What have you made/created today?
Discussion in 'Garage / Workshop' started by ERMB, Oct 28, 2014.
  1. Jul 20, 2021 at 7:06 PM
    #2461
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Kilo Charlie[QUOTED] likes this.
  2. Jul 20, 2021 at 7:12 PM
    #2462
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    Thank you!
    wilcam47[QUOTED] likes this.
  3. Jul 20, 2021 at 7:38 PM
    #2463
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Looks photoshopped to me. Not gonna believe it unless I see the tacos in person. :hungry:
  4. Jul 20, 2021 at 7:55 PM
    #2464
    Kilo Charlie
    Iowa
    Guess you better fire up the grill! And if I could photoshop things like this I wouldn't need a real job! Haha.
  5. Jul 21, 2021 at 5:38 AM
    #2465
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Slashaar and wilcam47 like this.
  6. Jul 21, 2021 at 7:07 AM
    #2466
    Kilo Charlie
    Iowa
    No Cilantro on these tacos silly!
  7. Jul 21, 2021 at 1:54 PM
    #2467
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Boooo.
    gasparic104 and wilcam47 like this.
  8. Jul 23, 2021 at 9:16 PM
    #2468
    2008taco
    chris
    san diego
    That should be a bannable offense!!! Mods need to update the CoC.
    Slashaar likes this.
  9. Jul 23, 2021 at 9:41 PM
    #2469
    Kilo Charlie
    Iowa
    Y'all are a bunch of weirdos.. you don't put Cilantro on these tacos. Clearly it belongs on a lot of other tacos... as well as a lot of other things.. but not these ones.
    Maybe you all need to read the Taco Rules again.
    #youfail
    Slashaar and Fargo Taco like this.
  10. Jul 23, 2021 at 9:50 PM
    #2470
    2008taco
    chris
    san diego
    https://youtu.be/nRB8Jor8tPs
    CaptAmerica likes this.
  11. Jul 27, 2021 at 11:43 PM
    #2471
    gasparic104
    gasparic104 Trusty Spotter
    Cayleigh
    Instagram: @NotSo_JDM
    2015 Tacoma TRD Sport DCLB; 21 & 03 Corolla
    Working on supporting master dice files for clients at work now :D
    This was today's task
    wilcam47, Kilo Charlie and Fargo Taco like this.
  12. Jul 28, 2021 at 3:37 PM
    #2472
    gasparic104
    Cayleigh
    The fruits of last nights labor:
    Supports didn't come off suuuuper clean because I didn't have any warm water, but the last stage is usually how I receive them to polish for work, so it's really neat to be on the design end :D
  13. Jul 28, 2021 at 7:13 PM
    #2473
    wilcam47
    Will
    Bourbon state
    Thats really neat!
    T-yoda likes this.
  14. Jul 28, 2021 at 9:12 PM
    #2474
    2008taco
    chris
    san diego
    I'm curious why you're using supports when they all have at least 1 flat side.
  15. Jul 28, 2021 at 9:38 PM
    #2475
    gasparic104
    Cayleigh
    I'm not terribly well versed in this because I'm just getting into the 3D side of things, but from what I understand:
    1. Orienting a model at an angle creates supports of different lengths. On some printers, you can place supports closer to the wiper side, shortening the distance the wiper travels during the final layers, which is just a time saver. Not every printer is like this, though.
    2. Putting large, flat surfaces to an incline of 10–20 degrees increases success rate by a lot. When you print a model at an angle, you are reducing the surface area of each layer while also decreasing the amount of contact the print has with the tank. Smaller surface area means that the print is subject to less force as the build platform raises with every layer.
    3. When branching features of a model meet, the intersection can crack or split. Orienting the model to stand with the merging feature facing toward the build platform creates a shared base for branching features to grow from. Instead of layers coming together at a joint, the layers separate into different paths.
    4. It can prevent failure from overhanging features if we do any weird shapes, etc.
    5. Preventing suction in general. If I were to say, print the d6 (square die) on the build plate directly, it would probably suck right off onto the FEP sheet, so it would need supported on 5 faces rather than 3 due to the 90 degree angle of the other 4 faces. Any flat faces would also need to be absolutely covered in supports and trimmed with flush cutters rather than twisting off. Even if it didn't stick to the FEP sheet you would likely get "Elephant foot" which would warp the dice too badly to fix.
    Those are all the issues I can think of at the moment from what I understand about resin printers. My boss is one of the top master makers in the US so while I'm learning, I'm definitely just going to follow his example, haha.
  16. Jul 30, 2021 at 5:24 AM
    #2476
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    When I was in Colorado last week, one of the brackets for my Road Shower vibrated loose and fell off. Yakima does not sell replacements. So I made one.
    MNMLST, Sand Dog, Tacman19 and 7 others like this.
  17. Aug 3, 2021 at 5:29 PM
    #2477
    gasparic104
    Cayleigh
    Made some skull dice for a repeat client. Ran into snags every step of the way. Was super surprised when I pulled them out of the pressure pot today that they turned out totally okay
  18. Aug 6, 2021 at 10:54 PM
    #2478
    gasparic104
    Cayleigh
    Made a little sticker for the new corolla for some gentle flair
  19. Aug 6, 2021 at 11:05 PM
    #2479
    Hateful
    Hateful Member
    2000 Tacoma base xtracab
    Work in progress for an upcoming gallery show (virtual). Got a long ways to go but the tricky part is done. The theme is fear in technicolor.
  20. Aug 6, 2021 at 11:19 PM
    #2480
    gasparic104
    Cayleigh
    Absolutely love your color choices! What did you use to sculpt on the canvas?
    I hope we get to see it finished!
    wilcam47 likes this.
