What have you done to your tacoma today? 5lug edition
Discussion in '5 Lug' started by Sperrunner, May 30, 2018.
  1. Jan 23, 2020 at 3:02 PM
    #81
    pwrslide2
    pwrslide2 Well-Known Member
    AZ
    07' 2.7 2wd auto
    In process
    I'd start a new thread to get some help on this.
  2. Jan 23, 2020 at 3:03 PM
    #82
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Took a picture of her
  3. Feb 6, 2020 at 12:27 PM
    #83
    SLO5lug
    SLO5lug Member
    California
    2001 Base Tacoma
    Stuffed some 30s on a stock 2001 base model with stock suspension and a 2” drop out back (previous owner). The clearance is about as tight as you would imagine. Clears the front valence without trimming, and nearly rests on the pinch weld at full lock. Tires stick out of the stock fenders about 3/4”. Considering an OEM type flare to keep things tidy. 3” lift coming shortly - Doetsch springs and UCAs with shackles.
    Wheel/tire setup:
    American Racing Baja 15x7 -6 offset
    Toyo Open Country A/T 30x9.5-r15
    Noticing some play in the steering now and I’m right at 100k miles. How would you guys recommend troubleshooting to decide what joints should be replaced? Everything looks original right now.
  4. Feb 6, 2020 at 8:47 PM
    #84
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    Looks good man.
    Some have said 3" lift kits are too much for the front suspension geometry. The 2.5" lift spacers are the max you can go without getting aftermarket upper control arms.
    How's the power/drivability feel with the tire upgrade?
  5. Feb 6, 2020 at 9:16 PM
    #85
    SLO5lug
    SLO5lug Member
    California
    2001 Base Tacoma
    Yeah, my understanding is that the bracket that connects the LCA to the lower BJ is the weak link on the 1st gens. Some have broken it in the past. There are several theories I’ve heard for the cause, but it’s hard to be sure exactly what causes the failure. I don’t plan to abuse the truck off-road and it’s not my daily, so I’m not too stressed about it.
    I’m doing longer springs and UCAs from Doetsch to ensure I can keep the truck aligned. I was all set to get things moving this weekend, but I am going to hold until I receive new BJs and tie rod ends. Probably next weekend.
    The power loss is very noticeable. The truck is very sluggish now. I am going to have a local gear shop build a rear end with 4.10s and a Detroit Truetrac here pretty soon. It’s definitely drivable for now, but I wouldn’t recommend it to a friend. :cheers:
    dasitmane420 and pwrslide2 like this.
  6. Feb 6, 2020 at 9:20 PM
    #86
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    Sounds good man. Nice lil project!
  7. Feb 8, 2020 at 3:29 PM
    #87
    NTEC
    NTEC New Member
    2010 Tacoma base
    Non yet
  8. Feb 8, 2020 at 4:45 PM
    #88
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    DGXR and TacoHank1998 like this.
  9. Feb 9, 2020 at 9:17 AM
    #89
    scouterjan
    Jan
    Even though it's a 2 wheel drive I run.AT tires for gravel roads and pulling my 13 ft boler trailer 20200208_164221.jpg
    TacoHank1998 likes this.
  10. Feb 11, 2020 at 3:14 PM
    #90
    TacoHank1998
    TacoHank1998 Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
    Got tired of the black fender... so I primed the whole front clip... redneck style.
  11. Feb 14, 2020 at 3:54 PM
    #91
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    Tortured it with 1.5 cubic yards of soil/compost
  12. Mar 21, 2020 at 7:50 AM
    #92
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    Spring cleaning!
    I went over the single-stage paint with a clay bar, polishing compound, then carnauba wax.
    I also tossed on my Mustang GT500 wheels but they won’t be on there for long. They dramatically changed the driving dynamics of this little truck, making it rather unwieldy and cumbersome.
    ireymon, Plkyone, KS WRAITH and 6 others like this.
  13. Apr 13, 2020 at 6:52 PM
    #93
    TacoHank1998
    Will
    Panama City, FL
    Hank is finally the same color again...
  14. Apr 14, 2020 at 9:49 AM
    #94
    maverick4x2
    maverick4x2 Well-Known Member
    2013 Tacoma 5 lug
    looking good
  15. Apr 23, 2020 at 1:35 AM
    #95
    Yapretzel
    Yapretzel Active Member
    Gabe
    2015 Access cab
    Painted the front bumper/installed the grille from toyota accessories guy
    96couv, maverick4x2 and TacoHank1998 like this.
  16. Apr 25, 2020 at 12:31 AM
    #96
    96couv
    96couv Member
    235/75/15 on stock steelies.IMG_20200424_112730-01.jpg
  17. Apr 25, 2020 at 2:21 PM
    #97
    Terc
    Terc New Member
    2012 Toyota Tacoma 5-lug regular cab
    I fixed the driver’s side of my bench seat and added Coverking seat covers.
    Before I started work:
    The underside of the passenger side:
    The support wires running up/down and the plastic rods running left/right are all intact. Also, the grayish blueish pad is present.
    This is the underside of the driver’s side:
    All that support material was missing from the driver’s side. It was like that when I bought it. It's a 2012 with 56,000 miles on it. I don't know how this could happen in so short a period of time. I actually didn’t notice how saggy the driver’s side was until I sat on the passenger side. After that, I couldn’t get it out of my head and I had to fix this.
    My fix was to add wood slats to the underside, in order to support the foam which seemed to be in good shape. I had no idea how I would ever fix the broken wires and plastic so this was the best idea I could come up with.
    This worked much better than I could’ve imagined. The bench seat feels really supportive now.
    Then I added the seat covers:
    I think it would’ve been an enormous pain to put the covers on with the bench seat installed, but I doubt I would’ve pulled the whole bench seat out just to do the covers. I’m glad I had this other project to do. (I also used my Dremel to cut slots on the sides of the seat so I could tilt the seat back a couple of clicks. There’s another thread on Tacomaworld about how to do this, so thanks to those guys)
    Back in the truck. Ta. Da.
    maverick4x2 likes this.
  18. May 27, 2020 at 7:51 PM
    #98
    randyave1
    randyave1 Member
    Randy
    2010 Access Cab Metalic Green
    Rain Guards, front mud Guards, steering wheel cover, Dash Mat, Outside door handle chrome covers.
    I bought mine January 30th 2020. I have added Rain Guards, Bug deflector, Seat covers, upgraded the sun visors pull to the left and they extend fully across the side window. Added Wiper Detent and Cruise Control. Added chrome door handles, Chrome strip on the edge of each door. I still want running boards, hood supports, back window slider.
  19. May 28, 2020 at 11:19 AM
    #99
    maverick4x2
    2013 Tacoma 5 lug
    Dang, wish I could see the pics. Sounds like something i need to do to my bench. Drivers side is way more crushed down than the passenger
  20. Jun 3, 2020 at 6:04 AM
    #100
    Terc
    Terc New Member
    I don't have any pictures of it, but when you've got the bench seat flipped upside down, there is a metal bar that runs left/right across the back of the bench seat. I screwed the wooden slats to that bar with self-tapping screws. There was nothing similar across the front of the bench seat on which to secure the wooden slats, so I just wedged them in there.
    I'm wondering why you can't see my photos. I see them just fine, but maybe I didn't post them correctly. I'm new at this.
