  1. Dec 29, 2020 at 6:31 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    If that hump gets removed, I don't even think you need brackets, just bolt down through the floor and put plates (something bigger than a washer) on the underside.
    lightnfast[QUOTED] likes this.
  2. Dec 29, 2020 at 6:47 PM
    slodoug
    slodoug Well-Known Member
    smogged and 2 new rear tires today (hankooks, to match the one that went flat (sidewall flat))
  3. Dec 29, 2020 at 6:58 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    I wired a special switch to my backup lights (not just factory, but two pods in bumper and one on top of cap), just so I can give them a little blip to let them know. Works!
  4. Dec 29, 2020 at 7:02 PM
    Running Board Man
    Running Board Man Well-Known Member
    Of the 3 times I've flashed my projectors the oncoming cars turn their High beams off
  5. Dec 29, 2020 at 7:06 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    All this talk about LED lights. I rather you run those than the fucken idiots who run ALL the light bars mounted on during the day and night. Fucken Idiots
  6. Dec 29, 2020 at 8:00 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    It's the dash gauges in the new cars that are always lit up and bright. I drove a few blocks with my lights off in some new POS rental car and it dawned on me how the dumbo's do it.
    As for running with evrey forward facing LED on at all times regardless of the weather, neck yourself!
  7. Dec 29, 2020 at 9:22 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    When I had my fancy LEDs with the shroud thing in I never got flashed by cars or trucks.
    But the second a semi was in the opposite lane they’d let me know my lights were hitting them up higher.
    Weird but true.
  8. Dec 29, 2020 at 9:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    They have a lens covering them that focuses the light don't they? Far cry from an LED mounted in a halogen housing with a clear plastic cover. Just Sayin!
  9. Dec 29, 2020 at 9:49 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Are they adaptive or fixed? The bimmer headlights do a good job of not blinding but the whole moving mechanism is more trouble than the function or LED/HIDs are worth.
  10. Dec 29, 2020 at 9:58 PM
    Speedytech7
    It's been around so long I kinda figured it was getting cheap. Too bad they haven't made adaptive more Stout, it makes HIDs and LEDs less brain frying for oncoming traffic
  11. Dec 29, 2020 at 10:30 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    this shit is awesome. I bet they will get it to work better as time goes on.
    burntkat likes this.
  12. Dec 29, 2020 at 11:42 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    WTF is going on in here, this is getting as bad as 3rd Gen, and that is coming from a former 1st Gen owner.
    BeamTech is a pathetic joke of a product. Check out test results in post #1854. Literally the worst LED I have ever tested by a continental landslide, it is so obvious that this is just bottom of the barrel cheap China crap that anyone with the slightest lighting background would laugh at this product suggestion. The only reason I tested them was as a joke/partially because a few people kept giving such horrifically awful advice to our forum members that was endangering people. Yeah they create foreground light, but no distance light at all. The test numbers linked are actually artificially very favorable compared to actual performance, since the results were so off the chart awful (worst product ever tested) I didn't even bother with a distance performance test which would have provided far worse real world numbers.
  13. Dec 29, 2020 at 11:59 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Aside from the obvious facepalm with 1st gen LED headlights for blinding the hell out of people, FU cheap ass LED bulbs.
    I learned my lesson and went back to incandescent with the exception of maps/interior cab/cluster lights.
  14. Dec 30, 2020 at 12:02 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    at work we've had a recent influx of LED bulbs burning up in the 3rd gens... like 4-5 in the past 2 months. (BUT YOU GUYS CAN WARRANTY IT RIGHT?).. no.. no we cannot. and insurance wont cover the harness repairs.. soo i avoid LED headlights. sylvania zevo bulbs for everything else? hell yea.
  15. Dec 30, 2020 at 12:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not that i disagree with you..but the bulbs in your test are not the same bulbs that have been brought up here. You tested a H11 and they are using an H4 with a low beam shield.
  16. Dec 30, 2020 at 12:46 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, very valid point. In my testing of countless LED bulbs only one brand provided a half decent properly engineered H4 low beam cut off shield, and that was Philips. All the cheap China brands were crap and provided excessive glare and also significantly reduced low beam performance. BeamTech is an extra special shitshow of an incompetent brand.
  17. Dec 30, 2020 at 1:27 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I have issues driving at night, and I swear some of these newer cars and trucks have 100billion candle watt power Q-beams for headlights these days. Most of these, not all appear to be on low beams and blind the shit out of me. Then you have the Moron's that drive around with their Highs on, which just make it worse. Makes me wish I had a light bar on the top of my truck, that I could turn on and vaporize their entire vehicle. I know improvements have been made in headlight bulb technology, but dam.
    burntkat and 0xDEADBEEF like this.
  18. Dec 30, 2020 at 4:52 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    The real issue here is too many people have their headlights improperly aimed. Even halogen sedans blind the fuck out of me very once in a while. Either that or far too many people can’t grasp the concept of high beam/low beam.
  19. Dec 30, 2020 at 5:01 AM
    slander
    Hickory, NC
    I also never understood why the lights aren't tied into the wipers.
    burntkat and m3bassman[QUOTED] like this.
  20. Dec 30, 2020 at 5:37 AM
    MCJohnston
    MCJohnston Well-Known Member
    Matthew
    CT
    02 Tacoma SR5 TRD 3.4L 4x4 X-tra Cab
    So now that we know everyone’s thoughts on the cheap “beamtech” drop in leds,
    What have you done to your tacoma today?
    Well I gave mine a nice little wash of all the road salt and somehow managed to rip half the 3m double sided tape off the pass. window rain guard. Guess I’ll have to go get some new tape and re install that on this long weekend.
