  1. Dec 27, 2020 at 11:31 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    that's exactly what I want to do with my 03 DC. I think that will protect the lower quarter panels really well. thinking about doing it on the bed also.All it takes is time and money.
    burntkat and Taco critter like this.
  2. Dec 28, 2020 at 6:03 AM
    JoeyWales
    JoeyWales Well-Known Member
    SC
    This is going to sound bad BUT, after two years this spark plug finally came out. When I replaced the spark plugs last 5 of the 6 came out just fine, where as this one felt like it got cross threaded/galled up when I was removing it. So at the time I just snugged it back in.
    Fast forward to last night and it finally happened. P0302 cylinder 2 misfire.
    Was looking at timeserts last night and decided to wait and see what comes of this. Went out sprayed a little PB Blast and she backed right out. Took a new plug, screwed in and back out no problem.
    That’s been a cause of stress for too long. Glad I didn’t have to use that sert.
    Have new plugs on the way.
  3. Dec 28, 2020 at 6:13 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I had to use one of those sert things this this fall. Cept I was too scared to do it myself so we paid someone
    hogeyphenogey likes this.
  4. Dec 28, 2020 at 6:14 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    It’s ok to know your limitations, especially on things that can become expensive quickly if you screw them up.
    ireymon, nagorb, CS_AR and 4 others like this.
  5. Dec 28, 2020 at 7:14 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Hopefully the electrode is just warn down and didn't break off?
  6. Dec 28, 2020 at 8:12 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    How much?
  7. Dec 28, 2020 at 8:12 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    How much?
  8. Dec 28, 2020 at 8:14 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Just doing the rocker panels would be cheap. You could easily do it in a day if there’s no body work to do.
  9. Dec 28, 2020 at 8:17 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    The threadserts aren't that big a deal. I used the Helicoil brand, installed last year after #4 decided to depart the engine, going through the coil. Worked like a champ, just takes a while and involved a lot of greasing the tap, cleaning the grease, repeat.
  10. Dec 28, 2020 at 8:40 AM
    commandeeredwifestruck
    commandeeredwifestruck Member
    2003 1st gen 4 door 4x4
    Bumper w/winch, bilstiens all around, K&N intake, snugtop shell with racks
    Long time lurker first time post. I just wanted to give a big thanks to everyone who contributes on the forums. There is a wealth of knowledge and wisdom here that I’ve used lately. I just replaced my upper and lower balm joints, wheel bearings, outer tie rod ends and cv axels. I have a list of more things to do and I’ll try to keep up with posting the progress. Thanks again!
  11. Dec 28, 2020 at 10:11 AM
    ROlla-Xrs
    ROlla-Xrs Well-Known Member
    Roman
    Elk,WA
    1st gen Trd Tacoma
    Pm sent
  12. Dec 28, 2020 at 10:27 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Since I mentioned (was asking questions about) LED/HID upgrades earlier, here's my before/after photos of the light output. Definitely a lot brighter with the new "bulbs."
    Process was reasonably straight forward, and we'll see how my reservations about the LEDs pan out... LED / HID installation.
    Original low beams. Bleh.
    LED low beams. Better (more light), for sure.
    LED high beams + Hella 700 with HID upgrade. Nice! (most of this is Hella 700)
    Phessor and m3bassman like this.
  13. Dec 28, 2020 at 12:35 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Blinding, hahahaha.
    Silver02Taco likes this.
  14. Dec 28, 2020 at 1:25 PM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    Picked this up for $400 today, can’t wait to get it installed!
  15. Dec 28, 2020 at 1:31 PM
    JoeyWales
    SC
    Electrode was completely worn down. I’m glad it didn’t break off.
    Ive done helicoil before, just not on something as critical as, a spark plug with the head on. I’m just glad I didn’t have to pay for the kit or even have to attempt it.
    @Reh5108 @JKO1998 @burntkat
    Phessor, Reh5108 and JKO1998 like this.
  16. Dec 28, 2020 at 1:36 PM
    JoeyWales
    SC
    Looks great. What steered you in this direction (besides @Blackdawg) instead of the harness that @crashnburn80 used?
  17. Dec 28, 2020 at 1:37 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    I would double check what plugs you need, because I think you need something like this. I have an 03 DC V6 and these are the type of plugs truck required.
  18. Dec 28, 2020 at 1:38 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Explain this for us simple minded old people.
  19. Dec 28, 2020 at 1:39 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Did you spray or roll on?
  20. Dec 28, 2020 at 1:42 PM
    ToyotaDriver
    Idaho
    Spray on.
