What Have You Done To Your Tacoma Today?
  1. Aug 15, 2011 at 8:31 PM
    wannatoy570
    wannatoy570 Well-Known Member
    Dave
    Lock Haven, PA
    05 Toyota Tacoma SR5
  2. Aug 16, 2011 at 7:06 AM
    KevMc
    KevMc Well-Known Member
    Kevin
    West Columbia, SC
    06 TRD Sport DC LB
    Satoshi with Hella 500FF's Readylift N-Fab Rear Runner w/ Westin lights TRD Seat Covers
    I made some brackets out of aluminum angle. On the drivers side I used the whole where one of the horn brackets bolted up and drilled a corresponding hole on the pass side. Puts the lights exactly where I wanted them, but the core support flexes a bit with the weight of the lights hanging off it so they bounce around some. I am going to tie them in with the vertical piece of metal that comes up in front of the radiator tonight and that should tighten everything up. I'll add some pics.
  3. Aug 16, 2011 at 11:04 AM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    Finally got a side picture after the canopy install.... With just the canopy the rear sags..... Trying to find out if the truck qualifies for the new leaf packs.[​IMG]
  4. Aug 16, 2011 at 11:17 AM
    Spazawa
    Spazawa Member
    Southern MD
    2010 4Dr 4x4 TRD Sport Lb
    Tinted front windows, Thule 822XT Bed Rider, TRD Wet Okole seat covers.
    Just installed my Wet Okole seat covers. I installed the ones with the TRD logo on it.
  5. Aug 16, 2011 at 4:54 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    '06 Tacoma xtracab BB
    Clayed paint today in preparation of applying wax tomorrow using Collinite Liquid Insulator Wax 845. I've never used this wax before but I have heard a lot of positive feedback from some detailing forums. We'll see how this works out.
  6. Aug 16, 2011 at 9:37 PM
    Stohrm
    Stohrm Well-Known Member
    Michael
    Oregon
    05 TRD Sport 6 speed manual
    Just ordered my grillcraft! Cannot wait for it to get here.
  7. Aug 17, 2011 at 12:32 AM
    l1tech
    l1tech Well-Known Member
    mike
    bend,oregon
    2011 TRD Sport
    3" Redilift
    She got a bath and new headight bulbs. Put in a set of Clear Vision XL's. Claim to be 50% brighter and would have to say its definately a big improvement.
  8. Aug 17, 2011 at 4:49 AM
    BransTaco
    BransTaco Well-Known Member
    Brandon
    North Georgia
    08 Silver Taco TRD Sport
    K&N, Tinted Winders, black'd emblems, amp'd sound system, custom sub, washed
    Looks good. How hard was it to get the grill emblem out> I did my side and rear emblems using fishing line and goof off, but can't figure out how to get in behind the grill emblem.... do tell.
    :confused:
  9. Aug 17, 2011 at 6:19 AM
    Saxophonedude
    Saxophonedude Member
    Phoenix, AZ
    08 TRD Off-Road PreRunner V6
    The grill comes out pretty easy...just open your hood...there are 2 silver screws that attach the grill on top and two plastic tabs on the left and right sides of the top. You just pop the tabs up with a flathead screwdriver and pull them straight up to remove. Then, look down between the grill and the radiator, there is a small plastic tab that locks over the grill to hold it in place on each side. Reach down and with a screwdriver, push on the tab as you pull up, the grill should slide up and out. The front emblem is removed by pushing on the two plastic tabs on the top of it and removing it through the front of the grill. Reverse to reassemble. Hope it helps!!
  10. Aug 17, 2011 at 6:24 AM
    CanisLupus
    CanisLupus Previously "MGMTacoFF"
    Northern Virginia
    2011 DCSB 4WD / 2013 Ninja 300
    If you're just trying to get the emblem out, get a flat head screwdriver and just gently pry the emblem off by putting the screwdriver underneath the emblem. I've gotten pretty good at prying it off for re-painting and such, but you may snap one of the tabs holding it on the first time, which is fine because it will still stay on if you snap one tab.
    GL
  11. Aug 17, 2011 at 8:12 AM
    Okeetee
    Okeetee I like the Anaheim Ducks
    Kyle
    Huntington Beach, CA
    '11 MGM TRD Sport DCSB 4x4
    OME 887 coil springs, Bilstein 5100s (front/rear), Light Racing UCAs, Wheeler's HD 1.5" AAL, 16x8 Konig Countersteer Offroads, Goodyear Duratracs (265/75/16)
    Dee Zee bed mat arrives today! Can't wait to install.
  12. Aug 17, 2011 at 10:32 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Changed oil and filter, greased zerks, Techron in tank, washed air filter and cabin filter. In case anyone reading this has trouble greasing the front zerks - I always did - the solution is to use a small one hand grease gun. You can easily push coupling on to the zerks. I always had a hard time getting coupling to lock on with the larger two handed gun - the grease always shot out around the zerk instead of going in it.
  13. Aug 17, 2011 at 10:54 AM
    Yota Toy
    Yota Toy Taco Sauce
    FX retros, Blazer fog-light retro, JVC KW-NT30HD head unit, Pioneer 6X9's in front doors, Pioneer 6.5's in rear doors, two Pioneer 12" subs in sealed boxes, Sony X-Plod amp, Hidden Hitch trailer hitch, EGR window visors, two PIAA low-tone horns, Westin light bar with two 100-watt KC low profile driving lights.
    Installed both PIAA "low tone" horns, in addition to the single factory horn. Man, it is loud now.
  14. Aug 17, 2011 at 5:34 PM
    95SLE
    95SLE Getting Ready for Summer
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Changed the oil and cleaned the K&N air filter.
  15. Aug 17, 2011 at 5:35 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    You will like it a lot.
  16. Aug 17, 2011 at 5:37 PM
    Guyota
    Guyota Member
    Phoenix, AZ
    Tacoma TRD Pre-runner
    bed roll cover, TRD exhaust, TRD wet okole, LED accents,
    I like the look of the LEDs accenting the headlights so here is what I did to my Taco. Has anyone else done this but not posted? Comments?
  17. Aug 17, 2011 at 6:50 PM
    Sanders17
    Sanders17 Well-Known Member
    Reed
    Livingston, TN
    Black Sand Pearl 08 TRD Offroad
    I washed my baby and filled her to make her twice as expensive
  18. Aug 17, 2011 at 7:30 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Bed Extender, OME lift with Dakars and 285 BFG KO2, Spidertrax spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Those LED's look pretty good! I personally dont like to try and copy Audi's and such. Its different when it comes from the Factory like that and someone trying to copy it...
    But that looks very clean! Good job on install! :D
  19. Aug 17, 2011 at 8:51 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    Pasadena CA
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights - 3k) Bullz Audio 0g wire Exterior: Blacked out OEM headlight housing Front grille swap (to chrome, dipped red) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome) 99 Cents Store tailgate lock Suspension: 1" spindle spacer kit (Addional nuts and longer bolts added) 4x4 leaf pack swap (middle leaf removed) 1" Drop Blocks Air Lift rear helper springs Rims: 18x9.5 Asuka ST 15-2 rims et26 all around 5mm billet aluminum wheel spacers 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Pioneer DEH 5000ub Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (old Dickies pants shift boot)
    mid day rolled the windows down, about 5 minutes ago rolled the windows up lol :D
  20. Aug 17, 2011 at 9:29 PM
    1Bigbird
    1Bigbird Yo! Wat up peeps?
    winter-peg
    2010 TRD D-Cab
Products Discussed in this Thread
