  1. Dec 17, 2020 at 10:41 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    cast crank same as the old 3vz-e
    the 92-93 camry 3.0l 3vz-FE had forged crank
    Silver02Taco likes this.
  2. Dec 17, 2020 at 10:42 PM
    Empty_Lord
    Dan
    i had the 5vz and 3vz-fe cranks side by side. the 3vz easily weighs 10 more lbs and you can clearly see its forged vs the clear casting marks on a 5vz crank
    burntkat and Silver02Taco like this.
  3. Dec 17, 2020 at 10:44 PM
    Empty_Lord
    Dan
    to start i'll be running the TRD blower. but eventually turbo is the plan.
  4. Dec 17, 2020 at 10:45 PM
    Empty_Lord
    Dan
    considering 95% of the people who bought them wanted a no frill vehicle with ok power. they didnt need to do any more than they had. the 5vz is a fine motor stock for the era its from. and its proven to be hard to kill.
    honestly looking back i should of put a modern Toyota motor in this truck. but the challenge of building a 3.4 was too much to say no to.
  5. Dec 17, 2020 at 10:47 PM
    Empty_Lord
    Dan
    valve adjustment? i did my first valve adjustment at 280k. i had one valve that needed adjusting. LOL theyre good engines. far better than anything from the domestics at the time.
    burntkat and Running Board Man like this.
  6. Dec 17, 2020 at 10:48 PM
    Empty_Lord
    Dan
    thats just age catching up with it.. its still a man made vehicle. but hey, its still running aint it?
  7. Dec 17, 2020 at 10:55 PM
    Empty_Lord
    Dan
    cracked heads, yes. valve adjustment technically is ever 30k per the manual. but ive never seen one actually out of adjustment before the 200k mark.. hell this abused 260k mile engine out of a 4runner that rolled over and i got for free had no valves out of adjustment and it was still on the original timing belt.
  8. Dec 17, 2020 at 10:57 PM
    Empty_Lord
    Dan
    p0420 i fought for a while eventually it was just obvious it needed new cats. but i started with new DENSO sensors (Anything else doesnt work)
    graphing the cats on a scan tool showed the full story though. after 270k my cats were shot. new magnaflows and it was code free for 4 years before i tore it down for this restoration
  9. Dec 17, 2020 at 11:02 PM
    Empty_Lord
    Dan
    LOL yea i had to do both.
  10. Dec 17, 2020 at 11:05 PM
    Empty_Lord
    Dan
    i'd say o2 simulator. buy you're in California. i think thats punishable by death out there
  11. Dec 18, 2020 at 7:51 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Got tired of the dangling trailer wiring connector so i installed a $2.00 bracket.
    megalodon, nagorb, Phessor and 2 others like this.
  12. Dec 18, 2020 at 7:57 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Valves getting tight is an issue for the 3rz
  13. Dec 18, 2020 at 8:12 AM
    MCJohnston
    MCJohnston Well-Known Member
    Matthew
    CT
    02 Tacoma SR5 TRD 3.4L 4x4 X-tra Cab
    I was just looking at mine last night and thought, “Damn, that’s just ugly”. I’m gonna have to find one and clean that up for sure now. Nice job.
  14. Dec 18, 2020 at 1:28 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's so cheap, it's silly not to. I am not sure if you are going to do the jute padding underneath but if you aren't def hit that shit with some MLV. Even with some of the vinyl work I added, the cab is significantly louder.
    Here is some of the shit I learned in the process of installing mine. Wish I did matting on the back wall and doors at the same time but that can be a project for the future.
    How to remove your carpet in a first gen tacoma
    nagorb and jubei like this.
  15. Dec 18, 2020 at 1:53 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Anyone wanna try to help diagnose a noise for me over the interwebs?
    When I start my truck, especially on cold days, it sounds like a kazoo under the hood. Noise disappears as it warms up. Gets louder when I give it gas. I thought power steering pump but I have full fluid and power steering seems to be working well...
  16. Dec 18, 2020 at 2:08 PM
    Kevins60
    Kevin
    Odessa FL
    MCJohnston[QUOTED] likes this.
  17. Dec 18, 2020 at 5:00 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Got the new tank into place and reconnected everything. Truck started up on the second crank and seems to be running well. I replaced the tank, tank gaskets, hoses and fuel pump. Hoping that I fixed the gas smell and P0456 for good.
  18. Dec 18, 2020 at 5:14 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Id put money on a pulley bearing going bad. Water pump, idler, alternator etc.
  19. Dec 18, 2020 at 5:39 PM
    eon_blue
    Azusa, CA
    Yup mine kinda sounded like that this time last year when I was getting ready to drive my truck up north for xmas. Was afraid it was the water pump but turned out to just be the idler pulley bearing, cheap fix.
    SwampYota likes this.
  20. Dec 18, 2020 at 5:41 PM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    I can’t wait for the results!
