  1. Jan 1, 2021 at 9:06 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Fernando[QUOTED] likes this.
  2. Jan 1, 2021 at 11:14 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Bummer man! Not sure about the clunking noise, but you can check for bent axle in the side view mirrors - just look to see if the wheel is tracking smoothly/evenly/not wobbling when you're at highway speeds.
    Swapping the seals (and you should do the bearings at the same time) isn't hard but requires some special tools. Totally worth it though, I still saved a ton of money over taking it to a shop.
    Here's a Step-by-Step Replacing Rear Axle Seals guide with links to the various parts and tools needed, and here's the story (with pics of the job) the day I did it. Those two things together can give you a sense of the work.
    Those are great wheels. I got the same ones and spent a couple days prepping and rattle-canning them myself; turned out great - though definitely a lot of work.
    For me, wheels are something that get scraped up pretty quickly. Any paint job - rattle can or powder coat - is lucky to last more than a few trips before rock rash renders it "noticeably used." :rofl: That's the main reason I decided to go rattle-can instead of powder. At least that way, I know it's easy to touch up and get a good match.
    Here was my write-up of the process. Would have been much easier if I had a buddy to do the sand blasting and prep, hahahaha!
    Wheel Makeover – Extreme Labor for a Totally Non-Functional Mod
  3. Jan 1, 2021 at 11:35 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just don't pick that color of poop brown like Dan did :p :luvya:
  4. Jan 2, 2021 at 12:15 AM
    spyder918
    spyder918 Member
    Acme Super H1 with Morimoto XB bulbs
  5. Jan 2, 2021 at 7:12 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :anonymous:
    :laugh:
  6. Jan 2, 2021 at 7:22 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Can you post a picture of it from the side and measure how wide it is front to back?
  7. Jan 2, 2021 at 9:50 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Here you go. I replaced the foam weatherstripping with Home Depot foam and rubber tapes. I drilled holes in the bedliner and unfastened the liner to install the hooks from the back side.
    https://www.acehardware.com/departments/hardware/hooks-and-screw-eyes/hooks/57935
    https://www.homedepot.com/p/Frost-K...-Rubber-Foam-Weatherseal-Tape-R534H/202262324
    https://www.homedepot.com/p/Frost-K...r-Strip-Tape-Cushioned-Ribbed-V27WA/100166568
  8. Jan 2, 2021 at 10:01 AM
    JKO1998
    Utah
    Nice, I was just wondering if it’d fit my truck how I need it to, but I don’t think it will
  9. Jan 2, 2021 at 10:21 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    When life gives u zip ties
  10. Jan 2, 2021 at 10:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not bad. I've used a ratchet straps before :laugh:
    burntkat and Das it mang[QUOTED] like this.
  11. Jan 2, 2021 at 11:45 AM
    eon_blue
    Azusa, CA
    I still keep my battery zip tied to the inside of the fender, even though I fixed the OEM battery tie down. It worked itself loose once on the trail and let my battery slide around causing the tie down strap to contact the terminals...that was fun.
    If it happens again at least I'll hopefully catch it before the zip ties break. Need to order that aftermarket tie down that the TW member on here sells, or get me an aftermarket battery tray
    Das it mang[QUOTED] likes this.
  12. Jan 2, 2021 at 12:27 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    I need to do this, it would be nice not to have to buy a press
    Burro and turbodb[QUOTED] like this.
  13. Jan 2, 2021 at 1:05 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Friend with one?
    Really, the press isn't very expensive at all (if you have room for it), and I've been surprised how many other things it has made much easier/how versatile it is. Even with the press and other "special" tools for the job, it still ended up costing me about half what taking it to Toyota would have cost. (granted, in a high cost of living area)
    burntkat likes this.
  14. Jan 2, 2021 at 1:11 PM
    hogeyphenogey
    Dave
    Agawam, MA
    Spent 1/2 an hour and replaced the low washer fluid bulb. Yippee.
  15. Jan 2, 2021 at 3:15 PM
    hogeyphenogey
    Dave
    Agawam, MA
    Sometimes, it’s the little things. Installed a command hook for my masks and the iPhone cord. Got sick of hanging my mask on the mirror.
  16. Jan 2, 2021 at 3:35 PM
    MCJohnston
    MCJohnston Well-Known Member
    Matthew
    CT
    02 Tacoma SR5 TRD 3.4L 4x4 X-tra Cab
    Definitely handy. I find myself hanging my masks on the 4wd selector
  17. Jan 2, 2021 at 4:15 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Fun times building this.
    jubei, BYJOSHCOOK, cbassd and 4 others like this.
  18. Jan 2, 2021 at 4:46 PM
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    OEM Battery..That’s cool
  19. Jan 2, 2021 at 4:47 PM
    Rldanie
    Rldanie Punisher78
    Colorado
    Nice Radiator
    It’s look like a champion?
    are you running green or red fluid?
  20. Jan 2, 2021 at 5:11 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    It is. Red.
