What Have You Done To Your Tacoma Today?
Discussion in '2nd Gen. Tacomas' started by kwalton, Feb 2, 2008.
  1. Mar 2, 2013 at 10:13 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    If that's the case he will probably be taking his bull bar off and want his skid plate back after he comes on this site
  2. Mar 2, 2013 at 10:21 AM
    CanadianMade
    CanadianMade Well-Known Member
    Central BC, Canada
    2005 Tacoma DCLB Sport
    factory hard tonneau cover, side rails, 265/70/17 General Grabber AT2's, Custom Seat Covers, More to come....
    Bravo! *golf clap*
  3. Mar 2, 2013 at 10:22 AM
    Swank
    Swank Certified Mall Crawling Instructor
    Steven
    Greenville NC
    2008 - Badass Mall Crawler Edition
  4. Mar 2, 2013 at 10:49 AM
    Texoma
    Texoma Well-Known Member
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Poweraid TB spacer, a bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA 2035s headers and dey are perty, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, LR UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, 5 factory 16" steels wit Pep Boys special Dakota Definity MT's in 285/75/16, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more but it's alre
    Put more lift on. Added a Toy Tec top plate to Blstn 5100's @ o with OME 885x springs, and LR UCA's. Have 285/75/16's on stock steel with front mud flaps removed and cut the front rain drop nipple out. No rub.
    Next will be to remove stock leaf packs with an AAL, and replace with All Pro leaf packs and U bolt flip.
  5. Mar 2, 2013 at 10:52 AM
    AnTiFuBaR
    AnTiFuBaR Well-Known Member
    Grand Junction, CO
    '13 TRD OR 4x4 DCSB
    BHLM
    Well I've had my 2013 for about 4 days now and last night I did a BHLM. Thanks to this forum and all you brilliant people I was able to do it no problem. Given I do have a bit of mechanical savvy and a monsterous tool set but still! I put my new headlights in the freaken oven because a forum told me too. HA HA HA. Anyway, thank you all! I did manage to get some blood on the headlights and truck also. Nothing a few Becks didn't help.
    Heads up the 2013 grill and headlights are different than the 2012. Not big differences but definitely not the same. A little shooting from the hip was required but it looks good. If anyone is interested Ill take some pics.
  6. Mar 2, 2013 at 11:27 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    Is there anything different with the process because I plan to do my 13 at some point?
  7. Mar 2, 2013 at 11:30 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    im set to see 40 post per page so i only have just over 770 pages :D
    but i have seen glitches like that from time to time!!!
  8. Mar 2, 2013 at 11:38 AM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    That's what I'm thinking. I call No Backsies!
  9. Mar 2, 2013 at 1:32 PM
    AnTiFuBaR
    Grand Junction, CO
    '13 TRD OR 4x4 DCSB
    BHLM
    Nothing big really. The third bolts on the lights that you have to get to by laying under and reaching up are 10mm. They aren't hard to reach once you find them.
    When you go to take the headlights off the body rotate them slowly counter clockwise as you pull them out and they will slide out. Any other way you will be fighting them for a while. (reverse the process to get them back in)
    The headlights aren't just "glued" together. They have screws all the way around plus 2 of them are hex screws.
    200 degrees in the oven for 8 minutes works just fine for baking them.
    Be careful when you take the orange reflector out. The clips are super brittle. I broke both small ones off on one headlight and used plastic model glue to put it back together. Holds fine.
    Other than that it went smooth. Separating the lights is a wresting match against time. Once they cool you have to bake them again to loosen the glue again.
    Hope this helps.
  10. Mar 2, 2013 at 2:12 PM
    evl21
    evl21 Active Member
    B
    CNY
    TRD OFF ROAD
    Tint,tonneau cover, Wet Okoles, EGR in channel rain gaurds, ATO rear bumper, not enough $$
    Tortured myself with some test fitting. Can't wait till it gets nicer out and I can throw a lift/wheels/tires/paint calipers.... on all at once and stop teasing her!
  11. Mar 2, 2013 at 2:27 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    BluTaco got a bath, sucked out and a shampoo of the upholstery. Gotta be looking good for new tires on Wednesday!
  12. Mar 2, 2013 at 2:47 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Here
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, Volant cold air intake with ram air scoop.
    Installed a Volant intake with air scoop.
  13. Mar 2, 2013 at 2:54 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Hope you don't do any off roading... those lights under the bumper won't last if you do :p Ask how many folks have broken off the trailer plug...
  14. Mar 2, 2013 at 2:59 PM
    CanadianMade
    Central BC, Canada
    noticed my passenger side mud flap is just about ripped off, hanging on by one maybe two fasteners now... time to replace I guess =( I would like to just keep them off but with the city using gravel on the icy roads and a dark blue truck, I'd rather not have a million chips down the side lol
  15. Mar 2, 2013 at 3:21 PM
    HIst8ofMIND
    HIst8ofMIND Defend Hawaii
    PJ
    Maui
    2013 MGM DCSB TRD-OR
    Ordered a set of wet okoles and grabbed a bite for lunch. Now to the beach.
  16. Mar 2, 2013 at 3:28 PM
    Tacomanator
    Clam Slammer
    Here
    I also scored a skid for cheap.
  17. Mar 2, 2013 at 3:42 PM
    ImpulseRed008
    Susan
    SC
  18. Mar 2, 2013 at 4:37 PM
    mattgecko
    mattgecko The Lighting guy
    Nor-Cal (San Jose)
    2011 DCSB OR 4wd Super Charged!
    Installed a motorcycle bed bar I had made. I'll get it powder coated and LED bed lights installed after I get back from Mexico.
  19. Mar 2, 2013 at 5:05 PM
    iamsuperbleeder
    iamsuperbleeder Licensed Lunatic
    Travis
    Lake City, Florida
    06 DC Prerunner Taco - SOLD -
    TRD E-locker rear axle swap, Cherrybomb Extreme muffler, custom made CAI, 2.5" spacer lift up front and AAL's in the rear, Sport model seat swap, Pioneer X940BT, Kicker shallow 10" and 12" behind the back seat
    found out my tires rub the front of the fender liner at full lock when the suspension flexes a little now after installing the Spidertrax 1.25" spacers :rolleyes: oh well
  20. Mar 2, 2013 at 5:11 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Fixed my driveline vibration (1/4" shims under the carrier bearing), changed the rear diff. fluid, and tightened up a couple of loose bolt on my exhaust.
