it all over your body and be fine hell it even cleans leather
  4. Dec 7, 2020 at 10:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I hate it when I get some on me or my clothes. It lingers.
    Speaking of smells... I am doing a drain and fill on the trans and used the @drr recomended Valvoline Max Life. Now that's a smell you wont soon forget.
  5. Dec 7, 2020 at 10:21 PM
    Speedytech7
    Yeah I had to put 10 quarts of that in the cruiser when I did my drain and fill. I had to pull the pan down to change the solenoids and I got covered in it. Terrible stuff
  6. Dec 7, 2020 at 10:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It has just gotten really stiff. it feels almost like I'm going to break the handle off just trying to open it. I am hoping that it's just dirty.
  7. Dec 7, 2020 at 10:29 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    No MT-90? I think I still have another year or two of that around, but boy, it's pricey.
    Digiratus[QUOTED] likes this.
  8. Dec 7, 2020 at 10:30 PM
    Speedytech7
    He's got an auto tragic
  9. Dec 8, 2020 at 5:37 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I am still working on this. I did mention I work slow, right? Between weather, work, lighting, and the kid's XJ acting up, I haven't had the time to finish this.
    Got the clutch swapped out. "Wore slap out" doesn't begin to describe it. I was getting into wear indicator #3 of 4. I went with an Exedy replacement kit from Rockauto. Super fast delivery and a great price as well. Fortunately I was planning ahead when I tracked it down, because the clutch started deteriorating rapidly over the last week- I doubt I'd have gotten to and from work another day.
    Got everything replaced- but the tranny is giving me trouble lining up. I can't seem to get it to go that last 1/2-3/4". Will be trying again Friday, if the weather holds, as I'm off.
    nagorb likes this.
  10. Dec 8, 2020 at 6:33 AM
    Speedytech7
    Throw it in gear and rotate the output flange a bit, might get you that last little bit of slip. DON'T draw it in with bolts!
    burntkat[QUOTED] likes this.
  11. Dec 8, 2020 at 6:35 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Trans mating is the biggest headache I know.
    burntkat likes this.
  12. Dec 8, 2020 at 6:57 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I did, but the trans was clean. Front diff had some water but nothing else did.
  13. Dec 8, 2020 at 7:14 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    That looks sketchy. You guys are braver than me. Water looks like it was moving fast as hell.
  14. Dec 8, 2020 at 7:59 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    it wasn't brave, it was stupid. I don't know why we didn't just turn around. Though I guess I'm to blame for that.
    And yeah it was hauling ass.
    Was stupid.
    SwampYota[QUOTED] likes this.
  15. Dec 8, 2020 at 8:05 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I always have WD40 around, but there's definitely better lubricants.
    I think I used Triflow or Boeshield on my door latches.
    Digiratus and Blackdawg[QUOTED] like this.
  16. Dec 8, 2020 at 8:56 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Ahh, right. See, I think he was the one who recommended the MT-90 to me originally, but maybe that's what he uses in his transfer case and diffs. I'm not wealthy enough to use it there, but I do put it in the transmission.
    FIFY
    The first photo was the second crossing, and was way dumber than the second photo (our first crossing). I will say that Monte likes to tell the story of my reaction just before the first crossing though. F.U.Rain Day 9 – “Seriously?” :rofl:
  17. Dec 8, 2020 at 8:59 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
  18. Dec 8, 2020 at 9:10 AM
    Speedytech7
    It seems to make the transfer case in my LC (which has gearsets for high and low because it's fulltime offset with a differential) much quieter. Didn't really make a difference in the manual trans so I switched to amsoil severe gear
  19. Dec 8, 2020 at 9:14 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    that was a fun moment. Mostly because you still had a hint of green horn in you so it was just funny. Idk. I love that memory hahahaha
    You'd probably just shrug and say "okay" nonchalantly now haha
  20. Dec 8, 2020 at 9:58 AM
    Digiratus
    Roaming the PNW
    The RedHead
    In those types of scenarios, the hardest part is knowing how deep it is out in the main part of the channel. Once Monte got thru, we knew we would be able to too. And also, once he was on the other side, we had no choice but to follow. :rolleyes:
    I might have, it is excellent stuff. I had used in my first 1st gen. :thumbsup:
